Old 02-03-2009, 04:39 PM   #31
War Hammer
Evil Monkey
War Hammer's Avatar
Oddometer: 351
Originally Posted by Twinsteel
You need one of these; they've even available in a Calif. legal model:
http://www.kel-tec-cnc.com/su16b.htm
That was actually a suggestion that I had in mind. Look into getting a folding or collapsible rifle in whatever caliber will work for your needs. My AK-47 with a folding stock fits very nicely in a tennis racket bag. Not only is it easy to carry, but it doesn't telegraph to everyone that it's a rifle and you should try to steal it. I can carry it off or on the bike with our drawing attention, so I don't have to try to figure a way to secure it when I walk into a gas station to buy a Coke.
War Hammer is offline   Reply With Quote
Old 02-03-2009, 05:29 PM   #32
Paradox Pete
Oddometer: 62
Scabbards and weapons....
Some solutions arrived at the hard way...
Horses or bikes, pretty much the same....Vertical carry, or butt fwd. carry is going to be regrtetted sooner or later.
Diagonal, muzzle fwd. and low, under your ankle if possible and butt level with underside of rear rack works.
THe shorter the rifle/shotgun the more conveniant to carry.
A 16" barrled NEF rifle is about the most conveniant rifle you can get for a scabbard carry other than than an even smaller frame similar length rifle. (Uberti "Baby" rolling block in .22 rimfire or .357 cut-down to 16" and with hte buttstock skeletonized is no heavier than a walkign stick...Sweet! :-)
Shotguns must have 18" barrel in the U.S. and rifles 16".
Canada requires longer by 2" barrels on both.
Shotgun wiht under 20 to 22" barrel will have alot of muzzle flash.
Bolt actions are longer by nature of their longer recieviers than single shots or shorter pistol cal. lever actions.
If you are willing to limit yourself to a SHORT rifle/shotgun , and a singleshot or SxS or O/U double barrel, you are going to be able find more choices on where to mount.
Another option is folding stocks like my BUtler Creek folder that has my Lothar Walther barreled 16" fluted HB 10-22 bedded into it with an added screw thru the forend into the barrel.
With stock folded and slung diagonally across my back it has surivived a couple wrecks w/O a ding. (Less than can be said for the rider....)
This is a comfortable "carry" and you could have a short zip-case over the weapon to keep dust out and so as to NOT scare the hoplophobes to where they sic the law on you for "intimidation".
Just DON'T carry with loaded magazine in the weapon unless your state specifically allows it.
A concealed carry permit is ONLY for a PISTOL in most states.
I have quiet exhausts on my machines, and a legally registered suppressor to mount on my 10-22.
(People don't make complaints about what they DON'T hear.)
Paradox Pete
Paradox Pete is offline   Reply With Quote
Old 08-11-2010, 05:16 PM   #33
Observer762
Oddometer: 1
I have been looking for a real rack to mount a 10.5" AR to my KLR650 (legal in my state). I haven't had much luck finding one. If I could find a locking M4 rack, I could mod it to go on the KLR. Any ideas?
Observer762 is offline   Reply With Quote
Old 08-12-2010, 06:42 AM   #34
Mac
Mac's Avatar
Oddometer: 2,153
http://www.kolpinpowersports.com/pro...-brackets.html
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is offline   Reply With Quote
Old 08-09-2011, 03:56 PM   #35
GillaFunk
I use profanities
GillaFunk's Avatar
Oddometer: 4,158
This looks doable with a bracked fabricated for the back of the DR:
http://www.santacruzgunlocks.com/set...lete916-5.html
EVERYTHING I need to know I learned from Porn
2011 Gear-Up; "سميرة" (Samira)
2013 DR800; "The Dirty-Hooker Too"
2007 FJR1300; "Sally Jupiter"
2003 1150GSA; the 2 Wheeled Submarine
GillaFunk is offline   Reply With Quote
Old 08-10-2011, 08:18 AM   #36
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,224
Here's how I did it. The Kolpin is mounted to the Gobi rack in two places, and is very secure.
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 08-10-2011, 10:41 AM   #37
GillaFunk
I use profanities
GillaFunk's Avatar
Oddometer: 4,158
Not bad, not bad. I'd just like to have a simple rack on the back, not a big case/tube hooya.
Sumping a little like this:
Old 01-22-2013, 06:30 PM   #38
VT-OregonTransplant
VT-OregonTransplant's Avatar
Oddometer: 28
Motorcycle rifle holster
I would check out this website.
seems like you could convert some of there holsters to fit on the front fork of a bike.
i have a 3030 Henry lever action i am gonna put on my DR650...
https://oldtradingpost.com/old-west-store/
Good luck with your gun rights everyone!
VT-OregonTransplant is offline   Reply With Quote
Old 01-22-2013, 07:06 PM   #39
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Kolpin rifle case on DR
Here's a picture of my DR with a Kolpin rifle case bolted on the side. Used the rear footpeg bolts and grab rail bolt to mount the thing.
It's been on lots of long trips over several years.
Dave
smilin jack is offline   Reply With Quote
Times are GMT -7.   It's 06:00 PM.
