Old 06-18-2012, 09:26 PM   #23701
JonXX
Infraction Collector
JonXX's Avatar
Oddometer: 389
I love my SM
Hungry? Out of work? Nowhere to ride? Do us all a favor and eat a Sierra Club member.
"They" said we couldn't run the OBDR on supermotos...
JonXX is offline   Reply With Quote
Old 06-19-2012, 12:55 AM   #23702
K7MDL
TE450, Jeep
Oddometer: 1,567
Termperature of TE610
I have the Trail Tech Vapor speedo with the coolant temp sensor installed in the cold water outlet of the right side radiator ('07 carbed). When I let it idle for a long time in the driveway (thus minimal temp diff between inlet and outlet temps), the fan runs when I see it get to around 200-208F and off less than 190F. I tried a thermo pistol thingy and it measured close to the same. Of course running down the road I see outlet temps from 130 to 190 depending on speed and ambient. I set my warning trigger at 210 and danger trigger at 220.
K7MDL is offline   Reply With Quote
Old 06-19-2012, 04:11 AM   #23703
Mgizler
Oddometer: 52
Originally Posted by 1 lunger View Post
I was thinking I could have an air pocket in mine too. Fans on more than I remember it being on before I changed the coolant. How do you resolve an air pocket?
Life is good!
Typically you would open a coolant outlet and try to "burp" it out by forcing coolant in until it comes out of the open connection. Some cooling systems actually have a port, screw usually, that you open to get the air out when refilling. What i am going to do is what jonxx described below, since thats really the only way to make sure.
Originally Posted by JonXX View Post
I don't know what the "official" procedure is, but we had a tech day a couple months ago and when we refilled the coolant, I pulled the small hose off of the water pump and poured until coolant came out of the water pump, stuck the hose back on and filled to the proper level. None of the three bikes that we had tore down that day have ran hot, that I know of (including mine).
That's what I was planning on doing today when I trouble shoot it some more.
Mgizler is offline   Reply With Quote
Old 06-19-2012, 05:50 AM   #23704
Taranis
Oddometer: 380
Originally Posted by Mgizler View Post
So, I am trying to finish up all reassembly of my bike and I come across this!!!!
Less than 2000 miles. So now I am on the hunt for a new cable. What do you guys think for a replacement? I saw somewhere there were a few guys putting the barnetts on with good results, and I also saw where there were some guys doing a few mods and getting another stock one. Any suggestions?
Thanks guys.
Mark
Lower end adjustments.
Top end adjustments.
With pics.
I'd also check Motion Pro. They make custom-length cables, and might be a little less expensive than Barnett.
DIRT BIKES ARE FUN AND INTERESTING
Taranis is offline   Reply With Quote
Old 06-19-2012, 06:19 AM   #23705
1 lunger
1 lunger's Avatar
Oddometer: 1,343
I drained it by opening the drain port by the header and flushed it with water. Then I poured Engine Ice in until I saw it come out the drain hole.
Life is good!
1 lunger is offline   Reply With Quote
Old 06-19-2012, 09:11 AM   #23706
SilverBullet
Oddometer: 455
I love my SM
Does the two hours also include mowing the grass? haha
_
2013 Yamaha Super Tenere
2011 Husqvarna TE630
2004 Suzuki VStrom 650
2002 KTM 300EXC
1974 Suzuki TM400
SilverBullet is online now   Reply With Quote
Old 06-19-2012, 11:13 AM   #23707
KIK ROX
KIK ROX's Avatar
Oddometer: 93
I love my SM
What size aux. fuel tank is that? Rotopax or Kolpin?
KIK ROX is offline   Reply With Quote
Old 06-19-2012, 03:59 PM   #23708
rocky mtn nut
rocky mtn nut's Avatar
Oddometer: 165
Well I ended up ordering a Barnett 101-37-10610 Cable directly from Barnett. After a few hours of trying to hunt one down from the many dealers in the area, I decided to call them directly when they opened. And they sold the new cable to me for 45$ + 10$ shipping and it will be to my door by Friday. Most of the local places wanted 56$-65$ for the cable plus shipping on top of that.
So if any of you guys Need a cable and want the Barnett here is their number. 1-805-642-9435
Thanks,
Mark
Mark you saved me, mine broke on the way home from work I followed your lead . its on its way.thank you
rocky mtn nut is offline   Reply With Quote
Old 06-19-2012, 04:51 PM   #23709
KIK ROX
KIK ROX's Avatar
Oddometer: 93
I just got my Barnett cable today... very nice, very robust. The coated cable looks promising, and the ferrule on the end of the housing looks like it will fit the lever better.
Old 06-19-2012, 04:57 PM   #23710
Flashman1
Flashman1's Avatar
Oddometer: 5,361
I hope they improved the design from 3 years ago - mine broke at the lever in 1000 miles - they "fixed" it for free - but it broke again in the same spot a 1000 miles later - went back to the OEM cable.
Flashman1 is offline   Reply With Quote
Old 06-19-2012, 05:37 PM   #23711
Road Rash
Infamous
Road Rash's Avatar
Oddometer: 18,772
Originally Posted by southy View Post
Battery died on mine recently with the same symptoms. If you have a multimeter put it across the battery and check the voltage as you press the starter button. On mine the battery showed 12.5v until I pressed starter button then it dropped to 1.5v.
Originally Posted by drrags View Post
Yup, battery. I'm gonna try a lithium ion next. My battery tray is still intact and I think a light battery will go a long way in keeping it that way.
Originally Posted by K7MDL View Post
I have a Ballistic EV02 in my TE450 and so far is has been great. The extra capacity is welcomed in my situation with a fan running long after the bike is off due to the air blockage of my particular rad guards. All that capacity, no special charging, and far less weight. So far so good.
Thanks for the info, I will order a Ballistic EV02 tonight
"A man can never have too many motorcycles, like any good craftsman you need the proper tool for the job at hand. A man needs more tools than a hammer, the same goes for bikes." ~Mr. Cob~
My Ride Through Roatan
Road Rash is offline   Reply With Quote
Old 06-19-2012, 06:32 PM   #23712
Hoder
Card carrying greeny
Hoder's Avatar
Oddometer: 1,019
Originally Posted by buffallodan View Post
Hi Folks!
I have been away from the forum for a while.
Dan
Wow! I haven't read this thread in months and who do I see? Welcome back! Hope all is well.
See my pics
Dave:
The 610 really makes me want to ride like a punk everywhere I go.
bikefrk:
You now understand supermoto.
Your training is complete.
Hoder is offline   Reply With Quote
Old 06-19-2012, 07:10 PM   #23713
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,825
I didn't have good luck with the MoPro cable. The barrel was way too small to fit in the recess at the lever.
With pics.
drrags is offline   Reply With Quote
Old 06-19-2012, 07:17 PM   #23714
buffallodan OP
buffallodan's Avatar
Oddometer: 1,709
Thanks Hoder!
buffallodan is offline   Reply With Quote
Old 06-19-2012, 07:26 PM   #23715
tlking6
tlking6's Avatar
Oddometer: 287
Started the tear down, no going back...
I've got that same exact tool bag on your shelf. Ive had that for years! That bag has been to hell and back with me!
08 Husky 610 TE
01 KTM 453 MXC
tlking6 is offline   Reply With Quote
Times are GMT -7.   It's 10:52 PM.
