Old 06-07-2010, 02:39 PM   #17176
xymotic
xymotic's Avatar
Oddometer: 8,367
Originally Posted by cbshaffer
I have a 2008 TE610 and would like to know if there is some way to make it less “twitchy” while cursing the interstate (around 70 MPH). It just seems a bit nervous and I was wondering if a steering dampener, or some other device, would calm it down some.
damper will mask a problem not fix it. Mine was downright scary with 908's on it. But it was the suspension setup that fixed it.
I'm at work and can't look at the brake, do I need dot 4 or 5 brake fluid?
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 06-07-2010, 02:52 PM   #17177
BikeSDP
Reluctantly Crouched
BikeSDP's Avatar
Oddometer: 497
It's DOT 4 (I checked on my 610 just now)
BikeSDP is offline   Reply With Quote
Old 06-07-2010, 03:04 PM   #17178
DeBandi
Exploring Alabama
DeBandi's Avatar
Oddometer: 3,100
Thanks guys.
I had the screws drilled out today.
Thanks again for all the help!
Explore / Dream / Discover
DeBandi
Visit ExploringAlabama.net
State Oval Decals Available
DeBandi is offline   Reply With Quote
Old 06-07-2010, 03:10 PM   #17179
lionsroaar
I meant to do that!!
lionsroaar's Avatar
Oddometer: 149
2009 TE610 fork seal leaking...
Has anyone else with a late model 610 had a fork seal leak? Mine is a 2009 with 850 miles on it. I went on a 150 mile dual sport ride yesterday and after parking the bike in the garage for a couple of house noticed a small puddle on the ground under the left fork...I'm pretty upset with the early failure but was thinking about sending the suspension to Les at LTR anyway...Any thoughts?
Sex is like pizza, even when it's bad it's still pretty good...
2009 Husky TE610
Up and over the Sierras to Bodie...
lionsroaar is offline   Reply With Quote
Old 06-07-2010, 03:19 PM   #17180
Fizz
Fizz
Fizz's Avatar
Oddometer: 168
I run a 14\45 sprocket combo on my 2006 TE610 (stock is 15\45). I want better torque for steeper hills and single track so am considering a 13\45 sprocket combination, and swap out the 13 and 14 depending on the riding I am doing - aggressive\less aggressive dirt.
Are there any problems with the 13\45 combination other than chain wear? ie wearing the swing arm rubber out etc.
Anyone run 13\45 sprocket combination for the dirt - what is your experience?
Thanx in advance
Fizz
Fizz is offline   Reply With Quote
Old 06-07-2010, 03:41 PM   #17181
edeslaur
San Diegan
edeslaur's Avatar
Oddometer: 445
Thanx in advance
Fizz
I ran a +10 tooth rear sprocket for the first 5,000 miles since that's what it came with when I bought it. Ran great, and pulled better up top than my buddy's stocker (same year).
It did eat the rear chain guide, being that much bigger than stock.
Now that I've gone back to stock gearing, top end speed is decreased.
Gas MPG remained surprisingly similar (maybe 1 or 2 better @ stock, maybe).
Performance-wise, I don't see a huge difference offroad once I get going, but then that's what the tranny's for. FWIW, I'm not a rocket, but then again I'm not slow.
For my next set of sprockets, I'm going to aim closer to the +10 combo I had I think.
YMMV
Eric D
06 Husqvarna TE610 - IMS 5 gal clear tank, heated grips, Alaska Leather sheepskin, Dirt Bagz, Leo Vince slip on, JD Jetting kit, Utah skid plate, Cycra barkbusters
08 BMW K1200S - It's freakin' awesome
Ride reports:
- 10 Mar Baja
- 08 Feb Baja
- 07 Aug West coast PDX->SAN
- More!
edeslaur is offline   Reply With Quote
Old 06-07-2010, 05:30 PM   #17182
jtemple
jtemple's Avatar
Oddometer: 572
YMMV
Wouldn't a bigger rear sprocket (especially +10) reduce top speed, not increase it? I would also think that 10 more teeth would make it pretty difficult to keep the front wheel down.
jtemple is offline   Reply With Quote
Old 06-07-2010, 06:32 PM   #17183
Hoder
Card carrying greeny
Hoder's Avatar
Oddometer: 1,019
I have a 13/45 on now. It's way better in the techincal stuff but I don't like to cruise over 55 mph with it.
Haven't noticed any wear from it.
See my pics
Dave:
The 610 really makes me want to ride like a punk everywhere I go.
bikefrk:
You now understand supermoto.
Your training is complete.
Hoder is offline   Reply With Quote
Old 06-07-2010, 06:41 PM   #17184
rockchucker22
rockchucker22's Avatar
Oddometer: 453
My 07 went at about 700 miles new seals and they haven't leaked since ...all though I did put seal savers on after the first leak.
rockchucker22 is offline   Reply With Quote
Old 06-07-2010, 06:44 PM   #17185
rockchucker22
Oddometer: 453
yeas larger rear slower top end. I went 4 larger in the rear and droped 12-15 mph top end.
Old 06-07-2010, 06:59 PM   #17186
Rattletrap
When in doubt-Gas it
Rattletrap's Avatar
Oddometer: 302
Well I can confirm the story about the silverstar bulbs. Put a 55 watt in my X2 for the high beam, and it lasted less than 500 miles. Replaced it with a standard 55 watt today. Maybe it will last somewhat longer I hope.
Rattletrap is offline   Reply With Quote
Old 06-07-2010, 07:32 PM   #17187
K7MDL
TE450, TE610
Oddometer: 1,552
Fuel range and load capacity wasn't really an issue for me. I almost never have time to take an extended trip on my bike.
Even so, some loops in the desert area are void of gas stops. Death Valley for example. Very easy to do 190 to 250 mile loops with no gas availalble along the way. I have refueled a KTM 950 and a KTM 400 from my old KLR supertanker last year in Moab and just over the Cascades from Seattle, respectively. Extended trips not required to find desolation in the western states :-)
K7MDL is offline   Reply With Quote
Old 06-07-2010, 08:34 PM   #17188
edeslaur
San Diegan
edeslaur's Avatar
Oddometer: 445
What's your top end? Maybe mine's just slow.
It would pull low 100s with the +10 into a stiff headwind. With the stock gears on it, it struggles at mid 90s - no headwind.
How do I know they're stock? I bought a new front gear, chain, and reinstalled the original rear (which came in the box o' parts).
Eric D
Ride reports:
- 10 Mar Baja
- 08 Feb Baja
- More!
Old 06-07-2010, 08:37 PM   #17189
edeslaur
San Diegan
edeslaur's Avatar
Oddometer: 445
Yeah, take a business card and run the corner under the lip of the seal and see how much dirt comes out.
Frequently it's something simple like that. Especially if your bike fell down of its own accord.
Eric D
Ride reports:
- 10 Mar Baja
- 08 Feb Baja
- More!
Old 06-07-2010, 09:23 PM   #17190
xymotic
xymotic's Avatar
Oddometer: 8,367
Thank you!!
Well, Les fixed my leaking fork seal
That's one part where a failure is not necessarily 'early' You get the right dirt in there, it's gonna leak. Ridden in any sand? Pismo beach is what killed mine. I haven't ridden my new suspenders yet, but everyone I know that has had it done by Les swears by them, so look on the bright side of life (Kinda ironic coming from a negative nelli like me)
Albert Einstein
6:10 to Yuma
Times are GMT -7.   It's 05:06 PM.
