Old 08-23-2007, 10:10 PM   #1501
Hoder
Card carrying greeny
Hoder's Avatar
Oddometer: 1,019
Originally Posted by jambie
the first thing I'm gonna do is replace the stock headlight bulb with....What? I know I read it here somewhere that there's a higher wattage, direct replacement bulb, but a search turned up no luck.
MR_DNALLOH (what ever happened to that guy?) replaced his bulb with a 55 watt and it started to melt the lense so he took it back out. The SM comes with a 55watt halogen. I tried several times to get the SM pigtail with the H4 plug but had no luck & had to splice the one on that came with my UFO Plast halogen. Borrow a hundred bucks if you don't have it and get the BD, UFO Plast or try to find the SM light.
http://www.ufoplast.com/en/product-details/mx-enduro/headlights/PF01691
See my pics
Dave:
The 610 really makes me want to ride like a punk everywhere I go.
bikefrk:
You now understand supermoto.
Your training is complete.
Hoder is offline   Reply With Quote
Old 08-24-2007, 06:57 AM   #1502
flan8tive
Flea Tibet!
flan8tive's Avatar
Oddometer: 2,188
Husky For Sale
This thread has been such a great source of information...I am very excited about the 08 EFI model coming out. Has anyone heard when the 610 will be here?
07 950SE Sold. Not Forgotten...
07 TE510 Sold.
80 Z50R
flan8tive is offline   Reply With Quote
Old 08-24-2007, 07:56 AM   #1503
ra2bach
drive-by poster
ra2bach's Avatar
Oddometer: 4,814
Hi Guys, another simple question from a simple mind...
I ordered two Iridium plugs for my TE and when they arrived, they were Denso IU24 - 5362, not the NGK CR8EIX. Does anyone know about this?
ra2bach
"having dreams to look forward to slows time..."
-- Freeflow
ra2bach is offline   Reply With Quote
Old 08-24-2007, 08:11 AM   #1504
husky123
Oddometer: 1,454
Flan,
Probably around Nov/Dec time frame.
ps. Cinderella fan?
husky123 is offline   Reply With Quote
Old 08-24-2007, 10:01 AM   #1505
jambie
Oddometer: 290
I ordered a UFO Ray Halogen today. Does anyone know if the replacement headlights use the stock plug that goes into the stock headlight, or do you have to wire a different one in? Hopefully it's just unplug the stocker and plug in the UFO (or Baja or...)
Cheers,
Tom
jambie is offline   Reply With Quote
Old 08-24-2007, 10:28 AM   #1506
noman
Oddometer: 867
i replaced my stock headlight bulb with a 100w/80 H4 - no problems whatsoever. did a lot of checking first and posted results here. try a search under my name, have only posted a dozen or so times. don't know about doing the same change on an '07 tho. i'd highly recommend the upgrade if possible - 4 bikers doa over this past summer from folks turning left.
bobp
1976 r75/6 -- mine since 1980, thx lloyd!
1985 vf500f -- v4, 6 spd, 16v, triple discs, water cooled
1997 900ss -- full sp spec
noman is offline   Reply With Quote
Old 08-24-2007, 05:30 PM   #1507
jambie
Oddometer: 290
Well, something else I've noticed upon closer inspection: While looking at which hoses I can remove from the charcoal canister (which ones come off completely, and which get teed to which?) I noticed that the two-wired electrical connector coming from the petcock is not connected to anything, and there doesn't appear to be a coresponding connector anywhere else that might attach. I'll try and and get a pic shortly...
Any ideas?
Cheers,
Tom
Old 08-24-2007, 05:36 PM   #1508
aalegado
Team Gear Whore
aalegado's Avatar
Oddometer: 477
I'm a new rider (BMW F650GS) but am already thinking about the second bike...really like the TE450 and the SMR450. Can't choose between them...I'd like a competent street-legal dirt machine but I also like the Supermoto style.
I'm in no rush...probably can't swing another bike for close to a year but you never know...
2009 Aprilia SL 750 Shiver / 2013 Piaggio BV 350 "Beverly"
aalegado is offline   Reply With Quote
Old 08-24-2007, 05:49 PM   #1509
jambie
Oddometer: 290
Okay, A,B, and C are hoses to and from the charcoal canister, and D is the unconnected connector.
Talk amongst yourselves...
Tom
jambie screwed with this post 02-12-2009 at 10:04 PM
Old 08-24-2007, 09:15 PM   #1510
Jakester
Homme du Nord
Jakester's Avatar
Oddometer: 34
[quote=jambie]Okay, A,B, and C are hoses to and from the charcoal canister, and D is the unconnected connector.
D, from the petcock has a connector at the wiring harness under the fuel tank. Remove the tank, you will find a matching connector. It's the low fuel sending switch connection. While you are at it, epoxy the blue wire coming out of the petcock. If it's not leaking yet, it will be soon. It's the only problem I've had with my 07.
You can safely remove all the emissions stuff, just be sure to block off the vacuum port at the intake manifold.
You may want to go back and read through the previous posts, there are people like Dan (buffalodan) who know way more than I do about this machine.
Jakester is offline   Reply With Quote
Old 08-24-2007, 09:19 PM   #1511
Jakester
Homme du Nord
Jakester's Avatar
Oddometer: 34
Originally Posted by mjf
The one I just received was the one in the crate . $6200.00 plus shipping. That saved me at least $1400.00 over buying one local. Normally I would like to support my local dealer, but $1400.00 was to good to turn down.
mjf, you got fast55's bike! Any problems? Mine had a fuel leak at the petcock.
Old 08-24-2007, 10:30 PM   #1512
Hoder
Hoder's Avatar
Oddometer: 1,019
The stock headlight has 3 separate mini connectors, the halogen uses a 3-prong plug like in your car. You'll have to splice the connector that comes with the new light, try to find a SM pigtail or make your own.
See my pics
Dave:
bikefrk:
Old 08-24-2007, 11:18 PM   #1513
Fred
Fred's Avatar
Oddometer: 1,051
I just rode home from the pub and allthough the headlight doesn't compare to the beams on my Speed Triple, I really don't find the stock h lamp that bad.
Maybe I just have good night vision?
Fred is offline   Reply With Quote
Old 08-25-2007, 12:01 AM   #1514
irnbru
irnbru's Avatar
Oddometer: 65
My dealer removed my emissions lines and I just noticed the vacuum line that should be plugged, is not.
Is this a big issue? Should I ensure it is plugged before riding again?
Cheers.
irnbru is offline   Reply With Quote
Old 08-25-2007, 06:49 AM   #1515
motometal
i like motorcycles
motometal's Avatar
Oddometer: 3,648
it will suck in air and make it run lean, especially at idle. If you were riding in dust, it would suck in that too. Go to the auto parts store and buy a container of plugs.
motometal is online now   Reply With Quote
Times are GMT -7.   It's 07:45 AM.
