Old 04-28-2013, 01:27 AM   #25111
BiG DoM
African Adventurer
BiG DoM's Avatar
Oddometer: 2,496
Originally Posted by xymotic View Post
I Finally got round to replacing my cam chain (this will be #3)
Anybody else broken a top motor mount? (broke right above motor) Anything I need to look into on the bottom to ensure the motor is aligned right?
When I first pulled my tank I noticed the top mount was loose, despite the nuts being the lock variety! This is just one of many often found loose bolt problems found ex factory on these bikes .... Luigi took a long lunch My guess yours may have been same and resulted in break. Check bottom mounts as well.
BiG DoM
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... 'Fuck, what a trip!'
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcyclists.
BiG DoM is offline   Reply With Quote
Old 04-28-2013, 06:15 AM   #25112
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 1,058
front suspension
Quick question on suspension, how do I interpret the +/- on the front forks?
Also, what is the red knob next to the choke for?
Can you tell I'm a noob??
Almost got it cleaned up and ready for a photo shoot....
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 04-28-2013, 06:29 AM   #25113
1 lunger
1 lunger's Avatar
Oddometer: 1,302
It for dampening. - is faster, + is slower or harder / softer whatever you want to call it. + will make it harder, ie more dampening - will make it softer, ie less dampening.
1 lunger is offline   Reply With Quote
Old 04-28-2013, 06:31 AM   #25114
1 lunger
1 lunger's Avatar
Oddometer: 1,302
Those only control the compression stroke. Rebound dampers weren't put on the newer bikes. If you have rebound dampers they'll be on the bottom of the forks.
Old 04-28-2013, 06:32 AM   #25115
1 lunger
1 lunger's Avatar
Oddometer: 1,302
Red knob?? Sorry, mines FI and I can't help with that.
Old 04-28-2013, 06:51 AM   #25116
TIGERRIDER007
Oddometer: 1,058
Okay, so if I'm doing motocross, I'd want to go toward the + and if I'm doing forest service roads/gravel trails I'd want to go toward the -
I think that's right...
I'll look on the bottom of the forks.
Red knob, maybe it's nitrous....
Scott
Old 04-28-2013, 06:57 AM   #25117
1 lunger
1 lunger's Avatar
Oddometer: 1,302
Take pic of the nitrous knob and send it to me. I might be able to tell you what it's for.
Btw, let me know how you do at the motox track with the 610. Lol
Old 04-28-2013, 07:00 AM   #25118
TIGERRIDER007
Oddometer: 1,058
Yep, will do, it's next to the choke...and I think Duane told me what it was, but I was too excited and already thinking of this bike off road to hear what he said...
Scott
Old 04-28-2013, 07:23 AM   #25119
1 lunger
1 lunger's Avatar
Oddometer: 1,302
Hot start??
Old 04-28-2013, 07:27 AM   #25120
Ditch
Ditch's Avatar
Oddometer: 1,131
Black knob on carb is enrichener
Red knob is hot start
Wendell
You will never find a more wretched hive of scum and villainy....we must be cautious.
Ditch is offline   Reply With Quote
Old 04-28-2013, 07:32 AM   #25121
TIGERRIDER007
Oddometer: 1,058
hot start?
Forgive my lack of knowledge, what does a "hot start" do?
Scott
Old 04-28-2013, 08:18 AM   #25122
1 lunger
1 lunger's Avatar
Oddometer: 1,302
When bike is hot they don't like to start. The enricher helps when cold and hot start helps when hot
Old 04-28-2013, 08:21 AM   #25123
TIGERRIDER007
Oddometer: 1,058
Now I get it, that is really cool...I'm starting to like this bike!
Scott
Old 04-28-2013, 11:52 AM   #25124
xymotic
xymotic's Avatar
Oddometer: 8,367
Originally Posted by Taranis View Post
You mean just the plate, not the frame itself, I hope. I'd just check alignment and make sure it's not being bent when torquing the bolts. Shim whichever side of it needs shimming, and you should be fine. Pre-bending things that are going to get vibrated a lot is a good way to promote failure.
Yeah the plate cracked right above the motor. what concerns me I guess is that there's a 1/32nd gap so it almost seems like ALL of the weight of the motor is on the top mount.
I guess I'll just have to get a new one and see how it fits.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 04-28-2013, 01:35 PM   #25125
Flashman1
Flashman1's Avatar
Oddometer: 5,361
Originally Posted by larryboy View Post
I've seen them wear that fast, they'll be fully wasted by 7,000 miles.
We are talking about the follower roller.
I just did mine for the first time - at 22,000 miles - maybe the bikes vary that much - or your riding style causes more wear.
Very easy to replace - don't forget the water pump gasket.
Flashman1 is offline   Reply With Quote
Times are GMT -7.   It's 12:05 AM.
