06-22-2012, 12:50 PM
#16 | |
Oddometer: 546
Compact, nicely made unit.
Now that everything has been made foolproof we are left with a society of fools. ~Ted Simon |
06-22-2012, 03:06 PM
#17 | |
Oddometer: 496
06-22-2012, 04:03 PM
#18 | |
"Cool" Aid!
Oddometer: 41,491
An external relay is not necessarily a plus, unless you tend to heavily load your fuse box. The screw terminals have not proven to be an issue so far, at least in the last several years. Jim
12-27-2012, 03:25 PM
#19 |
Still alive
Oddometer: 104
2006 1200GS Blue Sea 2025 install
Decided to post a few pics of my Blue Sea 5025 2006 1200GS install. I wanted a completely removable bracket that would not require any screw holes and left room below for relays as well as minimal clearance from seat. I have no need for the laughable GS tool kit so utilized that space.
![]() bracket is .063 aluminum ![]() Holes tapped to prevent screws hanging down below. ![]() Fits like a glove and took about 30 minutes to fab. ![]() Will be adding some tie down anchors for cleanliness sake prior to install in the bike. Will take some more pics after install. |
12-27-2012, 03:31 PM
#20 |
"Cool" Aid!
Oddometer: 41,491
Very clean!
![]() Jim
12-28-2012, 11:22 AM
#21 |
Still alive
Oddometer: 104
12-28-2012, 11:59 AM
#22 |
Oddometer: 78
I mounted the 5025 using (4) standoff spacers underneath the unit with long screws shown in the four corners.
For what it's worth, all connections are silver-soldered, and certain wires jacketed with convoluted tubing for abrasiion resistance. Both of which will mitigate electrical issues on the road. Dan kk3an screwed with this post 04-12-2013 at 03:35 PM |
12-28-2012, 12:24 PM
#23 |
Sure, why not?
Oddometer: 16,142
Really outstanding work!
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
12-28-2012, 01:42 PM
#24 |
why the hell not?
Oddometer: 1,300
now that's some of the tidiest wiring on a bike, I've ever seen! Really nice work there Dan
"It's not what you look at that matters, it's what you see." - HDT |
12-28-2012, 02:46 PM
#25 |
Oddometer: 78
Thank you, gents.
Dan |
12-28-2012, 05:28 PM
#26 |
Still alive
Oddometer: 104
Nice, looks clean. Similar to what I am doing with all ring terminals soldered, wire split loomed and heat shrink installed over ring terminals and meeting the loom for extra protection. Going to be constructing a very clean light bar for the bike over the next two weeks. If it turns out well enough I may mass produce some if the demand is there as the quality will be concurrent with much more expensive models.
12-28-2012, 05:55 PM
#27 | |
why the hell not?
Oddometer: 1,300
for the gs1200 (canbus friendly version?) interested.
12-28-2012, 06:11 PM
#28 |
Still alive
Oddometer: 104
It will be an aluminum solid roundstock mount for the driving lights of your choice. Mine will support dual HID Micro DE's but the bar will be built to last with final dimensions (measurement from bike fairing to the furthest point away) that can be specified with order. The standard dimensions will hug in pretty tight as I don't want them to be beaten in a light crash. The point is to match the size of the front fender support/oil cooler mount/subframe and flow nicely with the contours of the bike. Colors will be customizable as well to match frame or 60% black. I am going to try to keep the cost below 50 dollars, I have materials coming for prototypes next week. We'll see how she goes!
Reislust screwed with this post 12-28-2012 at 10:54 PM |
04-12-2013, 01:41 PM
#29 |
Oddometer: 10
Clearance under 1200 GS seat
Reislust. I LOVE how clean your setup is, but did you have to raise your seat to it's highest position in order to fit the 5025 under it? I borrowed a buddy's before he installed it on his 1150 GSA and I could not get the seat to latch shut while at the lower setting.
04-12-2013, 03:14 PM
#30 | |
"Cool" Aid!
Oddometer: 41,491
![]() Jim
