Old 03-31-2013, 09:33 PM   #24961
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,920
Maybe, depends on your setup. I can go 13-16t front with two links more than stock and a 50t rear. Then convert to 17/47 (I think, have to check) with a sumo set up.
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 03-31-2013, 09:48 PM   #24962
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,371
Yeah I run one chain and can run 13, 14, 15 & 16 with 50 rear (15/50 is my favorite off road set up) and then sumo set up with the same chain is 17/47
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 04-01-2013, 05:42 AM   #24963
buffallodan OP
buffallodan's Avatar
Oddometer: 1,709
Originally Posted by xymotic View Post
Is there enough range in the chain adjusters to swap a 13 front to a 17 w/o adding a link?
I dont think a 17 will fit? I run 14, 15, 16 with stock 45. I created a thread on a gizmo shim setup for switching between 14 and 16. It worked well eliminating need to change adjustment screws...
Sent from my SCH-I605 using Tapatalk 2
buffallodan is offline   Reply With Quote
Old 04-01-2013, 06:00 AM   #24964
Indy Unlimited
Oddometer: 1,371
I have been running 17 tooth for 6 years now. You cant run a chain guard but it fits.
Current Stable:
Old 04-01-2013, 08:05 AM   #24965
Huskylove
Oddometer: 54
Cam chain problem is a deal breaker for me....maybe i will keep an eye for a 630 at the right price (under 6200$ish)
Only bikes on the market that appreciate :/
96 Xr600r, 644cc 10.5:1 Je, megacycle cam/rockers, fcr41 sudco, custom exhaust and a set of 17's <motor and frame for sale PM me
Huskylove is offline   Reply With Quote
Old 04-01-2013, 10:15 AM   #24966
1 lunger
1 lunger's Avatar
Oddometer: 1,267
The only problem doing this is when adjusted all the way forward it makes the rear brake line bend more and put pressure on the brake. You have to crack the bleeder and let som fluid out and top it off when you pull it back. No big deal, just remember to do it. I have mine adjusted forward and the throw in the brake peddle feels short due to this. Anyone else have this happen?
1 lunger is offline   Reply With Quote
Old 04-01-2013, 11:14 AM   #24967
sein
Oddometer: 42
Clogged tank vent?
My '06 TE610 was struck by a car while parked last week, and judging by the marks on my handlebars it looks like it fell on its right-hand side. Not sure how long it was on its side because someone had picked it back up by the time I saw it.
Since then I've had some issues with the gas tank not venting. First thing i noticed was an odd noise coming from behind the headlight, which was a sort of periodic wheezing. This turned out to be coming from the vent hose attached to the top left of the gas tank. About every 30 seconds it would let some air out, then stop. Opening the tank revealed it to be under some small amount of pressure, and I was able to reproduce the issue again just by shaking the tank.
In addition to that, if I run the bike for a little while without shaking it, a vacuum forms in the tank. Air does not appear to be getting sucked into the hose mentioned above when this happens.
Is it possible the vent hose is just clogged with something, or perhaps got knocked out of wherever it was mounted so it's now malfunctioning? (it's currently just hanging loose behind the headlight, but there are indentations on the end of the hose that make it look like it might have been clamped to something.) Anything else I should check?
sein is offline   Reply With Quote
Old 04-01-2013, 01:23 PM   #24968
1 lunger
1 lunger's Avatar
Oddometer: 1,267
Blow in the hose and see what happens. If its clogged, start at the end and work backwards.
Old 04-02-2013, 06:24 AM   #24969
flyrodder
Donny, please.
flyrodder's Avatar
Oddometer: 3,121
Pull the vent line and have a look at the vent nipple. You can remove the nipple from the tank and look at it, maybe it was damaged when the bike went down.
"It's sorta like a combination of camping in your Grandma's back yard, and a Frat party. " --fifthcircle 2015 Filth Fest
flyrodder is offline   Reply With Quote
Old 04-02-2013, 08:25 AM   #24970
Ditch
Ditch's Avatar
Oddometer: 1,104
Clogged vent?
Has the bike been desmogged?
Wendell
You will never find a more wretched hive of scum and villainy....we must be cautious.
Ditch is offline   Reply With Quote
Old 04-02-2013, 08:36 AM   #24971
sein
Oddometer: 42
Pulled the hose off and I don't see anything particularly weird so far:
The left-hand side was connected to the tank, and the right-hand side hanging freely behind the headlight. If I blow in the right-hand side, the air passes freely through the hose and out the left. If I blow in the left-hand side, though, it takes more force to get the air through, and I can occasionally hear a kind of squeaking/wheezing sound like a goose that just stubbed its toe. The squeaking/wheezing sound is the same one that I noticed originally when the tank was under pressure.
I'm guessing there's some kind of valve inside the grey/green canister? If that's the case, then perhaps everything so far is normal and I should be looking at something else?
I'm not sure (bought the bike used). How can I check?
sein screwed with this post 04-02-2013 at 08:50 AM
Old 04-02-2013, 08:41 AM   #24972
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,669
Yes, it's a one-way check valve that vents excess pressure from the fuel tank. If left in place it can make a burping or mooing noise as tank pressure vents.
Old 04-02-2013, 08:57 AM   #24973
sein
Oddometer: 42
Good to know that's normal, then
Since air flows freely in the other direction I'm guessing it uses the same hose to pull air into the tank to prevent it from forming a vacuum? If that's the case, maybe the hose was just kinked or something.
Old 04-02-2013, 09:36 AM   #24974
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,669
Maybe. On the advice of George Erl (Uptite Husky) I removed the valve and just routed a line straight down to the skid plate area. Apparently, he had seen the valves fail in the past, allowing the tank pressure to reach excessive levels.
Old 04-02-2013, 06:57 PM   #24975
Taranis
Oddometer: 372
Happened to me. The worst time, when I finally figured out what was going on, I drove from Long Beach, up the Cajon Pass to Adelanto area, back down to 138 and up to Miller Jeep Trail all with the bike in the van. When I unloaded, it had built up so much pressure that when I turned on the gas, it overpowered the float valve and filled the bowl to the point gas leaked out the vent ports in the throat of the carb and pooled in the boot connecting to the air cleaner. I had nothing better to do and a picnic bench to take it all apart, which is the only reason I found the pool of gas.
All the other times the valve screwed me and made the bike not run by overfilling the float bowl, I had either tipped the bike on its side or done a really steep climb or both. I was thinking I was getting some dirt sucked into a jet when it tipped, or something. The non-level position of the bike changed the effectiveness of the float and needle, and pressure from the tank overfilled the bowl. Never would have figured it out if I hadn't had that last time where it happened as soon as I turned the gas on.
I took off the valve (it was the last part of the evap system left after my canisterectomy) and replaced it with a Free-Flo hose (hose only, no valve). Used a vacuum restrictor from Autozone to minimize the spill rate if it does and a small inline fuel filter at the very end to avoid drawing dirt into the tank. So far, so good.
I did a lot of reading about check valves. Many people have problems with the little aluminum ones not venting. An OE check valve off a dirt bike is probably a little more reliable, but they are made to go vertically out the top of a screw-on gas cap. With the Husqvarna's horizontal vent exit, I wasn't sure the valve wouldn't get closed by normal slosh and cause the same problem all over again. Hence the restrictor rather than a check valve.
With a normal off-road bike, the overflow line on the float bowl just vents out past the linkage, and if the bowl is overfilling, it starts dumping gas on the ground visibly. Due to the carb vent lines being collected for evap control on the TE610, the overflow line runs back up higher than the air passages from the bowl chamber to the air inlet, so the lowest spill point was back into the air boot.
I installed a 7602 Racing carb vent system to fix that.
DIRT BIKES ARE FUN AND INTERESTING
Taranis screwed with this post 06-09-2013 at 03:11 PM
Taranis is offline   Reply With Quote
Times are GMT -7.   It's 03:07 AM.
