Old 11-21-2006, 02:18 PM   #1
walkingbear OP
walkingbear's Avatar
Oddometer: 3,587
Dr 350
does anyone know if a DR 400 motor will fit in a DR 350 (90) frame?
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 11-21-2006, 02:42 PM   #2
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,638
everything is possible. But not as a straight swap. Totally different beast.
KTM 950 ADV '05.5
KTM 690 '10
christian is offline   Reply With Quote
Old 11-21-2006, 03:40 PM   #3
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
No, DR350 is a dry sump, oil cooled bike and the DRZ motor is not. There is no reason to do this swap anyway as the DR350 frame and suspension isn't even up to handling a good stout DR350 motor. You are flirting with what would be a ton and a half of work going backwards. Just power up the DR350 with a cam big bore and a flatslide carb and some minor porting and itll be as fast as a DRZ400 is stock anyway.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 11-21-2006, 05:28 PM   #4
walkingbear OP
Oddometer: 3,587
problem
here is the problem, purchased a sitter.. clean the carb, changed the oil,
new plug, new air cleaner .. no spark or compression.
WHAT SHOULD I LOOK FOR NEXT?
Old 11-22-2006, 10:30 AM   #5
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,957
No compression could be the fact that the rings are dry. Try squirting a little oil into the cylinder. If the rings are shot, then it's tear-down time. No spark could be a few things. CDI box, bad plug, bad plug wire, etc. Electrical gremlins are the worst. Check out the Maximum Suzuki forums. They're DR specific and you'll most likely be able to search for (and find) the resolution.
Good Luck - Dave.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 11-22-2006, 11:20 AM   #6
patsymack
patsymack's Avatar
Oddometer: 330
Walkingbear,
You might want to check the compression release to make sure its not holding a valve open that could be the cause of low compression.As far as spark I have no clue .Hth
Patsy
patsymack is offline   Reply With Quote
Old 11-22-2006, 12:06 PM   #7
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
Lack of spark on a DR can be these three things, ok 4. Bad CDI, kick stand kill switch, clutch kill switch, or the starter relay. On Suzukis, the starter relay (if it is an ele start model) causes the bike to not have spark if it has gone bad. Id check the kill switches first. Is thsi a DR350, or a DR350S or SE? Need 2 know more to help!
Old 11-22-2006, 12:13 PM   #8
BikePilot
BikePilot's Avatar
Oddometer: 11,251
A flat battery will cause a no-spark situtation as well, even on the kick start models.
Also note that checking compression is tricky on the SE models due to the auto decomp mechanism. It will probably read around 80-100psi if you just stick a compression gauge in it and crank it over because one of the exahust valves will be held partially open.
good luck
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 11-22-2006, 12:58 PM   #9
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
What model are wee talkin here?
Plus, if we KNEW WHAT MODEL it is maybe we could get a little more informative??!! If it is electric start, DR350SE, then turn on the key, make sure you have juice ala light, from the headlight, then if so, the solinoid is under the seat, jump it and see if the motor turns over. If so, it is either the safety switches, the key switch, or the relay....
Old 11-22-2006, 02:25 PM   #10
patsymack
patsymack's Avatar
Oddometer: 330
He says its a 90 so I assume its a kicker.
Patsy
Old 11-23-2006, 09:20 AM   #11
honcho
Barley Adventurer
honcho's Avatar
Oddometer: 911
my (91) dr350 is definately not oil cooled.
it'll be an adventure!
honcho is offline   Reply With Quote
Times are GMT -7.   It's 05:24 AM.
