02-20-2013, 11:12 AM
#27451 | |
Ancien
Oddometer: 16,355
02-20-2013, 11:14 AM
#27452 | |
Ancien
Oddometer: 16,355
Have fun with it.
02-20-2013, 12:13 PM
#27453 | ||||||
part-time wanderer
Oddometer: 1,487
keep in mind that we're talking about head tube angles, where differences in fractions of a degree make difference in handling that are noticeable. fork length and headset heights are all going to (literally) add up to make a difference in this. if you've already verified that all the parts you're swapping add up correctly, great. (judging by where the brakes line up on the rim doesn't tell you much; there's often a good deal of room for adjustment.) Quote:
good luck!
just a guy... '02 GS Adv |
#27454 | |
Aven'Tourer
Oddometer: 9,706
well, so you have a frame with 1" threaded headset, and a 1" threadless fork? Whale, Aisle Bee Daiman. they still make 1" threadless headsets. http://www.aheadset.com/bicycle-headsets?p=TR.1 whats missing here is the size of the head tube this fits into, one can only pray its the same as what you have. I *think* that was pretty much standardized prior to the current 1-1/8" stuff. now you need to remove the headset from the frame (remove bars, stem, remove old forks, use long brass drift and hammer to tap out the headset cups from behind). take the frame to LBS to have the head tube reamed and faced (the tool to do this properly far exceeds the cost of this whole project). install threadless headset cups in freshly reamed and faced frame (I've been known to use a wood block and rubber mallet, its properly done with a press, others have used threaded rod and big washers, whats important is that both the cups go in STRAIGHT and fully seat). install the crown race on the fork. assemble the headset stack with the fork. now you get to find a stem that fits a 1" threadless system, should be fun since /everything/ is 1-1/8" nowdays.
Experience is what you get when you don't get what you want. |
02-20-2013, 01:14 PM
#27455 | |
That's MR. Toothless
Oddometer: 25,568
I can't wait till he installs the fork... ![]() @Pierce: they make shims for that 1" -> 1 1/8" thing. That's not a problem Any LBS that's been around a while should have a few laying around. M
There. I've moved back to VA. Can you PLEASE change the weather?! |
02-20-2013, 02:09 PM
#27456 | |
Oddometer: 456
As for your first question about trail...yep... Basically the larger the trail, the more straight line stability you have at the sacrifice of cornering.... Head tube angle plays a large factor in that....and with my 700c tires, i have decreased the trail by lowering the axle 3/8", thus making the head tube slightly more vertical...taking around a half to 3/4 degree off the headtube angle... As for the voids in the welds, usually theres some telltale of a void, somtimes theres not, risk i am taking....like i said...i already have over a thousand miles on the frame, if there was a bad weld, riding 1000 miles on chicago roads would have brought it to light... As for the real bike off craigslist comment.....i prefer ebay....and built this up last fall after i retired my 3900 hardtail...LOL that had 15k miles.... ![]() Heres my hard tail that i just mentioned... ![]() So yeah i can build a nice bike too... This ones a fun build...that just happens to work for me...if i were riding the frame offroad? Hell no i wouldnt be building off a dept store frame... For mostly smooth and all paved riding? I dont have any qualms about using it... |
02-20-2013, 02:25 PM
#27457 |
Oddometer: 2,444
My SS is setup the same way; 26" > 700c. I love that bike!
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
02-20-2013, 02:35 PM
#27458 | |
Oddometer: 456
Gotta think outside of the box when dealing with me... Otherwise it will cause you headaches....LOL |
02-20-2013, 02:40 PM
#27459 |
Oddometer: 456
02-20-2013, 04:20 PM
#27460 |
part-time wanderer
Oddometer: 1,487
i'll wish you good luck again 'cuz i expect you're going to need it, and in spite of the fact that you came here asking for help it seems there's nothing anyone can help you with that you don't already (think you) know.
(i'm glad it's not my bikes you're working on! it's going to be, uh, interesting.)
02-20-2013, 05:14 PM
#27461 | |
Aven'Tourer
Oddometer: 9,706
who said "its not what you don't know, but what you know that ain't so, that gets you in trouble!" ?
02-21-2013, 06:18 AM
#27462 |
Oddometer: 2,444
Meh. Some of us love to experiment and learn on our own.
02-21-2013, 06:28 AM
#27463 |
Oddometer: 25,568
I think we all get that. I've made stuff work that by all rights shouldn't have.
You aren't a mechanic for 20 years if you don't. ![]() One of my favorites was a pair of thumb shifters on a road drop bar as 'barcons' for my around town bike back in college. Ricky's got a lot more than that. He's got creativity coming out his ears! I get that sometimes there's awesome things that come out of 'hey, let's see what THIS does!' Just look at most of the 'some assembly required' section of this site. ...but if collectively everyone says 'it isn't a good idea' would you keep going or would you stop and think about it some? ![]() Me? Faggetaboutit. I'm going for a 3-4hr ride on my cross bike here in a bit. Good thing its 'warmed up' to the 30s! ![]() M
02-21-2013, 06:50 AM
#27464 | |
Oddometer: 2,444
02-21-2013, 07:00 AM
#27465 | |
Oddometer: 456
That said i did prove a lot of people wrong with the last "unanimous you cant make it work" project.... Front engine rear wheel drive 5spd gocart.....LOL ![]() Thing does almost 40, powered by a 1979 honda xl75 motor... |
| Thread Tools | |
