Old 03-31-2009, 09:31 PM   #61
impi
impi's Avatar
Oddometer: 1,247
Originally Posted by Bike4Fun
Thanks for this link. Quite a bit of a saving on the No-Mar's cost.
Impi
_____________________
2007 R1200GSA
impi is offline   Reply With Quote
Old 04-01-2009, 06:00 AM   #62
ricohman
Marinoni man
ricohman's Avatar
Oddometer: 1,981
Does anyone know if this adapter from HF will fit my 05' R1150GSA?
http://www.harborfreight.com/cpi/cta...emnumber=98490
ricohman is offline   Reply With Quote
Old 05-02-2010, 01:02 PM   #63
ricohman
Marinoni man
ricohman's Avatar
Oddometer: 1,981
What a chore.........
The original tires really didn't want to let go.
I'm still fighting with the front.
Should small nicks in the anodizing on my GSA rims be touched up to prevent corrosion? Or will the Dalton in June make these little marks seem insignificant?
Old 03-15-2011, 10:14 AM   #64
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,217
good tutorial..bump
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 03-20-2011, 08:46 AM   #65
KankakeeBenjamin
KankakeeBenjamin's Avatar
Oddometer: 328
nice tutorial
had to bump this. I havent fixed anything on my bikes in years because I worked a lot and didnt know how. I am finally going to give it a try and change my tires asap.
ride safe
KankakeeBenjamin is offline   Reply With Quote
Old 04-02-2011, 10:41 AM   #66
speedthrills
speedthrills's Avatar
Oddometer: 50
Does anyone know if 210 g is to much to bring a wheel tire into balance? Should I place it all in one spot? One row of six and one of seven, 7 g wts? Seems like a lot of weight. I must have missed the light spot on the tire. It is a tourance and not marked that I saw. Using marc parnes balancer.
speedthrills is offline   Reply With Quote
Old 04-02-2011, 03:01 PM   #67
802mike
802mike's Avatar
Oddometer: 452
Break the bead and rotate the tire on the wheel 1/2 turn.
802mike is offline   Reply With Quote
Old 04-02-2011, 08:46 PM   #68
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 980
Do you have TPMS valve stems?? If so, it may require a lot of weight..my '07 GSA did. I don't recall using over 3 1/2 oz or 98 grams to do so though.
+1 Rotating the tire 1/2 way is the best way to even things out.
whisperquiet is offline   Reply With Quote
Old 04-03-2011, 12:40 AM   #69
doc riverz
anatra di seduta
doc riverz's Avatar
Oddometer: 4,353
Nice post, Doug. I started my car fixing career as a tire buster. I did truck tires, car tires and motorcycle tires for 5 years before I went car tech full time.
I like your instructions and I like your inventiveness. However, I would not use a punch on my wheels, ever. Raising the metal around the punch mark creates a stress riser. This is where cracks can start. I just don't think it is a good idea.
Personally, I never balanced the bare wheel either. I did check them for the heavy spot and set the tire's heavy spot opposite it as you did and (usually spin) balanced the assembled wheel and tire.
doc riverz is offline   Reply With Quote
Old 04-03-2011, 12:46 AM   #70
doc riverz
anatra di seduta
doc riverz's Avatar
Oddometer: 4,353
Back in the day when I balanced tires for a living if a moto tire/wheel needed that much weight I would usually dismount the tire and rotate it on the wheel 180* and recheck balance. That usually resulted in it needing less weight. I almost always had a spin balancer that would indicate how much weight to put on one side of the rim vs. the other. If I static balanced the assembly I just split the weights on moto wheels to both sides.
Old 06-10-2011, 09:06 AM   #71
deeve
DumbA$$
deeve's Avatar
Oddometer: 1,348
Originally Posted by manfromthestix View Post
Curvy tire irons from http://www.bmwbobs.com/, faboolious tools. I take two with me when travelling plus some plug-patches for little adventures like this:
What kind of plug-patches are those and where do you get them? I have a PITA hole that I had to use two Stop&Go mushroom plugs because of the location (right in the v between the lugs) I really don't like the idea of that and the tires are new, so I thought I would try my hand at removing the tire and seeing if I can get the Stop & Go to seat better or if not do one of the inside repairs. If these aren't what I am looking for what would you all suggest?
DAVE
2010 KTM 990 Adventure-Nuclear Fusion Powered
deeve is online now   Reply With Quote
Old 06-10-2011, 12:49 PM   #72
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,144
Those 'mushroom' patches are the best. You should be able to find them at an auto tire store or shop. They require that you remove the tire from the rim but they are a very thorough solution.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 06-10-2011, 01:42 PM   #73
deeve
DumbA$$
deeve's Avatar
Oddometer: 1,348
I figured it's about time that I get the correct tools and learn how to remove my tire....
Old 06-25-2011, 06:31 PM   #74
Daryl_Stamp
Daryl_Stamp's Avatar
Oddometer: 808
This is a great write-up; I paid dearly to have several sets of tires changed by various shops; jumping in & doing it yourself is not only a great $ saver but will also save considerable time when you consider the convenience of doing it on your own schedule in your own location.
I suggest also to go through the effort of puncturing the old tire before it's removed, practicing how to plug it and then riding some distance on the plugged old tire. Sure, it takes some time, but it's way better to learn the ins & outs of plugging for the first time in your garage than it is on the side of the road under less than ideal circumstances.
Live while you're alive.
Daryl_Stamp is offline   Reply With Quote
Old 06-26-2011, 09:48 PM   #75
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,120
where are you disposing of your old tires?
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is offline   Reply With Quote
Times are GMT -7.   It's 02:38 PM.
