Old 09-20-2012, 04:32 PM   #24301
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Originally Posted by flyrodder View Post
Seat Concepts cover and foam showed up today. Wish me luck.
The trick is to work from front to back and do both sides as you go. That's how I did it and I've had to do it a couple of times ( denser foam ). Pull it tight but not so tight it makes waves in the foam. I also sprayed the seat pan with adhesive. I've logged lots of very hard miles on this and I love it! don't forget to put the plastic thing on this and here too here's a back shot it really isn't hard, just take your time and keep checking to make sure it's even.
1 lunger screwed with this post 09-20-2012 at 04:40 PM
1 lunger is offline   Reply With Quote
Old 09-20-2012, 04:39 PM   #24302
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Originally Posted by BrandonR View Post
Some may remember the debate about running the TE with a capacitor..
I picked up a cheap surplus oscilloscope.
I probed the system at the positive battery terminal.
First, the battery is connected, then just the capacitor and finally the capacitor gets disconnected. You can see there's no built in filtering, the waveform goes to zero with each pole of the stator.
http://www.youtube.com/watch?v=X1x_w...zpLjmhzRk8hi3g
I'd have better luck translating Chinese than understanding that. So what are you say? They're bad stock or bad with the capacitor? Or just leave it alone like I have for the last 7500 trouble free miles?
Old 09-20-2012, 04:43 PM   #24303
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
Originally Posted by 1 lunger View Post
The trick is to work from front to back and do both sides as you go. That's how I did it and I've had to do it a couple of times ( denser foam ). Pull it tight but not so tight it makes waves in the foam. I also sprayed the seat pan with adhesive. I've logged lots of very hard miles on this and I love it! don't forget to put the plastic thing on this ( ie: condom ) and here too here's a back shot
it's really isn't hard, ( yet ) just take your time and keep checking to make sure it's even.
AND have a Gay sticker on the bottom side of your seat
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 09-20-2012, 05:34 PM   #24304
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Looking back it kinda sounds like I'm trying to help an impotent guy work through his problem and put a rubber on. I just read it to my wife and she laughed too. The JD tuner sticker does look like the gay flag! They should've picked better colors!
Old 09-20-2012, 07:37 PM   #24305
flyrodder
Donny, please.
flyrodder's Avatar
Oddometer: 3,100
Thanks for the advice -- It will at least keep me entertained while I'm "starting at the top"!
"It's sorta like a combination of camping in your Grandma's back yard, and a Frat party. " --fifthcircle 2015 Filth Fest
flyrodder is online now   Reply With Quote
Old 09-20-2012, 07:37 PM   #24306
flyrodder
Donny, please.
flyrodder's Avatar
Oddometer: 3,100
Originally Posted by Yossarian™ View Post
Good luck! I believe that a one week window before leaving on an excursion is plenty of time.
Unless you screw it up.
That mean you are coming over to "help"?
Old 09-20-2012, 09:22 PM   #24307
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,656
Got any brew? Yeah, I can "help" you.
Old 09-20-2012, 09:42 PM   #24308
BrandonR
BrandonR's Avatar
Oddometer: 861
It explains why the bike shuts down when there's no battery. And shows there's no crazy spikes in voltage as someone speculated. The bike can be more reliable with a simple capacitor added to the system, this shows it graphically. I believe it also may explain why they have so many batteries fail (Shitty charging method).
Brandon Reed
2009 Husqvarna TE610
BrandonR is offline   Reply With Quote
Old 09-20-2012, 09:44 PM   #24309
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,366
What Brandon is proving is if (when) your trouble free battery fails, you will be able to get a jump start and motor home if there is a capacitor wired in
Hey Brandon, what should the cap rating be?.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 09-21-2012, 04:15 AM   #24310
1 lunger
1 lunger's Avatar
Oddometer: 1,253
I was stuck in the woods once with a dead battery and it would even take a jump start from a truck. I will look into wiring one of these capacitors in. Thanks guys.
Old 09-21-2012, 05:41 AM   #24311
mrkartoom
Lurker Extraordinaire
mrkartoom's Avatar
Oddometer: 828
Same here. My bike was only months old when the stock Varta exploded and left me stranded 30 miles out from the event start. I was missing a good old carb at that point. Luckily the sweep crew was there to save the day.
Getting stranded remains my one concern with this bike. If this works it would be great.
"gotta have more cowbell" C. Walken
"I
spent 90% of my money on woman and drink. The rest I wasted." G. Best
'08 Husqvarna TE610, '11 Gas Gas EC300, '03 Beta Rev3 250
Husky TE/SM-610 Thread Index
mrkartoom is offline   Reply With Quote
Old 09-21-2012, 06:23 AM   #24312
shootis
shootis's Avatar
Oddometer: 114
Brandon has more info over here:
http://www.cafehusky.com/threads/09-...battery.12094/
I think this is the one he used:
http://www.radioshack.com/product/in...ductId=2102508
shootis screwed with this post 09-21-2012 at 06:43 AM
shootis is offline   Reply With Quote
Old 09-21-2012, 06:26 AM   #24313
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Ever since I put the new battery in I hook it to the tender until fully charged and then unplug it. I've had this battery for 7500+- mile (1.5 years) and test it often. Its always 100%. The battery that shit the bed was stock and never changed out when I bought the bike as leftover 2.5 years after it was built. It lasted for 200 miles (30 days)
Old 09-21-2012, 10:48 AM   #24314
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,366
The battery that is currently in mine has been a trouble free replacement for the original too, but one thing I know is that it will fail someday. They all do.
Old 09-21-2012, 12:15 PM   #24315
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,222
Originally Posted by shootis View Post
Would be nice if there was a clear writeup of this, either here or on CH
huzar is offline   Reply With Quote
Times are GMT -7.   It's 07:33 AM.
