Old 08-02-2006, 09:40 AM   #1
AndyB OP
Lonely Traveler
Oddometer: 173
02 640A Leakin' Oil
Hey guys the beast has sprung a leak damnit. Leaking where the shift shaft comes thru the Kickstart shaft. looking in the manuel, appears #6,O ring(s) ist quanity as 3 of them, is probably the culprit. puuled the shifter off and the only thing i find is the V seal. So i assume i gotta pull the shaft out from the other side? how big a pain in the ass is this gonna be? gotta pull the whole clutch basket too i assume to get to the rascal?...Anything i should be weary of while disasymbly/reasymbly???
any words o wisdom Mr. Creeper?
thanks in advance......,AndyB
oh by the way, Vintage Days at Mid O. was great!
AndyB is offline   Reply With Quote
Old 08-02-2006, 05:24 PM   #2
AndyB OP
Lonely Traveler
Oddometer: 173
Some Guidence Please....Creeper?
well i was hoping for a little info here. the leak ain't bad but in a cpl rides has got worse. went from just a little pearl on bottom side of kicker. but now the more i shift the more it leaks. "Duh"... was hoping to hear from someone who's had to make this repair or someone who gets into these motors. the manuel unclear just as to where these O rings are located. like i said earlier, nothing behind shifter except the V seal????? thanks again, A
Old 08-02-2006, 06:12 PM   #3
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
You may be in deep doo doo Andy.... but you get one "last chance" to find out.
The "V-seal" is the only seal that is easily accessible from outside the engine... everything else (except maybe the kicker shaft seal) requires splitting the cases.
There is a seal... #9 in the diagram that is pressed into the end of the kicker shaft that you may be able to get out... but if you scar up one or both of the shafts doing it, you are screw'd for sure.
#9 54632090000 SEAL RING DH/GR 12x19x3
This is your last chance.
Pull the shifter off and pull the V-seal off.
Now, spray the #9 seal preferably with silicone spray or some other light oil that is kind to rubber parts.
The idea here is to clean, flush out and clear the area around the kicker shaft seal, shafts and face of the kicker.
Spray from the seal area out, to flush out the seal lip and to flush away grit from the seal.
All clean and lubed up?
You can see the greenish blue colored shift shaft seal? Good.
The seal looks to be in good shape? More gooder yet still.
Now... either buy a new V-seal or clean the old one, again with a rubber friendly spray product. I like silicone because it tends to restore rubber seals that are a bit dry from age.
Now that everything is clean, grit free and well lubed, put it all back together and go for a ride.
Did it stop leaking? Yes?
Is it still leaking? Yes? You are screwed and will have to split the cases.
Told ya'... last chance.
Best 'O luck,
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 08-02-2006, 09:43 PM   #4
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,237
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 08-02-2006, 09:48 PM   #5
motowest
Two-wheeled Adventurer
motowest's Avatar
Oddometer: 1,298
ditto what popsicle said...
motowest is offline   Reply With Quote
Old 09-04-2006, 09:10 PM   #6
meat popsicle
Ignostic
Oddometer: 14,237
Well???
I have a vested interest in your experiences... I have not torn into it. I have just cleaned up the area to watch for more leaking. I had forgotten about this thread, and Creeper brought it back to my attention; thanks mang
So in my preliminary look at the diagram and parts list I noticed the following two seals:
#17
Item #: 0760223270
SHAFT SEAL RING 22X32X7 BSL
Quanity On Diagram: 1
Cost Each: $7.25
Item #: 58038022000
CU-SEAL RING DIN7603-12X18X1,5
Cost Each: $1.50
I am guessing Creeper called #17 the "kicker shaft seal", but I will have to look again at the parts list to find the V seal, et al. Not sure of the importance of #7. I'd like to know what things are before I start in there.
Old 09-08-2006, 04:43 PM   #7
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
Oh joy! I think I have this issue now too.
BlitzBike
BlitzBike is offline   Reply With Quote
Old 09-08-2006, 04:49 PM   #8
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
It's all in your head.
Mine dribbled a bit. Cleaning the V-seal and all the junk off the shift shaft seal put an end to it.
I think... you'd have to have fallen hard on the shifter, or have a old or high mile bike to have that shift shaft (9) seal fail.
Or figure out a way to pack a bunch of gritty muck into it.
So... how's tricks?
Old 09-08-2006, 10:56 PM   #9
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
Same here. I looked a the pic first (cause I'm simple ) and saw "THIS IS YOUR LAST CHANCE ".
i thought Creeper had gone postal at Andy
But thankfully he hasn't
But I suppose the day isn't over yet !
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is offline   Reply With Quote
Old 09-08-2006, 11:01 PM   #10
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
We haven't heard from AndyB since my first post in this thread... hope I didn't scare him, it wasn't my intention.
What I meant was it was his last and only chance before splitting the cases.
So... how's tricks?
Old 09-08-2006, 11:09 PM   #11
meat popsicle
Ignostic
Oddometer: 14,237
The KOD in retirement? Spanish Riveria? :KOD
Old 09-08-2006, 11:10 PM   #12
rjf
rjf's Avatar
Oddometer: 4,376
We haven't heard from AndyB since my first post in this thread... hope I didn't scare him, it wasn't my intention. Well you did mention "split the cases"
Yeah as soon as I read the post I knew that, it's just the first words I saw were "this is your last chance".
I don't think the post scared him off.
Your avatar on the other hand may have
Old 09-09-2006, 01:23 PM   #13
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
Which part is the so called "V-seal"?
BlitzBike
Old 09-09-2006, 02:00 PM   #14
AndyB OP
Lonely Traveler
Oddometer: 173
I'm Not Scaaaaaarrre-d!
hey guys just gettin back on here (uh... sum trying circumstances have averted my attention from a a leaky bike, So i Apologise for my absence in all this) and Wow! alot of interested folks and concern here. ...well, stayed tuned i have sum Q-uestions ? that'll be addressed later (soon).... going for a ride tomorrow, and will be in touch.
thanks for the interests though, 'cause if i gotta split the cases (damnit!) i'm gonna need sum support.., AndyB
Old 09-09-2006, 02:25 PM   #15
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
It's the odd shaped "seal", #17 between the shifter and the kicker. It' there to keep schmutz out of the "real" seal... #9.
If a bit of schmutz gets thru and into the conventional #9 seal... that's when you spring a leak.
You may be able to clean it out and stop (or reduce) the leak... or it may be too far gone to do any good.
With a dedicated tool, you might be able to get the #9 seal out of the kicker shaft without damaging either one of the shafts. It's something I've been thinking about since I first posted the infamous "last chance" line.
I'm working on a tool shape that one could grind or file into a small, high quality screwdriver to turn it into a seal puller; that would be what I'd try to do if mine was leaking like a sieve... at least before I split the cases.
So... how's tricks?
Times are GMT -7.   It's 07:54 AM.
