Old 07-14-2006, 10:34 AM   #1
Willi-P OP
Just a man.
Willi-P's Avatar
Oddometer: 706
TKC80 Tire Pressure Offroad
Question for all y'all GSers who run offroad with TKC80's, do you air-down? If so, what pressure do you run offroad vs. on road?
Willi-P is offline   Reply With Quote
Old 07-14-2006, 10:42 AM   #2
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,999
Jimmy Lewis says not to drop the pressure on GS's (I think).....
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 07-14-2006, 10:50 AM   #3
Willi-P OP
Just a man.
Willi-P's Avatar
Oddometer: 706
Hmmm. Interesting. I'd think lower pressure would work better offroad. Maybe you run the risk of spinning the tire on the rim or something?
Old 07-14-2006, 11:12 AM   #4
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,338
Do a search for this topic...there are plenty of opinions and it's been discussed to death.
My opinion? I'm with Jimmy....I've ridden behind him some and I think he knows these bikes pretty well...leave the pressure alone with TKCs and learn their feel.
Just my $.02
Cheers,
Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Old 07-14-2006, 12:17 PM   #5
Willi-P OP
Just a man.
Willi-P's Avatar
Oddometer: 706
I gotta say if that's what Jimmy says, I ain't arguin'.
But, what did I buy this neat little electric air pump for then?
Old 07-14-2006, 01:50 PM   #6
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,975
TKC80 balancing
Not to hijack this thread, but does anybody know if TKC80s have a mark or dot like some tires to indicate the lightest point on the tire?
The only marks I've found are a "D6" stamped in yellow on the rear tire and an "A1" also stamped in yellow on the front tire. Are these the indicators or something else?
This set of TKC80 was made in Korea, if that makes a difference.
I'm planning to mount tonight or tomorrow.
Thanks,
David
GSBS is offline   Reply With Quote
Old 07-14-2006, 01:53 PM   #7
TedShred
PHAT BASTARD
TedShred's Avatar
Oddometer: 974
I lower the pressure to 20lbs on my 1200GS for off pavement riding. The bike handles much better...
"Well Traveled Wise-Ass"
2006 DRZ400E
2005 R1200GS
TedShred is offline   Reply With Quote
Old 07-14-2006, 02:13 PM   #8
Coach
Coach
Coach's Avatar
Oddometer: 103
You might consider changing air pressures with speed and terrain.
I have run the TKC80's (Touratech sponsored 1150GS) as low as 16psi for competition sections at speed. Never lost a bead even when crossed-up (sliding sideways). For pavement transfer sections, I'd go back to normal air pressures with a 12v pump and look for a 10% pressure increase from cold to hot.
For two track or off-road, if there are a lot of rim-busters (embedded rocks), I either leave the pressures high to protect rims (high speed) or drop air to improve traction (low speed).
Hope this adds something to the discussion.
Ramey "Coach" Stroud
Coach is offline   Reply With Quote
Old 07-14-2006, 03:19 PM   #9
Flash412
Elk Biffer
Flash412's Avatar
Oddometer: 9,196
I had the pressure at 28 or so on the rear TKC80 on my F650 and tore the stem out of the tube in deep sand. I don't think I posted my Dualsport Solstice Ride Tale here. (Four flats to fix in one day.)
Click here for Gathering Speed - Tales of Motorcycles and Life
60 countries/6 continents, 40/6 on motorcycles, so far, and counting...
50 US states, 49 via moto. ɹǝpun uʍop uǝǝq ı
Links to Forty years of my Adventure RIDE REPORTS
Helmet laws interfere with natural selection.
Flash412 is offline   Reply With Quote
Old 07-17-2006, 07:52 AM   #10
Willi-P OP
Just a man.
Willi-P's Avatar
Oddometer: 706
Thanks Y'all!
Your comments on this topic are very helpful!
Old 07-17-2006, 07:58 AM   #11
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,481
I do not air down, seems to work fine.
GSBS - Go by the yellow stampings. If the amount of weight to balance is excessive, deflate, rotate tire, and rebalance.
Don C
dlrides is offline   Reply With Quote
Old 07-17-2006, 09:02 AM   #12
Just_Sean
herewegoagain
Just_Sean's Avatar
Oddometer: 14,504
I generally don't, but Hyde said to drop to 20 front and rear for his class - keeps a lot of small rocks from tweaking your handlebars around
Just_Sean is offline   Reply With Quote
Old 07-17-2006, 09:48 AM   #13
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,975
Thx
Don C
Thanks Don!
Old 07-17-2006, 09:55 AM   #14
mikerd400
mikerd400's Avatar
Oddometer: 1,830
I'm with Ted on this one. I air my tires down. I have ridden with the air pressure up. The bike handles much easier with the tires aired down.
Mike
2009 BMW R1200GSA
2005 BMW R1200GS (onto motorcycle heaven)
2003 Kawasaki KLR650
1977 Yamaha RD400
1976 Yamaha RD400
Proud to be Riff Raff 2011!
Riff Raff 07, 08, 09, and 10!
mikerd400 is offline   Reply With Quote
Old 07-17-2006, 10:35 AM   #15
Venture
Venture's Avatar
Oddometer: 214
I run the following air pressures with TKC80 or with Tourance....
Riding solo with no gear loaded on the bike I run 20lbs front and rear.
Riding solo with bags and gear loaded on the bike I run 25-30 lbs depending on how much I'm carrying.
Once I air down, I keep the speed below 50 mph on asphalt (to keep the tires from getting too hot) and take the curves real easy (to keep the tires from slipping off the rims)..... I play it conservative....
Venture is offline   Reply With Quote
Times are GMT -7.   It's 11:47 AM.
