Old 07-30-2011, 04:47 AM   #1591
zedtours
zedtours's Avatar
Oddometer: 382
balancer shaft seal
Thanks for reply on oil breather/balancer shaft seal.Seal did not look too bad [a la severino's] but it is a weird set up as shaft acts as the breather thru it's centre and with inertia it does seem that any oil getting up to airbox must come past that seal. Am I right?
zedtours is offline   Reply With Quote
Old 07-30-2011, 12:59 PM   #1592
Pyndon OP
Pyndon's Avatar
Oddometer: 2,590
Generally yes, unless you have bigger issues causing the engine to breath REALLY heavily, and then it blow it out anyway!
I put a one way valve in my breather pipe too, like the later 950's and 990's have. That and the seal did the trick!
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon is offline   Reply With Quote
Old 07-31-2011, 03:22 AM   #1593
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
Later models really dont have a one way valve. Just a aluminium block with a narrower channel in it. I think the one way valve was tried and gotten rid of really soon after that.
Do you have a picture of the valve you have installed?
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 07-31-2011, 03:45 AM   #1594
Pyndon OP
Pyndon's Avatar
Oddometer: 2,590
No, it's the latest one though according to KTM.
My KTM 950 Story
Old 08-04-2011, 05:52 PM   #1595
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Hi Lyndon,
Thanks for providing such a very detailed thread. It is huge to credit to you and a benefit to all others.
I am about to embark on preparation of 04 for a 2 year RTW trip. I was originally consisting replacing my old girl but like an old pair of jeans I know how she'll feel every time I go for a ride.
I plan strip the motor down for inspection as part of prep and replace bearings and like, she has a bit of a gearbox rumble in neutral with the clutch out plus the gear shift becomes very frim, loosens up and becomes firm after a big hit on my last trip so something may have come adrift somewhere in gear box.
Anyway to get to the point. From reading your post when you pulled your engine down much of wearable items were well within spec. Obviously to measure much of this requires some specialist equipment. Could you please provide a list of what special tools you think would be required? (dial indicators etc)
Also how well do you find that GPR exhaust holds to damage from rocks, logs etc up being swung down like that? I am thinking that is that way to go and adding rear tanks both sides.
Thanks heaps
Craig
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 08-05-2011, 12:28 AM   #1596
Pyndon OP
Pyndon's Avatar
Oddometer: 2,590
Originally Posted by ciedema View Post
Hi Lyndon,
Thanks heaps
Craig
Hi there, way to go......I would take my old girl around the world tomorrow, no worries! Well done having a go yourself. Be really meticulous though, you don't want to do a Steverino and have to do it four times before getting it right While your in there do everything that needs doing if you can afford it, it'll save you in the long run.
I can tell you straight away what the intermittent stiff gearshift is, it will be the small roller bushes on the shift fork that locates into the shift drum. One of these will be getting elongated, I've had to replace them before on other bikes that had the exact same symptoms. It'll only be one of them but get yourself three new ones regardless. While you are in there, replace the shift drum too, I've replaced a few broken ones from the earlier bikes, KTM replaced them with a stronger part, details are in here somewhere.
As for the tools, get yourself an engine repair manual, it tells you everything you need and you will need this to know all the specifications and wear limits etc. If you PM me your email address I will send you one, use the 990 engine repair manual as you will also them discover the other little bits and pieces that have changes over the years and you can decide if you want to upgrade those parts too. I'll send you both if you like.
You'll need KTM bearing presses to replace the white metal bearings (if you need to, although my guess is that they will be in spec). Also, if you have the older 04' engine and cases, you should check your base gasket surfaces for corrosion. Again, I have seen a few with this problem now. Again, details are in this thread. Get yourself a clutch holding tool too, it helps a lot.
Other than this you just need a good set of micrometers, dial bore gauges, feeler gauges (for ring gaps and valve clearances) and some plastigauge to check the rod bearing clearances.
It really does depend how many miles she's done how far you need to go into her. Dig out a list of all the tech service bulletins and double check that they are all done too, i.e. clutch bolts, boosters plate bolts, replacement of clutch push rod, flywheel bolts, flywheel lapping to crankshaft etc etc.
As for the GPR, I've had mine on for about 30,000 miles now and had no issues with rocks damaging it, or flattening it or anything. If you get it from www.adventure-spec.com they do a G-It bash plate to go with it (this is what I use) and it has an extra bit to protect the GPR. The silencer needed re-packing and re-riveting after 25K but I chose to replace it with an Akra and the collector pipe cracked so I had to get that welded. This is nothing worse than the standard system though, I had to get the rear header welded a couple of time on the standard system. I'm happy with it, it works and it looks good and best of all, it's gets all the heat away from under the seat!
Hope this helps, good luck with it and if your in the UK look me up!
Pyn
My KTM 950 Story
Old 08-05-2011, 03:24 AM   #1597
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Your pics show that it not that much harder that my 450 motor - just more bits.
Yeah definitely going to do that. It will need need do 100,000km on our trip and I hope to keep the motor more or less in one piece over this time.
Yeah will be replacing the lot no point scrimping on such a small part. I saw the pics of the upgraded drum seems also see no point in scrimping on this - especially since I am serial gearbox abuser.
That would be beaut.
Yep I saw those. Cool didn't of the clutch holder (generally use a rattle gun )
Probably a long way as per above I want to her to go a long way with out having to pull her to bits.
Will the Akra (or Wings) cans bolt straight up? That way I would only need the system and use one the wings pipes. I was looking at using the down swept as I want to have a fuel cell on each side. I have will have to see if Neduro will make me one for the RHS. I could put the Safari tanks on but I ride a KTM not a UTB.
Pyn
It does heaps, and April next year I will be in the UK for the start of the trip.
Old 08-05-2011, 02:39 PM   #1598
Pyndon OP
Pyndon's Avatar
Oddometer: 2,590
No, you have to use a custom silencer as it used a 54mm slip-on, not a bolt on.
My KTM 950 Story
Old 08-08-2011, 06:21 AM   #1599
neduro
Addict
neduro's Avatar
Oddometer: 12,052
That's a standard size for many manufacturers, though, so I think you can find a replacement pipe if you need one.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 08-08-2011, 07:03 AM   #1600
Pyndon OP
Pyndon's Avatar
Oddometer: 2,590
Oh yeah, forgot about you guys. Most European manufacturers use 52mm and 60mm inlet size, manufacturers such as Akrapovic for example. Hence why you will not find an off the shelf Akrapovic to fit the GPR 54mm (or I could not anyway) hence a modification was required.
Only 54mm silencers I could find to slide straight on the GPR just did not cut the mustard in either the Pyndon aesthetics or durability departments "and for that reason.......I'm out" sprung to mind.
Ned you set the ball rolling with the injuries......did my Medial Collateral Ligament on my left knee on the CRF yesterday. Not good at all but at least I have some time of work to get some maintenance done of the bikes, having no knee does not stop the wrenches turning
Pyn
My KTM 950 Story
Old 08-08-2011, 08:32 AM   #1601
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,742
Pyn -
I don't know about the Medial, but I tore both of my Anterior Collateral Ligaments years ago and I've been able to function just fine without them. The doc said that he couldn't repair mine due to my age but that if I kept myself in shape that the muscles in my legs would easily compensate for the missing (torn) Anterior Ligaments.
Good luck with it.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is online now   Reply With Quote
Old 08-09-2011, 04:35 AM   #1602
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Knees - the one injury that I constantly live in fear of, the recuperation is way to long.
Pyn,
For the case bearings that are standard sizes do you get them from KTM or buy them from a bearing supplier?
Cheers,
Craig
Old 08-09-2011, 08:49 AM   #1603
neduro
Addict
neduro's Avatar
Oddometer: 12,052
Bad news! Sorry, mate, heal fast.
FWIW, I have no idea what I'd be doing if I were still fully functioning, been working dawn to dark everyday without the distraction of riding, probably a good thing the option was removed for a few weeks.
Old 08-09-2011, 10:32 AM   #1604
Pyndon OP
Pyndon's Avatar
Oddometer: 2,590
Pyn,
Cheers,
Craig
Generally KTM but it really does not matter. If I want them quickly, bearing supplier works best.
My KTM 950 Story
Old 08-11-2011, 11:51 AM   #1605
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,507
My MCL is wonky, its loose but has tightened up on its own over the last few years. But still loose.
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Times are GMT -7.   It's 08:12 PM.
