Old 07-11-2010, 12:20 PM   #17521
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,144
Originally Posted by xymotic
Gotta Say: $1,800 for a grenaded/eaten cam don't sound all that bad
The cam was a $200 part. The tiny metal bits that fell down into the stator took out a $400 part. It figgin MIRV'd on me!
It stings more because I just bought the bike and had put less than 150 miles on it. Bought it used with under 2k miles on it.
But it's fixed up pretty good and I had a nice ride through the hills yesterday on it. But it did remind me how poorly it does over 45 or so. Body parts start to get numb from vibration. It's really meant to stick to the dirt. Guess I'll have to start finding more!
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is offline   Reply With Quote
Old 07-11-2010, 12:48 PM   #17522
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,537
I swapped out the rear bearings with a tire iron and a borrowed claw hammer...I kept breaking rocks.
Old 07-11-2010, 03:54 PM   #17523
Flashman1
Flashman1's Avatar
Oddometer: 5,359
Originally Posted by DeBandi
I'm changing my rear wheel bearings & seals today.
I have my torch for heating the hub and the bearings have been in the freezer for a couple of days.
My question is...
What is the best method for removing the bearings from the rear hub?
Thanks guys.
How do you know they are wore out?
Flashman1 is offline   Reply With Quote
Old 07-11-2010, 04:20 PM   #17524
Flashman1
Flashman1's Avatar
Oddometer: 5,359
Ride today - near Tucson.
Old 07-11-2010, 04:28 PM   #17525
motogo1
I don't want a pickle,...
motogo1's Avatar
Oddometer: 1,107
My question is...
Thanks guys.
I've always used a long drift (punch) from the opposite side to pound them out. You have to pry on the spacer to get the drift to land on the bearing inner race. Once you have tapped on the race a few times, the spacer becomes easier to move to the side. Don't know if this is the BEST method, but it's worked for me for about 35 years. And pry the seals off the new bearings and PACK them with grease.
5 of'em. Yes, I need 5.
motogo1 is offline   Reply With Quote
Old 07-11-2010, 04:51 PM   #17526
spanker
bada bing, capiche?
spanker's Avatar
Oddometer: 825
motogo1
That'll work, you just have to be patient with it and not take too much of a whack on one side......a little at a time so you don't cock it.
2010 BMW R1200RT, a sweet scooter for my daily 100 mile commute.
'08 Husqvarna TE-610, sold
waiting till I retire to get a new adv bike. meanwhile........
spanker is offline   Reply With Quote
Old 07-11-2010, 05:43 PM   #17527
motogo1
motogo1's Avatar
Oddometer: 1,107
True. When you headin' out to WY? I'll be out that way probably the 2nd week of Aug. Maybe gonna camp and explore in Big Horn National Park. Sounds like your crew is planning another epic adventure.
Old 07-11-2010, 06:42 PM   #17528
firefight100
Husky te610
firefight100's Avatar
Oddometer: 63
Road Trip 1624 miles
This is the Girl packed and ready for her 1624 mile road trip.
Eastern Florida upto Wright City Missouri. The objective was no interstate travel and no time frames.
Florida, Georgia, Tenn, Ky Il, Mo.
New concealed carry permit and several credit cards with me, I set out. Finished the trip there in 3 days.
The 610 is bearable for long distance riding. Dont believe anyone who says it isn't. I had already done a 700 mile trip in two days and a 360 in one day so I knew what I and the bike could do.
Oh and the only trouble on the trip, a pinhole leak in the hp fuel line one night. Easily repaired.
Cant wait to do the next trip. I'm thinking of Texas.
Lifes a bitch! Then you die !
08 TE610 HUSKY
Previous rides
Polaris 400 Scrambler
250 HARLEY DAVIDSON
441 BSA VICTOR
72 250 X6 HUSTLER SUZUKI
Currently in Sunny Malabar Florida
firefight100 is offline   Reply With Quote
Old 07-11-2010, 07:16 PM   #17529
spanker
bada bing, capiche?
spanker's Avatar
Oddometer: 825
firefight,
How did you repair the leak and does anyone know what the discharge pressure of the pump is?
Old 07-11-2010, 08:10 PM   #17530
firefight100
Husky te610
Oddometer: 63
Fuel leak
I had already modded my pump to have brass fittings and FI line. So I was able to cut off about 1.5 inches to the leak and put the line back on the brass hose barb.
Pressure is about 40 psi at the pump and get's reduced at the throttle body by the pressure regulator. I am not sure what the Fuel Injector sees for pressure.
08 TE610 HUSKY
Previous rides
250 HARLEY DAVIDSON
441 BSA VICTOR
Old 07-11-2010, 11:56 PM   #17531
Countdown
Oddometer: 5,321
My question is...
Thanks guys.
Like every thing else, there is a tool. It goes into the bearing from the out side then a flat tapered punch goes in from the other side and fits into a slot in the adapter and you pound it out.
Jerry Counts
Countdown is offline   Reply With Quote
Old 07-12-2010, 03:31 PM   #17532
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,807
My question is...
Thanks guys.
I have found this to be a good tool to use. It is a round bar about 12" long with, as you can see, a slightly mushroomed head. The lip is just enough to get into the gap between the bearing and the spacer or bearing and hub. Then just tap the bearing out, moving the punch and tapping around the bearing, from the other side. I don't heat or freeze anymore. You don't need to if everything is clean going back together. A little antisieze in the bore will make reinstall EZ and removal next time EZ as well.
Sorry, Honda hub shown.
Use the old bearing to drive the new one all the way in.
Something flat like this to drive in the seals. Again tap around on all sides till the new seal is all the way in.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc screwed with this post 07-12-2010 at 03:44 PM
fritzcoinc is offline   Reply With Quote
Old 07-12-2010, 03:47 PM   #17533
BaRbEndEr
BaRbEndEr's Avatar
Oddometer: 66
Renazco Seat to trade for a stock one
I'm looking to trade a Renazco seat(and some cash) for a stock seat.
It's Black leather top, and red carbon fibre sides. If I sell enough farkles, I'll get to keep the bike. Pivot pegs and Uptite skidplate to sell too :(
Pm if your butt needs relief from the stocker or you'd like to try some pivot pegs, ond/or a nice skidplate.
BaRbEndEr is offline   Reply With Quote
Old 07-12-2010, 04:45 PM   #17534
DeBandi
Exploring Alabama
DeBandi's Avatar
Oddometer: 3,100
Thanks "all" for the tips.
Explore / Dream / Discover
DeBandi
Visit ExploringAlabama.net
State Oval Decals Available
DeBandi is offline   Reply With Quote
Old 07-12-2010, 06:54 PM   #17535
30Bones
30Bones's Avatar
Oddometer: 4,634
Finally dusted off the bike and put 250 miles on it this weekend. 150 or so doing the first part of the TWAT ride to Soldiers Grove, WI. Only pic I nabbed as it poured not long into this. Back MT21 is bald and I need to get the Motoz sitting in my basement mounted up before the next ride.
Moto Guzzi rally coming up in August as well as the TWAT from Soldiers Grove, WI north.
30Bones is offline   Reply With Quote
Times are GMT -7.   It's 01:33 PM.
