Old 05-08-2006, 12:53 PM   #31
Thorny
Bent But Not Broken
Thorny's Avatar
Oddometer: 496
Originally Posted by Randy
what mcomstock said but i will add one small hint: break the fork caps loose before loosening the triple clamps. you also don't really need the special float tool although it may be worth having. i've always gotten by with a ruler and small flashlight. just pour in the approximate amount of oil, with the forks fully collapsed without springs and measure oil level from top of tube to top of oil. adjust as necessary. i just use a large syringe with plastic hose to suck out excess if necessary.
Important Point on this:
If you do not loosen the top tripple clamp you may not be able to loosen the fork cap because it actually squeezes the pipe tight enough to hold the fork cap from turning. So loosen the top tripple clamp and keep the lower one tight. that should allow the cap to spin.
Thorny is offline   Reply With Quote
Old 07-13-2006, 11:07 PM   #32
Wannabeeuro
Tuner chic
Wannabeeuro's Avatar
Oddometer: 1,972
Confused about fork oil level
Questions: I can't really tell in the WP manual where the outer tube is in realtion to the inner tube when measuring oil level, Can someone clarify this for me? Also what level is the piston at?
"Build a man a fire and you will keep him warm for a day, set the man on fire and you will keep him warm for the rest of his life"
Find Me with SPOT http://share.findmespot.com/shared/f...kUQSskMiIucMuB
Wannabeeuro is offline   Reply With Quote
Old 07-14-2006, 09:15 AM   #33
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,900
I guess you are talking about the sliding part of the fork? All the way down.
I might add that there are a lot of flakes from the springs that start to float around in the forks, they get into the valving and will affect how the forks work. The only way to get them in tip top shape is to take them apart and clean all the parts.
I weigh in at over 200 lbs., on the last cleaning I raised the oil level to 100 mm and that has solved the bottoming out problem for me. With the higher oil level the bike handles better now. New springs would be a better fix, so many things to do.
mars is offline   Reply With Quote
Old 07-14-2006, 10:47 AM   #34
Wannabeeuro
Tuner chic
Oddometer: 1,972
Sorry I was not very clear. Yes, I was asking if the lower fork is compressed all the way into the upper when you measure the oil level.
I am going to try 120 mm of air space even though I am a bit lighter at 170 I like to jump and I am hoping that I get a bit less dive on the street as well so that I can practice stoppies if I ever get the guts.
Old 03-13-2007, 04:23 AM   #35
The Duke
Guest
Oddometer: n/a
Thumb Gary's report?
Originally Posted by Gary
Thanks MC and Randy for the tips. This is making sense to me now.
Gary
Gary,
Just waht I was looking for!. I must have spent a day looking for this information on the forum - (the manual is seriously scary) so I look forward to hearing of your experience. Please document the procedure in detail I'm sure others will apprecoiate it. (I'm on a 99 Duke!!)
Old 03-07-2010, 04:31 PM   #36
jamesdemien
jamesdemien's Avatar
Oddometer: 609
Gonna do this next weekend... thanks guys!
Everyone else should probably do it too... I'll take some photos of the innards.
If you don't fall you're not going fast enough?
Gateway BMW Motorcycles St. Louis | Vimeo
jamesdemien is offline   Reply With Quote
Old 03-08-2010, 10:36 PM   #37
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,223
Here are some more links for you:
http://www.advrider.com/forums/showthread.php?t=339544
http://www.advrider.com/forums/showthread.php?t=286065
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-08-2010, 11:01 PM   #38
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,900
in the process of replacing the seals in mine. 10 k on them. i finally settled on 5.2 springs, stock valving and 145 mm oil level with 7.5 weight oil. The are the closest to factory works forks feel I have ridden. I rode one of the factory Dakar bikes a few years back and they were a good benchmark. I weigh in at 220 lbs. and I can not bottom them any more and they have a very compliant and progressive feel.
Old 12-01-2010, 08:49 PM   #39
kdscoates
kdscoates's Avatar
Oddometer: 3,485
how did this work out for you?
Quote from Pj "if loud pipes save lives imagine what learning to ride that thing would do!!!"
quote from 4runner "but,if you really need a 80/20 , which most of us do and won't admit it,"
kdscoates is offline   Reply With Quote
Times are GMT -7.   It's 07:30 PM.
