Old 01-05-2013, 11:35 PM   #24646
BiG DoM
African Adventurer
BiG DoM's Avatar
Oddometer: 2,488
Subframe failures with many enduro type bikes are common - this is a weight saving area and often they are only designed to hold the fender and maybe lights and plate. Many then fit a rack or extra gas tank and they FAIL. This is very common on the 610's and 630. When you have it repaired you must have it gusseted for extra strength. There is a very good thread on it on the Cafe Husky website (albeit for the 630) uit applies to 610 as well. This will also allow you to use a rack if you wish. If you simply weld the break the chances are good it will break again next to the existing break.
BiG DoM
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... 'Fuck, what a trip!'
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcyclists.
BiG DoM is offline   Reply With Quote
Old 01-06-2013, 12:50 PM   #24647
BiG DoM
African Adventurer
BiG DoM's Avatar
Oddometer: 2,488
Oh and check your battery cage while about it - also known to crack.
BiG DoM
Old 01-07-2013, 10:52 AM   #24648
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 758
Thanks. Someone PM'ed me a link to the MotoIQ website where they did some repairs.
http://www.motoiq.com/magazine_artic...ed-design.aspx
I am pretty much going to do something similar to what is on the above page. Below is where I am now. I hope the repair isn't too expensive.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 01-07-2013, 05:23 PM   #24649
1 lunger
1 lunger's Avatar
Oddometer: 1,253
That should be an easy enough fix.
1 lunger is offline   Reply With Quote
Old 01-07-2013, 05:29 PM   #24650
motopreserve
Oddometer: 128
I just did the Moto IQ described fix for the clutch cable - making a collar for the ferrule. Great, easy fix. That couple with some cleaning and fresh dri-slide, and the clutch pull action is night and day.
Very helpful tips.
Kawasaki Versys**CL360 Project**Honda CB 550**Husky TE610**'72 XL250 for the lady
MotoPreserve -- a blog about wrenching on bikes in Barre, VT...
motopreserve is offline   Reply With Quote
Old 01-07-2013, 06:31 PM   #24651
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 758
Yea that one place wouldn't be that bad to weld up, but i am planning on getting the area strengthened with some gussets. That is going to increase the price of repair by a large margin. It will be much better though when it is done.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
Old 01-07-2013, 06:46 PM   #24652
motopreserve
Oddometer: 128
If you buy the metal and cut the pieces yourself, the price really should not be that much more. It's not a ton more welding - based on what was on the Moto IQ site.
Old 01-07-2013, 07:24 PM   #24653
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 758
Yes that would help. I don't really have a workshop area or the access to the tools that I need where I live now. I might could do it but it would have to be done with hand tools.
Does anyone happen to know what grade of aluminum I should be looking for or what the subframe is made of?
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
Old 01-07-2013, 07:36 PM   #24654
xymotic
xymotic's Avatar
Oddometer: 8,367
It's either low grade cheese or high end butter, not really sure :)
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 01-07-2013, 10:25 PM   #24655
BiG DoM
African Adventurer
BiG DoM's Avatar
Oddometer: 2,488
Looking at that fracture it may be worth bracing the break internally with rod or bar before the initial weld and the guzzeting. Always try and get the maximum span in the gusseting without it interferimg with plastic panels etc. The pic in the IQ link shows the lower gusset a bit short IMHO as was room to extend it some.
BiG DoM
Old 01-08-2013, 07:57 AM   #24656
Taranis
Oddometer: 365
The break above is through a solid forging, not a tube section.
Go to an actual metal supply place or fleabay if you can't find one near you and get 6061-T6 or T-6511 (the latter is typical for extrusions). Most of them have a remnant section where you can get end cut pieces for a few bucks. Stay away from typical hardware store material, which is actually kinda like " low grade cheese or high end butter" in comparison. IMO, the 610's chassis isn't made from poor material, it just has lots of bad design details and some sloppy manufacturing here and there.
You can make all those reinforcing bits with a bench vise, hack saw and some files. I've done a ton of that stuff that way. A power disc sander makes it go a lot faster. I guess a $10 Harbor Freight angle grinder and $4 of discs would speed things up, too.
DIRT BIKES ARE FUN AND INTERESTING
Taranis screwed with this post 01-08-2013 at 08:11 AM
Taranis is offline   Reply With Quote
Old 01-08-2013, 08:59 AM   #24657
BiG DoM
African Adventurer
BiG DoM's Avatar
Oddometer: 2,488
Yeah looking at it again you right.
BiG DoM
Old 01-08-2013, 10:27 AM   #24658
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 758
That is funny! You might be right.
Yes. I think that the lower bracing section can be lengthened out much further into the tail fairly easily. I have not decided how I want to do the top section though. There is not much room with the plastics. I think that I will change the design from the MotoIQ site and make a thicker but shorter brace on top.
Yes it is solid.
I will probably go with onlinemetals.com. I have used them before and you can order exactly what you want. They have reasonable prices also. 6061-T6 is readily available but I have not seen T6511. I will probably end up cutting them some with a jigsaw and hand finishing. I am sure it will make the repair job cheaper.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
Old 01-09-2013, 04:34 AM   #24659
fatgut
Oddometer: 634
Rear sub repaires
Did copy of this to my 610 after 10,000km of hard Aussie bush fully loaded no issues.
Kev
fatgut is offline   Reply With Quote
Old 01-09-2013, 05:21 AM   #24660
motopreserve
Oddometer: 128
We have ordered a ton of metals to the shop from these folks too, just as an option: http://www.mcmaster.com/#
Times are GMT -7.   It's 10:07 PM.
