Old 07-12-2006, 08:30 PM   #1
jimmy2020 OP
limpiador de ventanas
jimmy2020's Avatar
Oddometer: 957
? bout removing 17t c-sprocket.
there is a part that appears to block pulling out the sprocket. Located about 7 o'clock when looking at it. Does this need to be moved or will the sprocket squeeze by. Also, I assume that the bolt holding on the CS is a lefty loosen and not a counter thread. Also while asking all this...do ya know the size socket needed.
Jim
Did a quick search, but no luck...
jim
"the adrenaline and stress of an adventure are better than a thousand peaceful days"
jimmy2020 is offline   Reply With Quote
Old 07-12-2006, 08:34 PM   #2
Mouse
I'm only smelly
Mouse's Avatar
Oddometer: 8,830
here
"Australian history... is full of surprises, and adventures, and incongruities, and contradictions, and incredibilities, and they are all true." Mark Twain
“It is better to stir up a question without deciding it than to decide it without stirring it up”
Mouse is offline   Reply With Quote
Old 07-12-2006, 08:47 PM   #3
jimmy2020 OP
jimmy2020's Avatar
Oddometer: 957
thanks for the link mouse...
I have a Dakar and it is literally a 5 minute job.
"K T M !"
I guess once it is on, I will just leave it.
jim
Old 07-13-2006, 01:53 PM   #4
SeaBass
SeaBass's Avatar
Oddometer: 939
Jim
Did mine the other night. Wound up removing the rear wheel to get enough chain slack to wiggle the 17t off, after unbolting the slave cylinder (at 7 'oclock). Took about an hour altogether. DONT LOSE THE PIN IN THE CLUTCH ROD!
Socket is the same size as the rear axle bolt.
SeaBass is online now   Reply With Quote
Old 07-13-2006, 08:03 PM   #5
jimmy2020 OP
jimmy2020's Avatar
Oddometer: 957
thanks SEABASS
I just put on my 16t. Just went for a quick test rise and I LIKE. I should have taken your advice about removing the rear wheel. I tried just loosening the chain and figured that would not work. So off came the rear wheel and I was in business. A little tip I learned was when you use the KTM wrench, just stick it on the nut and spin the rear tire to loosen. It is too difficult to try to spin the wrench.
Thanks again everyone.
jim
Old 07-14-2006, 08:49 AM   #6
SeaBass
SeaBass's Avatar
Oddometer: 939
It's a good EZ mod. The front end gets real light when you hammer it now!
Felt like I had headshake the first ride as i was nailed in 3rd, b/cthe bars got so loose in my hands
Old 07-14-2006, 07:56 PM   #7
Orangetwin411
Katoom Rider
Orangetwin411's Avatar
Oddometer: 292
I just did mine tonight also. If you loosen the rear axle nut and remove the right chain adj block, you can tap the axle out just enough to spin the left adj block. That will give you enough slack in the chain to get the job done. For those that have not done this yet... there's a nyloc nut on the upper left bolt that retains the sprocket cover. Make sure you catch this when you remove the sprocket cover. A pair of channel lock pliers work well to crimp the flat washer to the sprocket nut when you are wrapping up.
Scott W.
2002 KTM 380 SX
2005 KTM 300 MXC
2005 Kawasaki V2K Ltd
2005 KTM 525 SX
2007 KTM 950R
http://bigsaint.smugmug.com/
Orangetwin411 is offline   Reply With Quote
Old 07-14-2006, 09:24 PM   #8
VintageThumper
Gotta ride!
VintageThumper's Avatar
Oddometer: 1,026
I've had a 16T on order for about a month, and it still appears to be on B/O. Anyone know of a source other than KTM for one of these things?
One adventure bike + one retro bike + one dirt bike = one big grin
VintageThumper is offline   Reply With Quote
Old 07-15-2006, 05:59 AM   #9
jimmy2020 OP
jimmy2020's Avatar
Oddometer: 957
try elite motosports
It's a ktm dealer in Loveland Co. I bought mine last week. They have it in stock. 970-461-1022. ask for Don
jim
Old 07-15-2006, 12:36 PM   #10
SeaBass
SeaBass's Avatar
Oddometer: 939
Got mine from KTMTWINS.
Old 07-15-2006, 04:02 PM   #11
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 11,663
That would be strange - the backorder, that is - my dealer in Columbus just ordered and got them in his usual order. Took about a week because he had sold them out already.
I know we're about 100 miles from the warehouse, but UPS goes everywhere, eh?
Try KTMTWINS.
Dave
dunno.....
Times are GMT -7.   It's 05:15 PM.
