Old 08-26-2008, 07:23 AM   #751
wsdbikes
New Max is Mad
wsdbikes's Avatar
Oddometer: 1,281
been discussed in multiple threads. I looked at that as an option but couldnt find anyone to try a test fit. looks close but i think it would take a lot of work.
I will say that the SM is fine for light off road and will do single track if you have to but, i aint no dirt bike. If I had bought the SE instead I would probably still have it. If you want to pound it off road the SE is the choice. If you want a hooligan good time bike that is great on the street and can do dirt roads, gravel roads and light 1-2 track the SM works. Need a skid plate though. there are exposed oil lines under the engine.
Originally Posted by LostOzzy
Hello y'all
slightly confused. when did ktm start routing the exhaust underneath the motor for the supermoto?
currently undecided between the se and the sm. any pointers in either direction? i have plenty of road and off road experiance so confidence on either is not a factor.
has anyone put the se exhaust header on the sm?? is this even viable?
Wsdbikes
"I only wish I had video running when WSD did a no footed can-can over some boulders on mainline....two feet of air easy..." -Abdelhub
Yeah, on the GS http://vimeo.com/3232838
Notable Past-'01 KLR 250, 95 R1100GS, 06 KTM 950 SM, 69 Bridgestone 90
wsdbikes is offline   Reply With Quote
Old 08-26-2008, 09:15 AM   #752
Maineroads
Ridgerunner
Maineroads's Avatar
Oddometer: 831
+1, someone make a skid plate!
Steve
Maineroads is offline   Reply With Quote
Old 08-26-2008, 10:53 AM   #753
Maineroads
Ridgerunner
Maineroads's Avatar
Oddometer: 831
Re: the shift lever height. I removed the rubber insert in the pegs and lowered the lever one notch. The combo seems spot on for me. Thanks for the ideas.
Steve
Old 08-26-2008, 10:03 PM   #754
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,100
Whelp, the "Klacker" is a very real thing. I'm ordering parts tomorrow and fixing it next week. It's been getting worse and worse instead of better. Remarkable, huh? I thought if I ignored it...well, no.
I have the water pump parts on the shelf ready to go when it does, so I'm in front of that one, and now I'll keep an eye on my fuel pump points and I'm over the hump!!
2005.5 KTM 950 Adventure
2005 Ducati ST3
Chuckracer is offline   Reply With Quote
Old 08-26-2008, 11:47 PM   #755
Aleong1967
KTM Newbie
Aleong1967's Avatar
Oddometer: 15
Pretender windscreen
Hey Chuck , I saw in a old posting that you had the Pretender windscreen on your bike.
How is it after having it for a few months?
When you ordered it, do you remember how long it took to get to you from Germany?
Did it come UPS or Fed EX?
I ordered one last week , so Im wondering how long I should expect to wait
P.S. did you order the tall or the short screen?
Thanks for any info
Andrew
Aleong1967 is offline   Reply With Quote
Old 08-27-2008, 08:24 AM   #756
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,100
Actually it came with the bike (used), and I sold it after two rides. To me, it didn't seem to actually accomplish anything other than generate turbulence. It was a tall. btw.
I've tried three different windshields now on this bike, and have come to like nothing the best.
2005 Ducati ST3
Old 08-27-2008, 08:39 AM   #757
wpbarlow OP
Oddometer: 10,441
Originally Posted by Chuckracer
...I've tried three different windshields now on this bike, and have come to like nothing the best.
Did you try the Hyde Racing type that I use? It works for me; though I know people have different sensitivities wrt this.
wpbarlow is offline   Reply With Quote
Old 08-27-2008, 08:41 AM   #758
wpbarlow OP
Oddometer: 10,441
Originally Posted by JBird
Walter, ... I think KTM should give you a SD for all your hard work, no marketing MBA can get better results
Thanks! I'll be sure to mention that to them
Old 08-27-2008, 09:38 AM   #759
SteveAS
Crank
Oddometer: 193
I have the tall Pretender screen. I notice no increase in turbulence and a half-decent reduction in wind blast. 85 with the screen feels about as tiresome as 70-75 without it.
SteveAS is offline   Reply With Quote
Old 08-27-2008, 02:17 PM   #760
Milhaus
Made in Denmark
Milhaus's Avatar
Oddometer: 3,010
FRONT brake pads
What are you guys seeing for life on the front brake pads? I have close to 4,000 miles on mine and they look fairly well used at this point??
| 2007 KTM 450EXC |
www.mypersonaldefense.com
Milhaus is offline   Reply With Quote
Old 08-27-2008, 04:19 PM   #761
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,100
So far I've tried the Pretender Tall, The Laminar Lip Tall (mounted in two different heights), and the KTM 690 SM screen.
I'll use the tall LL or the KTM when it gets cold up here, but I hate the turbulence from all of them.
2005 Ducati ST3
Chuckracer screwed with this post 08-27-2008 at 04:26 PM
Old 08-27-2008, 04:22 PM   #762
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,100
I've got 16000 miles on mine now and the pads are fine.
2005 Ducati ST3
Old 08-27-2008, 04:25 PM   #763
JBird
Retriever
JBird's Avatar
Oddometer: 832
I purchased the KTM Tank bag (62512019200)per the recommendations earlier in this thread. Just received it and wanted to say whoever recommended this is correct - perfect fit (and very secure,) very nice quality, and I can even refuel without moving it one bit. I am very happy with this and would second those who recommended it.
Got it from cheapcycleparts.com $135.00
I appreciate the knowledgebase here!
JBird
KTM 1190R
KTM 950SMR
'08 Goldwing
'98 Golden Retriever
JBird is offline   Reply With Quote
Old 08-27-2008, 04:28 PM   #764
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,100
Yep, I use mine a lot, and am thrilled with it.
I found re-fuels were tricky till I realized you can up-zip it from the base 2/3's of the way around and simply lean it over to the left...brilliant!
2005 Ducati ST3
Old 08-28-2008, 06:05 AM   #765
Nick Makwell
Bavarian Murder Weapon
Nick Makwell's Avatar
Oddometer: 672
Walter, Chuck everybody else - thanks for the great thread and info.
I've bought the third last new 2007 950SM available in Australia and I can't wait to pick it up!!! (has to be shipped from Perth to Brisbane, then assembled)
Got the full touring package and looking forward to some great rides.
cheers!
_________________
1981 BMW R65 - "Seven"
Nick Makwell is offline   Reply With Quote
Times are GMT -7.   It's 06:25 AM.
