Old 07-31-2006, 06:34 PM   #1
309 OP
Special Purpose
309's Avatar
Oddometer: 5,360
Spoked Wheel Maintenance
So I've got a loose spoke on the front wheel, which reminded me that I need to learn about spoke maintenance. Coming from street bikes, I never gave this much thought.
If I remember right, I'm supposed to be tightening the spokes on one side of the hub uniformly, then doing the other side. That's about all I remember...
Anybody care to give a lesson?
309 is offline   Reply With Quote
Old 07-31-2006, 07:46 PM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Assuming your wheel is true, and this isn't going to become a "how to true a wheel" lesson... you begin by putting one drop of light penetrating oil at each spoke/nipple junction. Then you wait a few hours. Have a beer... or, maybe not.
Why oil? Because I don't know how corroded and/or old your wheels are, and a drop of oil goes a long way towards making the nipple easier to turn and the torque a little easier to feel.
  • Get the wheel off the ground and locate the valve stem… the valve stem is your “pass point”
  • Place a good fitting spoke wrench on either spoke nipple nearest the valve stem and tighten it no more than 1/8th of a turn. How did it feel?
Typical spoke torque is around 45 to 60 inch pounds, or about 4-5 ft. lbs. In other words, not much.
  • Now... assuming you have a conventional wheel with 36 spokes, count the first spoke you touched as number 1.
  • Now bypass two spokes in which ever direction you’d like to rotate the wheel, and lay the wrench on the 4th spoke... apply pressure to that nipple using the one prior as a point of reference.
  • Then bypass the next two spokes and repeat the process.
The idea here is to go around the wheel 3 times, giving 12 spokes per turn a “snuggie”.
Or, you can go around 4 times giving 9 spokes a little push. When you've gone around enough times; you've laid a wrench on all the spokes... the wheel should still be true and all the spokes fairly evenly tightened.
If you want to, use a felt pen to mark each spoke as you do it... they all kinda look the same and it's easy to loose track of where you've already been.
At each spoke, when you lay the wrench on it you will feel a degree of resistance. The idea is that all the spokes should have the same feel of resistance when done. When you run into the "loose spoke" bring the tension up on it so that it is similar to the others you've done.
Think in terms of an average tension rather than a high or low tension.
Better to sneak up on a spoke than to arbitrarily turn it... even 1/2 turn, unless you actually know what your doing.
If you encounter a spoke that seems unusually tight, back it off a ¼ turn and re-tighten it… again, trying to duplicate the average torque previously encountered.
Wheel service for someone who's never done it before can be very ah... stressful. You think you're going to screw something up.
If you don't over-torque anything, and you only tighten spokes based on what you feel instead of the fractions of turns, you'll be fine.
Remember, if your not sure, less is better than too much.
This is why there's a good market in spoke torque wrenches. Not for the guy that knows how to lace and true his own wheels, but for the guy that doesn't.
A pro wheel guy probably owns a torque spoke wrench… and very seldom uses it. He (or she) has developed a feel that is, in most cases, a better gauge of torque than the wrench.
Corrosion can give the misleading impression that your spokes are tight when they are not… only a trained hand can “feel” that.
Bla bla bla.
Best ‘O luck,
C
creeper screwed with this post 07-31-2006 at 08:11 PM Reason: There was the sentence I didn't like much. What do you want for a 5 minute write-up... Shakespeare?
creeper is offline   Reply With Quote
Old 07-31-2006, 08:11 PM   #3
Django Loco
Django Loco's Avatar
Oddometer: 3,785
Wow Creep, you musta worked in a bicycle shop at some point, no?
I use mostly SOUND and FEEL to adjust my spokes.
Take your spoke wrench or "other" device and go round the wheel
and tap each spoke. They should play like a Zylophone if all adusted
correctly. The "tone" should be close but will not really change because
the spoke length is always the same. But a "tone" means your in the ball
park. A rattle or thud means that spoke is loose. feel it. Its loose, right?
Tighten until you've got a tone...no more.
Tighten it up, but not too much. You don't want to throw the wheel out
of line. Hard ridden dirt bikes will develop loose spokes from time to time.
No big deal. Most Japanese wheels require very minimal and infrequent
adjustment in my experience. I like Creepers oil idea. Keep it off the disc
and pads though. Could oiled spokes slip more with use?
Django Loco is offline   Reply With Quote
Old 07-31-2006, 08:21 PM   #4
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
I hesitate using the "tone" method with a wheel service "virgin" for a few reasons.
  • One, they may be tone deaf.
  • Two, if the hub is conical, or otherwise has multiple lengths of spokes, the tone will not be the same from spoke to spoke.
  • Three, virgins will start to "chase" the tone and loose track of what's been tightened and what hasn't. If they aren't careful, they can "chase" a wheel right out of true.
  • Four... I can't remember. I'm old, what can I say.
Loco my man... Think in terms of a first timer. Uncomplicated and, more importantly, systematic is a good thing when you're already a little apprehensive about the job in the first place.
Laters,
C
Old 07-31-2006, 08:28 PM   #5
309 OP
Special Purpose
309's Avatar
Oddometer: 5,360
Thanks fellas, that's just what I was after.
Old 07-31-2006, 10:02 PM   #6
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,843
Nice post (it's already in the index ),
Considering the above Caste, what do you think of spoke torque wrenches? Meaning besides the expense, what do you think of their up and downsides? Seems like they would be a good idea, but my reading of wheel tuner-speak leads me to believe there is an art to it - and science can interfere with artistry.
Here are some that came up in a quickie search:
http://www.ftmbiz.com/mx_excel_spoke_wrench.html
Fasstco
RK
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 07-31-2006, 10:29 PM   #7
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Fasstco
RK
Hey Meat,
I think they are fine to use, as long as the user realizes that the cleaner and better lubed the spoke/nipple threads are, the more accurate the wrench will be.
56 in.lbs. can be 56 in.lbs. of actual torque value applied spoke tension... or it can be 18 in.lbs. of torque and 38 in.lbs. of corrosion, or thread damage induced resistance.
This is why professional wheel builders will use oil, grease or "spoke thread lube" when they build a wheel... to get a smooth, true feel.
On an assembled wheel, for the home maintenance guy who wants to really do it right but doesn't have years of wheel truing experience under his belt, a dab of penetrating oil, maybe turning the nipples in and out a bit to get the oil into the threads... then use the wrench... that would be the most accurate use of a spoke torque wrench I think.
Even better if you do your own tire changes... 'cause then you can get really sloppy with the spoke lube and not worry about the excess getting into the wheel, tire and tube "sealed area".
C
Old 08-01-2006, 06:32 AM   #8
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,088
and a few more pointers,,
great info Creeper and Django loco,,,,,
1,,,when it comes to tone,,every 4th spoke ie all the spokes going in the same rotation should definitely sound the same
2,,,if ya hear a change in pitch,,make sure the spokes aren't touching each other,,which they often do
3,,,no mention was made of using an indicator of sorts,,,ie a means of referencing your latitudinal and longtitudinal run-out and hence knowing if you are actually truing your wheel ,,,,getting closer or further away from your detination,,,,otherwise IMHO you are just blindly tightening spokes
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 08-01-2006, 06:56 AM   #9
Odysseus
Stoic Philosopher
Odysseus's Avatar
Oddometer: 4,154
Is this a great resource or what? 309 asks a question about spoked wheel maintenance and gets three GREAT responses!
BTW from what I have been told, IF you are going to get a spoke torque wrench, the one from Fasstco is one to have.
Keep faith with our American heros:
Wounded Warrior Project www.woundedwarriorproject.org
Special Operations Warrior Foundation
www.specialops.org/
Odysseus is offline   Reply With Quote
Old 08-02-2006, 12:43 AM   #10
bmwktmbill
Traveler
Oddometer: 4,009
Creeper,
Nice post. I have never really had a good idea of how to deal with a wheel tune up. I appreciate your explaination for the technique.
Bill in Tomahawk, WI.
bmwktmbill is offline   Reply With Quote
Old 08-02-2006, 03:52 AM   #11
DirtRiderwjc2000
DirtRiderwjc2000's Avatar
Oddometer: 515
+1 for the fasstco wrench, pricey but worth it. I bought for my Honda CRF 450, I got the entire kit, so I have the correct size for all my bikes. Best tool I have ever bought.
09 BMW R1200GSA
11 KTM 300XC
06 BMW F650GS SOLD
08 Husky TE 450 SOLD
03 BMW K1200RS SOLD
DirtRiderwjc2000 is offline   Reply With Quote
Old 04-22-2009, 11:40 PM   #12
Tseta
Lost
Tseta's Avatar
Oddometer: 654
Spoke dimensions
Hello,
Once again, sorry for digging up an ancient thread, but...
I've been reading up on KTM spoked wheels and the horror stories associated with them. In anticipation of spoke failure, I've been planning to zip-tie the spokes together and keep a close eye on them. I've also been considering carrying some spare spokes with me on longer trips.
How should I interpret the KTM parts fiche listing for the front and rear wheel spokes for my 2003 640 Adventure? The fiche lists the rear wheel spokes as:
546.10.471.000 SPEICHE M5X223-10G 18“ SPOKE M5X223-10G 18“
and
503.10.071.197 SPEICHE M5X197-10G 18“ DDE SPOKE M5X197-10G 18“ DDE
The spoke nipples as:
583.09.072.000 SPEICHENNIPPEL M5-TA (8X21MM) SPOKE NIPPLE M5-TA (8X21MM)
For the front:
503.09.071.230 SPEICHE M4,5X230-15G 21“ DDE SPOKE M4,5X230-15G 21“ DDE
And the nipples:
503.09.072.000 SPEICHENNIPPEL M4,5X0,75 8X21 SPOKE NIPPLE M4,5X0,75 8X21
The reason I am asking is because the cost for these parts is stupidly expensive from my local dealer. There is a custom wheel manufacturer who could make me some spokes for much less, but he would need some more information about the spokes before making them. I don't trust my ability to measure the assembled spokes and I really don't wish to dissassemble the wheel and send some some spokes as samples.
I've figured out so far that the part descriptions highlighted in orange have probably something to do with the diameter and the (total) length of the spoke. At least one additional dimension, mainly the angle of the bend is required. My gut feeling says that the part highlighted in red could be something to do with that angle (as G could be short for Grad - angle in german...).
So, anybody have any insight into the aforementioned issue?
Cheers,
Tseta
Tseta is offline   Reply With Quote
Old 04-23-2009, 12:08 AM   #13
MaverickAus
MaverickAus's Avatar
Oddometer: 938
Send a message via MSN to MaverickAus
I am no expert, I think the M5 and M4 bit is to do with the thread, the 223, 197 and 230 is the length of the spoke in mm and the 10G and 15G is the gauge of the wire.
I may be wrong
1999 KDX 200
1996 KLR 250
2006 KLX 250 R
2006 CT110X
2012 Versys
MaverickAus is offline   Reply With Quote
Old 04-23-2009, 09:53 AM   #14
meat popsicle
Ignostic
Oddometer: 13,843
Tseta,
if you don't get a good answer in the thread send the same question to "Woody's Wheel Works" (who posted earlier in the thread). He builds KTM wheels and will know the specs you need for your local builder.
Old 04-23-2009, 10:00 AM   #15
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,434
and if you want to drop it off at the pro
http://www.woodyswheelworks.com/
pit posse has the best deal for the home user:
http://www.pitposse.com/potowrkit.html
i would also buy this as your initial spoke thread prepping tool.
http://www.pitposse.com/moprospwr.html
can't imagine using a torque wrench to lossen and tighten the nipple to prepare the thread is good for the tool.
i like the slip over the nipple box design because all 4 corners are used. this is important when your intially cracking corroded nipples so you don't strip anything.
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
eakins screwed with this post 04-23-2009 at 10:20 AM
Times are GMT -7.   It's 10:36 PM.
