Old 03-15-2009, 05:12 PM   #46
Grape_Ape
It Feels Good
Grape_Ape's Avatar
Oddometer: 547
Originally Posted by Long Gone
Any ideas on how to get a front Tourance to seal to the rim so I can even begin to inflate it? I've tried a tie-down strap around the circumference to force the bead in to the rim but I can't put enough pressure on it to do any good. I've seen an inflatable strap used for cage tires but I need something for on the road as well as at the house.
No, I don't particularly want to try the WD-40 and a lighter technique. But I'd love to watch someone else try it. On their bike.
Have you tried inflating the tire with the shrader valve removed from the stem? This allows alot more air to flow and it might do the trick.
Grape_Ape is offline   Reply With Quote
Old 03-15-2009, 05:34 PM   #47
gelandestrasse
Fidem Scit
gelandestrasse's Avatar
Oddometer: 20,255
I tried unsuccessfully to inflate a set of Maxxis Presa Detour tires on my R1200GS. I ended up pulling the valve core and hooking up an air hose to a compressor with a hand valve. The tire seated with a bang.
"The trouble with quotes on the Internet is that you can never know if they are genuine."
- Abraham Lincoln
gelandestrasse is offline   Reply With Quote
Old 03-15-2009, 07:46 PM   #48
pwlindo
I can do this!
Oddometer: 156
I just installed a set of TKC80's on my GS11 rims and had the same problem with the rear tire. I don't have an air compressor so i used the "free air" station at the local gas station. It's not exactly a powerhouse of air pressure and the tire wasn't filling. Then i realized i could feel where the air was escaping from the rim and pushed and pressed on that part of the tire until the air stopped escaping. The tire then filled and seated with a KA-BAAAAM at about 50 psi. Took 4 presses of the Start Air button. The front tire seated itself without any effort on my part.
'95 R1100GS
pwlindo is offline   Reply With Quote
Old 03-15-2009, 08:00 PM   #49
Barney Fife
Oddometer: 68
+1 on removing the Schrader valve to increase airflow. However one of my two air chucks won't flow air unless the Schrader valve is installed to depress the center of the air chuck. The other one works fine without the Schrader valve installed. You might run into something similar. Good luck.
Barney Fife is offline   Reply With Quote
Old 03-18-2009, 03:40 PM   #50
Groucho
Hexhead Hoon
Groucho's Avatar
Oddometer: 470
Great posts! This thread has inspired me to give this a shot!
Judging from the TKC80 that's already on the bike, I presume this is Continental's heavy spot mark:
"When in doubt, gas it. It'll either solve the problem, or remove the suspense."
2008 BMW R1200GSA Schnellpanzerkampfmotorrad
1977 Moto Guzzi 850-T3 FB
Groucho is offline   Reply With Quote
Old 03-18-2009, 04:05 PM   #51
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 941
Groucho,
No.....the TWI and arrow indicate the TIre Wear Indicator.....not the heavy spot........
whisperquiet is offline   Reply With Quote
Old 03-18-2009, 04:17 PM   #52
Groucho
Hexhead Hoon
Groucho's Avatar
Oddometer: 470
Originally Posted by whisperquiet
Groucho,
D'oh!
OK, found it.
Old 03-18-2009, 06:27 PM   #53
swanski
swanski's Avatar
Oddometer: 198
wait a minute, doesn't the paint spot indicate the light spot?
Swanski
'08 R1200GS
'08 Nigel Dennis Romany S
swanski is offline   Reply With Quote
Old 03-18-2009, 07:02 PM   #54
wsdbikes
New Max is Mad
wsdbikes's Avatar
Oddometer: 1,281
yes. the dot goes by the valve stem
Wsdbikes
"I only wish I had video running when WSD did a no footed can-can over some boulders on mainline....two feet of air easy..." -Abdelhub
Yeah, on the GS http://vimeo.com/3232838
Notable Past-'01 KLR 250, 95 R1100GS, 06 KTM 950 SM, 69 Bridgestone 90
wsdbikes is offline   Reply With Quote
Old 03-19-2009, 10:55 AM   #55
Groucho
Hexhead Hoon
Groucho's Avatar
Oddometer: 470
Yikes- gotta rotate that sucker. Thanks.
Old 03-19-2009, 11:09 AM   #56
Bike4Fun
Smooth IS Fast
Bike4Fun's Avatar
Oddometer: 1,758
Originally Posted by 08KLR650 ALICIA
No-Mar tire changers are very nice also. Kind of pricey for a manual changer, but the Nylon Blocks and Leavers eliminate any chance of scratching the wheel. I just LOVE mine.
No Mar partner and less expensive.
http://www.cyclehill-tirechanger-sec...ults.asp?Cat=1
Bike4Fun is offline   Reply With Quote
Old 03-19-2009, 01:07 PM   #57
Litre
AKA JimiChanga
Litre's Avatar
Oddometer: 412
Excellent write-up. Ordered a balancer, weights, and irons today. Going to give this a shot in a week or so.
“When the government fears the people, there is liberty; when the people fear the government, there is tyranny.” - Thomas Jefferson
- 2008 BMW R1200GS Adventure: Mine
- 2003 BMW F650GS: Hers
Litre is offline   Reply With Quote
Old 03-19-2009, 08:19 PM   #58
whisperquiet
Oddometer: 941
I just bought one last week.......I've mounted/balanced a new rear Michelin Anakee on my buddy's 1200GSA and front/rear tires on his KLR650. It works great..........I bought the Cycle Hill Big Package + the cone set to balance the GS rear wheel.
Old 03-20-2009, 07:03 AM   #59
Groucho
Hexhead Hoon
Groucho's Avatar
Oddometer: 470
SUCCESS!
Thanks for the excellent writeup!
Old 03-28-2009, 05:40 AM   #60
Big D
So Cal
Big D's Avatar
Oddometer: 143
HF Motorcycle wheel balancer
Thank you for the outstanding tire change writeup, things like that keep me coming back. Superstore is shipping a set of Anakee 2's and decided they needed to be balanced. I came up with this combo set, may save you a few bucks also.
HF sells motorcycle wheel balancer part #98488-2vga $60 and BMW rear wheel adapter #98490-ovga $30 (note does not fit 07 r1200gs)and they don't say what it fit, holes to big for 07 GS.
I ordered a rear wheel adapter from Marc P. that will fit the HF .500 dia bar.
When ordering from Marc tell him it is for HF stand and the bar is .500 dia. His bars are .500 also, so Marc's large rear adapter slides on nicely.
Enjoy
Daryl 07 GS So Cal
HF wheel balancer comes with two cones and .500 (1/2 inch) bar. The large center adapter is from Marc Parnes products. $35
Big D screwed with this post 03-28-2009 at 05:51 AM
Big D is offline   Reply With Quote
Times are GMT -7.   It's 02:20 PM.
