Old 05-29-2012, 09:54 AM   #23446
logroller
b00n
logroller's Avatar
Oddometer: 24
Originally Posted by larryboy View Post
There isn't a gasket.
I hope you type fast and didn't spend too much time typing all of that.
It took be 4 hours to type that up - No, eyes quick.
No gasket. How the heck does that valve cover make a seal. I've never heard of a no gasket valve cover top. Whys though 600 series so different from the the other modies, me's wonder? It looks like the 600 series valve cover works like the top and bottom end mating surface on the smaller cc bike. Interesting.
I would say my recommendation still applies. Clean every single spec of the old sealer, wipe down any oil, reapply even amount of new sealant, check seating, slightly tighten, check seating, tighten to spec.
Cheers, Logroller
logroller screwed with this post 05-29-2012 at 10:01 AM
logroller is offline   Reply With Quote
Old 05-29-2012, 09:56 AM   #23447
logroller
b00n
logroller's Avatar
Oddometer: 24
Originally Posted by Lav1200 View Post
Had the top end apart to replace the rings. When reassembling it all, heard an odd "snap" while torqueing down the cam sprocket bolts... ugh:
Bike has approx 25k miles on it. Calling Halls and Motoxotica tomorrow to see who can get me one the quickest. Sucks to have something like this go just as riding season hits here in Canada.
WHAAAAAA??? Good for you knowing to think twice about what that noise might of been and then checking. Could you imagine trying to ride with that and the damage that would have occurred if you had not heard the pop/crack.
Cheers, Logroller
Old 05-29-2012, 10:18 AM   #23448
Dr Klaun
Dr Klaun's Avatar
Oddometer: 439
Does anyone have pics / info of the holes through the rear fender area for the rear rack (through the plastic)? I know this can't hold much, etc. etc. but I'm planning on fabbing up a little alum. plate rack for light items, that sits on risers extending down to the Al subframe. The 06-07 models had that OEM rack - was just wondering diameter / alignment of the holes through the plastic - I assume they just align vertically from the predrilled ones in the little alum subframe?
I'd also like to get some concensus on front brake pads. As I was working on the bike over the weekend, I noticed that the pads were missing big chunks of material. Never seen that before... Are the cheap fleabay organic / semi-metallics OK for general use or are folks actually using sintered or metallic pads?
- Matt
96 R1100RSL (red)
08 TE610
Dr Klaun screwed with this post 05-29-2012 at 12:00 PM
Dr Klaun is offline   Reply With Quote
Old 05-29-2012, 10:56 AM   #23449
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,160
Yeah, it's like a bottom end..no gasket machine tight fit. Your method doesn't work on the 610, I've tried...hafta use thread sealant on the bolts, the oil migrates up the threads and comes out around the bolt head if you don't.
larryboy is online now   Reply With Quote
Old 05-29-2012, 01:57 PM   #23450
logroller
b00n
logroller's Avatar
Oddometer: 24
Originally Posted by COXR650L View Post
I have a constant issue with an oil leak on the front of the engine, more right side. The oil looks like it is coming from the area of the front right of the valve cover and then runs down between the header pipes.
I have tried 3 times now to re-seal everything and it makes no difference and leaks the same amount in the same general area. It seams like it leaks the most running it at highway speeds.
I have been using permetex Aviation Gasket maker on the valve cover and inspection cover gaskets, with a dab of red silicon on the bolt threads.
What am I doing wrong???? I am tired of digging into this damn thing over and over. Is there anywhere else it could be leaking oil from that I am missing?
Thanks for any help.
There is a time gap in the video, but it seems like he did not use any gasket sealant on the 2006 model.
http://www.youtube.com/watch?v=pocw20JmBHw
Cheers, Logroller
Old 05-29-2012, 02:03 PM   #23451
logroller
b00n
logroller's Avatar
Oddometer: 24
Just found this, future reference parts source for most Huskies. Sorry I never did cathc what year, looks like the top end had gaskets until 2006. If I am reading this right.
http://www.athenaparts.com/eng/produ...nd-gaskets-kit
COXR650L and Larryboy, have you tried calling Hall's (IL), or Gpmotorcycles (San Diego, CA) and Moto-Forza (Escondido, CA)? All three have always helped me with questions.
Cheers, Logroller
Old 05-29-2012, 09:32 PM   #23452
mahonk
Oddometer: 6
flat spot around 4500?
when im rolling along at say 4500 rpm and then decide to crack the throttle i get a bit of hesitation for a second... then things pick up and i start to pull hard... with it still pinned, if i roll off the throttle a little bit i get a sudden increase in power? this is new to me since ive changed two things.. moved to a town with an elevation of 3000ft... and got the clearances set on the rockers just before the move.. any ideas?
mahonk is offline   Reply With Quote
Old 05-29-2012, 09:37 PM   #23453
mahonk
Oddometer: 6
me again
the bike is a 2007 610te and is carburated
Old 05-29-2012, 10:35 PM   #23454
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,160
Every 610 I've seen has been the same no matter how old. No gasket there. MotoXotica is my dealer of choice because he listens to me and stocks what breaks.
I wore out a 2007 610 in two years, lots of wrenching in 20,000 miles and I just try to help out here in the 610 thread, I saw every problem with the 610 and more. Cracked a front hub too.
Old 05-30-2012, 06:43 AM   #23455
SilverBullet
Oddometer: 455
This is characteristic of running lean. You were probably slightly lean before and didn't know it and now the 3K elevation change tipped the scale. Adjust your needle setting and/or rejet to your new altitude. What airbox setup do you have? If opened up you could cover the holes for a temp fix, might be enough.
_
2013 Yamaha Super Tenere
2011 Husqvarna TE630
2004 Suzuki VStrom 650
2002 KTM 300EXC
1974 Suzuki TM400
SilverBullet is offline   Reply With Quote
Old 05-30-2012, 06:52 AM   #23456
Taranis
Oddometer: 380
Check the resistance readings on your TPS.
Look into rejetting. I did the "Malcolm Smith" jetting and it runs crisp and strong from sea level to 5000'. The on-off-on hesitation is completely gone, which I attribute to the leak jet change.
DIRT BIKES ARE FUN AND INTERESTING
Taranis is offline   Reply With Quote
Old 05-30-2012, 07:39 AM   #23457
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
_
Since there is less dense air at higher elevations, shouldn't the bike be running richer at higher altitude? That is if he went up 3k ft in elevation and not down?
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 05-30-2012, 07:48 AM   #23458
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,708
The fuel calculations done by the computer use the air flow sensor to determine how much fuel to inject. So, less air mass entering the sensor, less fuel mass injected also.
The savings in mileage come more from the fact that the bike and rider are pushing through less air than anything related to the fuel mixture.
Old 05-30-2012, 09:19 AM   #23459
BlueLghtning
Oddometer: 5,403
I was questioning in response to mahonks' bike which is a carbed model. Silverbullet was saying his bike would be leaner at higher elevations and that didn't make sense?
I would agree with what you said about the FI models.
Old 05-30-2012, 11:24 AM   #23460
mahonk
Oddometer: 6
There is a jd jet kit in the carb right now... If that helps any..
Times are GMT -7.   It's 07:48 PM.
