Old 02-28-2005, 08:39 AM   #16
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by ChrisC
Your cell walls are too impermeable for osmosis, what do you think you're made of...fuckin' Goretex?
Mornin' Crappy....
Mornin' Kissy Chrissy...
Not me you boob... see, you make a mark on a dish towel you steal from the kitchen... then you shove X amount of mm into the fork leg... then... nevermind.
So... how's tricks?
creeper is offline   Reply With Quote
Old 02-28-2005, 10:02 AM   #17
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,252
that's "wicking" you wacker
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 02-28-2005, 10:06 AM   #18
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Ooops...
Osmosis, in botany and chemistry, the flow of one constituent of a solution through a membrane while the other constituents are blocked and unable to pass through the membrane. Experimentation is necessary to determine which membranes permit selective flow, or osmosis, because not all membranes act in this way. Many membranes allow all or none of the constituents of a solution to pass through; only a few allow a selective flow.
My bad.
So... how's tricks?
Old 02-28-2005, 11:11 AM   #19
meat popsicle
Ignostic
Oddometer: 14,252
Ooops...
My bad.
It is also defined as flow from areas of low concentration to areas of high concentration - almost applicable except the main force of movement in the towel case is surface tension right?
Or you could go for the "learning thru osmosis" definition (just reading Chrissy's posts makes me dumber... ) but that is more of a stretch.
back on target, is their some indications that fork oil might need to be changed?
Old 02-28-2005, 11:16 AM   #20
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Karma has a lot to do with it.
Still Karma.
How black... is your Karma?
So... how's tricks?
Old 02-28-2005, 12:53 PM   #21
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Mine must be bad....got up in Denver and now I'm in Fargo...brrrrrrrrrrrrrrrrr
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-28-2005, 12:54 PM   #22
meat popsicle
Ignostic
Oddometer: 14,252
i was kinda trying to get away from the "motorcycle maintenance thru channeling the universe" stuff (like my Jehovah's Witness crack that ChrisC snagged).
so what your saying is, visually inspect the fork oil every so often and see if it's Karma is gone? kinda like my oil eh? whent the motor is running I can see the particles sloshing around in the oil...
Old 02-28-2005, 12:55 PM   #23
meat popsicle
Ignostic
Oddometer: 14,252
ride report link?
Old 02-28-2005, 01:07 PM   #24
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
ride report link?
Ride Report
Chris
1943 BSA M20WD
Old 09-21-2005, 09:50 AM   #25
drmax
Oddometer: 330
oil seals...
I've searched but not dice. Is there a place here of how to change the oil seals?
My '02 LC4 has evidence of leakage on left side. Seems like these could be cleaned with something but not sure. Thx
drmax is offline   Reply With Quote
Old 09-21-2005, 12:32 PM   #26
Velocibiker
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
You probably just have some grit or something in there. Pull the dust seals off and slide a piece of 35mm film up and around the seal. Be careful and work slowly. Once done, I goob some white lithium grease up in there before I push the dust seals back on.
If you're lucky, your leak will stop. If not, the forks will need to be torn down to replace the seals.
Currently bikeless.
Velocibiker is offline   Reply With Quote
Old 09-21-2005, 01:19 PM   #27
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
Did we ever determine what fork oil height should be in a USD equiped 640 ADV?
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack is offline   Reply With Quote
Old 09-21-2005, 01:57 PM   #28
Velocibiker
Oddometer: 1,164
WP manual states:
Keep the outer-tube down and the
piston rod a little bit extended
(like picture), fill the forkleg
with oil till the edge of the
outer-tube, wait a few moments,
you will see airbubbles rising
up.
The oil must stay above the 4
holes of the inner-tube, if
necesarry fill some extra oil in
the forkleg.
12_206
Move the piston rod (keep the
adjustment tube on his place)
several times up and down, till
you feel that the cartridge is
full with oil, (the damping is
smooth over the entire stroke)
mostly it is necesarry to fill
some (not too much) extra oil in
the forkleg.
Now compress the piston rod and
outer-tube fully down, and fill
the forkleg with oil till about
25mm under the 4 holes of the
inner-tube. Move the piston rod
and the outer-tube at the same
time several times up and down
over the entire stroke.
Push the piston rod and outertube
fully down and adjust the
oil level (airchamber) with
T137S
Airchamber is 120mm for the 2003 Adventure.
Currently bikeless.
Old 09-21-2005, 02:32 PM   #29
G.Kennedy
G.Kennedy's Avatar
Oddometer: 1,850
This is a small point and maybe obvious but, ... back to step one
1. loosen top triple clamp bolts
2. loosen caps
3. loosen bottom triple clamp bolts.
The top triple clamp puts pressure on the caps, they come off easier if you loosen the top triple first.
Back to your regularly scheduled program .....
'00 R1100RT
'05 525EXC
'08 Hypermotard
IBA#11791
G.Kennedy is offline   Reply With Quote
Old 05-08-2006, 10:24 AM   #30
meat popsicle
Ignostic
Oddometer: 14,252
karma...
Times are GMT -7.   It's 03:22 AM.
