Old 06-06-2010, 10:24 AM   #17146
tagalong
tagalong's Avatar
Oddometer: 465
Originally Posted by DeBandi
I'm replacing my front disk rotor and have encountered a problem.
Two of the screws are so tight, they have stripped, and I can't get them out.
The allen head on the screws have rounded off.
-I soaked them with penetrating oil overnight.
-I also tried heating them with a torch.
No luck.
Any other suggestions?
Thanks guys....
An old professional approach to removing allens with rounded out heads is to take a Torx socket just a hair larger and drive it in with a hammer. This gives more surface area to grip, and a more positive grip. Of course, you need to get them freed up first.
08 950 SE
99 KLR 650
93 ST1100
tagalong is offline   Reply With Quote
Old 06-06-2010, 10:48 AM   #17147
Kingsqueak
Wannabe
Kingsqueak's Avatar
Oddometer: 820
Originally Posted by xymotic
I haven't heard of anyone having accuracy issues. Mine was Dead on, balls accurate.
As for reserve, careful with that. I got 17-20 miles on reserve. Not a lot when you are in the stix. And I think someone posted an ad saying 60 MPG. Um, not even close unless you are a rider that is constantly getting tailgated I get about 45. I've tried to drive on a whole tank without being a hooligan just to see what the mileage is capable of, but so far I have not actually been able to do that.
Good info, thanks again. I ride like a snail (generally 5 over) most of the time, the fines are nuts here and I had a few tens of thousands of them back in my 20's. Also, generally speaking the local cops really hate bikes. I haven't had a point violation (speeding etc) in over 20yrs and rarely get stopped. Until I got a bike.
They stop bikers (non Harley of course) here just for kicks. "I couldn't see your inspection sticker". I got pulled over at least once a quarter when I was last riding...for no reason. Gotta love steaming to death in gear while they noodle around entertaining themselves.
My general riding is around suburbia, even 'off road' here so I think I should be pretty o.k. with the small tank on this thing for a while.
2008 TE610 - "Jumpy"
2001 KLR650 - retired "Lumpy"
1987 Honda Saber - destroyed "Crashy"
Kingsqueak is offline   Reply With Quote
Old 06-06-2010, 11:05 AM   #17148
Kilomph
Oddometer: 22
Question
Is the 2000 Te-610 any good? I've been considering a couple local 525 exc but the Te-610 seems like it'd be a slightly better DS.
Kilomph is offline   Reply With Quote
Old 06-06-2010, 11:23 AM   #17149
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,095
No luck.
Thanks guys....
One option, if you have access to a mig or tig. get a nut with an inside diameter just a wee bit smaller than the head. Place over top, weld inside the nut to the head, let it cool, then just use a wrench to remove.
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is offline   Reply With Quote
Old 06-06-2010, 03:49 PM   #17150
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,452
Since you are going to replace the disc anyway just grind away the bolt and disc if all else above fails.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 06-06-2010, 04:31 PM   #17151
goincb89
Oddometer: 22
hey so this is frank.
goincb89 is offline   Reply With Quote
Old 06-06-2010, 04:47 PM   #17152
goincb89
Oddometer: 22
i picked him up in november and cleaned it up and put a fresh timing chain on it.
hes named frank for a reason its got a 95 frame a 2000 te kick only engine, and 98 plastics.
its been a blast to ride but im not sure if everything is quite right cause its lots of low end but the power really signs off after 6k, its got a dellorto carb with a 174 main and 52 pilot and one of the uptite full perforamce exhaust on it and a opened up airbox. im in central NJ and would really like to meet up with someone thats got a 610 to hop on and and give it a whirl since i have nothing to judge its power and performance against, also when i whip the throttle open it will hesitate backfire through the airbox and shoot a flame out the tailpipe.
valve were just adjusted and it is a 1-2 kick starter, idles good and otherwise the power delivery seems smooth
Old 06-06-2010, 10:19 PM   #17153
xymotic
xymotic's Avatar
Oddometer: 8,367
Well, I fired up the bike today after my cam chain change. It took a LONG time and after a small heart attack inducing backfire she fired right up and purrs.
Course I forgot to tighten the rad hose clamp under the tank, so once I got that sorted she seems to have survived the surgery.
I am having two issues though:
The Front Brake is rubbing the caliper a bit. And I have very little almost non existent force at the handle. I don't understand this because I didn't open the system at all. I kinda thought maybe the caliper would center itself on the rotor if I could get it to bite? Which would fix my rotor rubbing problem. Is that correct or did I do something off on the install?
Also, in the fiche, part #35, don't these actually go the other way? Out away from the wheel?
With the new forks and Bars, the brake line seems tight. Can anybody tell me the specs of the stock line? I want to ride the bike while I order a new one.
Also, I seem to have an oil leak in the right case. Do those gaskets go 'bad' for any particular reason? The case is tight, and the gasket seemed like it was in perfect order. I suppose I could have got dirt or something in there, but it seems strange. I also of put in $70 a gallon motorex, so I really don't wanna open the case if I can avoid it.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic screwed with this post 06-06-2010 at 10:49 PM
xymotic is offline   Reply With Quote
Old 06-07-2010, 01:24 AM   #17154
K7MDL
TE450, Jeep
Oddometer: 1,561
Clean the drain plug area well, and drain the oil into a clean pan and reuse it. Not that I have ever needed to do that :-).
Right side leak: I assume you checked the cover bolts are tightened fully and did not mis the one under/in front of the oil filter? Sometimes bits of the old gasket will stick on the metal and not mesh up right when the thing goes back together allowing oil to weep out, probably only when running if it is in the upper 2/3.
bars/brakes: When you had your bars off, teh master cyclinder likely was upside down for many days. You probably now have air in the line. Yo need to bleed the system. You can try to cheat if the air might be in the top portion only. Loosen the cyclinder hose banjo bolt and and push on your brake pads (open them) and catch the air and fluid that drips out. Others have put a strap on their brake handle to hold it open for days and let the air bubble to the top.
On my '07, the bushing/spacer (#35) goes between the bracket and the caliper to properly space the caliper over the rotor.
K7MDL is offline   Reply With Quote
Old 06-07-2010, 01:28 AM   #17155
K7MDL
TE450, Jeep
Oddometer: 1,561
Originally Posted by edeslaur
Anyone figure out how to make it so you can change views underway?
You have to make the speedo think it is at zero mph. There is a slight delay as it averages the pulses. The best way to do this is to use a switch or relay/Switch to open both side of the speedo sensor cable. The Husky Speedo thread has my experiment using diodes and a switch to ground the signals. Not good enough, at least not without lots of delay. Not worth the effort overall. My stock speedo started locking up so I just put a Trailtech Vapor on. Problem solved.
Old 06-07-2010, 01:52 AM   #17156
K7MDL
TE450, Jeep
Oddometer: 1,561
A little 2-day ride for the Blackdog DS ride
June 5-6 was the annual Blackdog Dual Sport Event in Hood River, Oregon. Got sun on Saturday, rain on Sunday. Some major slippery, greasy mud roads, mud holes, and loads of good riding. Got some single track in, but mostly forest roads and pavement connectors. Saturday was in Oregon, Sunday was on the Washington side of the Columbia River Gorge.
This is looking down on the orchards and town.
Mt Hood with a poser
Was too busy riding and trying to stay vertical to take many pictures. I only crashed once in a perfect slide through the mud and into a seamless stand up manuever. After that my gloves were too muddy to handle the camera, though the rain did eventually wash most of it off. The regional ride comments and pictures are here for those interested in this great event. http://www.advrider.com/forums/showt...566402&page=16
Sharp eyed folks might notice the new-to-me Highway Dirt Bikes submount, lower clamps, top clamp, and handguards now on my bike. They did their job well during my crash. I have a loaned-for-testing GPR tower mount designed for the '08-'09 TE610 with stock tank that looks like it will work with my '07 and IMS 5 gallon tank after a slight modification to remove about a 1/4" of material that sits down into tank ridges around the gas tank bolt. Will be working on that more this week. Once fit, I measure and order a Scotts damper with the correct arm. GPR makes a submount for teh TE610 also if you are not using the HDB system. I do not know if the GPR submount will work with a HDB top clamp. The GPR tower uses 2 standoffs on either side of the tank so it straddles the tank, with the tank bolt being the third leg. The HDB submount fits nicely with the Lynx dashboard. Other submount designs (GPR and Protect Eduro Concepts I believe) that are large blocks with the lower clamps (riders) machined integral to them are too deep and will interfere with the Lynx dashboard bend location.
The area in front of the tank bolt hole (to the left of the hole in the above picture) neeeds 1/4 shave off to seat within the tank ridges.
- Mike
K7MDL screwed with this post 06-07-2010 at 01:59 AM
Old 06-07-2010, 04:18 AM   #17157
Fizz
Fizz
Fizz's Avatar
Oddometer: 168
Rim Locks
On front\rear wheels, opposite the valve stem, there are little rubber 'thingies' where real metal rim locks should be. Is this just a plugged up hole for when you want to put rim locks in, or is it a new fandangled rim lock. For a bike in its class I would assume it comes with rim locks???? I am confused.
Thanx in advance
Fizz
Fizz is offline   Reply With Quote
Old 06-07-2010, 06:51 AM   #17158
BikeSDP
Reluctantly Crouched
BikeSDP's Avatar
Oddometer: 503
Thanx in advance
Fizz
Yes, it's a plug for that very purpose. Interestingly enough, my WR300 was delivered with front and rear rim locks, yet nothing on the 610.
BikeSDP is offline   Reply With Quote
Old 06-07-2010, 06:56 AM   #17159
jtemple
jtemple's Avatar
Oddometer: 574
Thanx in advance
Fizz
It's funny you should mention that. I just looked closer at the pics of my 630 and noticed there are no rim locks.
jtemple is offline   Reply With Quote
Old 06-07-2010, 06:59 AM   #17160
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,748
You would generally run lower tire pressures in your wr300, 10-14psi. The 610 would generally be higher, 16-22psi. I think that is enough pressure to not need the rim locks.
toddler is offline   Reply With Quote
Times are GMT -7.   It's 12:20 PM.
