Old 04-14-2010, 04:53 AM   #31
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,890
Originally Posted by SMURF
@ seikkailu, did you manage do change the seal behind the shifter on that small shaft,
how did you put a new one ?
I have R&R'd both of the seals.
when installing the seal on the case, go slow, do not get in a rush.
if ya got a deep well socket, that works. If not something similar.
I aint tellin' ya how I did mine, you'll prolly fook yers up doin' it that way
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 06-30-2010, 04:17 PM   #32
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,607
Question Help!
Is this thread still alive? Anybody here that can help?
Need the special tools to do the job right!
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 07-01-2010, 03:22 PM   #33
Carl_Mega
Carl_Mega's Avatar
Oddometer: 145
Was going to resurrect this thread too (since it showed up in the Adventure Owners thread)...Anyway, I don't think I can help you since I'm likely in the same boat and this will be my first repair attempt.
I know my V seal is a touch mangled. Earlier this year, I had a terrible time taking the shift lever off and the V seal was a bit of a causality (had a slight leak even back then). Currently, it barely leaks oil from this area but it does develop a few drips here and there. It sounds like you may be able literally stop the bleeding and prevent further damage to the #9 seal, so I'm glad to have read this thread and possibly save myself a larger problem. Off I go to get a new V seal and silicon spray.
Doesn't really help you but I will post my results on the "last chance" clean-up!
I’ll end with a question: Has anyone actually developed a leak that was catastrophic and couldn't be addressed without splitting the cases?
CarlMega on Twitter
2006 KTM 300 XC-W
2004 KTM SXC 625
Carl_Mega is offline   Reply With Quote
Old 07-01-2010, 07:08 PM   #34
mxchamp
Registered Lurker
mxchamp's Avatar
Oddometer: 1,607
Cool2 Oil leak
I have a brand new V seal installed. Going to take the bike to the KTM dealer Tuesday or Wednesday.
Will let you know how it turns out.
Ride safe!!!!
2014 KTM 690 Enduro
Old 07-28-2010, 07:33 AM   #35
IamTRooPeR
TRooPER from Belgium
IamTRooPeR's Avatar
Oddometer: 132
my mechanic did the "hard work", he has a custom made special tool and it only takes 5 minutes for him. He knows the LC4 engine inside-out.
He told me the orginial V-shaft was put on the wrong way, and he said , he saw this often, yes even from the factory with a new bike.
IamTRooPeR is offline   Reply With Quote
Old 07-28-2010, 10:57 AM   #36
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
Sorry for the long absence.
Was busy renovating the old house.
The leak is quite comon and usually a reason to split the Engine case.
But I usually just stuff two new o-rings in the gap and use a new V-Seal.
Is holding on my Rally now for 20K.
10K more than the original solution.
Takes 5 minutes and can be done by even the clumsiest of BMW riders
cu
Stefan
KTM Lc4 660 Rally MY98 pre e-start; KTM EXC450 MY14 Torque Rally Conversion; KTM EXC450 MY04 HDB Rally Light; Honda XRV750 RD04 MY91 AfricaTwin -for Sale-
Happe is offline   Reply With Quote
Old 03-14-2011, 03:57 PM   #37
IamTRooPeR
IamTRooPeR's Avatar
Oddometer: 132
i have been riding more than 10k with the shaft seal. no problems found.
last work done: FCR installed, valves checked,
been riding for 500km, everything OK and good power with the new FCR.
today, riding with 130kmh and suddenly: blocked rear wheel in fifth gear.
I hurried for the clutch so I got safe to the side of the highway.
Tried to start the engine again and I heard some very bad noises from the top engine (like valves? waterpump? ...)
I took the bike home in my van, and checked some things:
- a little less coolant than normal
- spark plug looks good (light brown)
- took the spark plug out , but I couldnt turn the rear wheel by hand ???
- I saw some little oil on the seal of the kickstarter
Is this a blocked transmission case?
I think this might look bad.
What is the consequence of oil on the kickstarter?
Old 04-06-2015, 08:20 PM   #38
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 913
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Times are GMT -7.   It's 12:57 PM.
