Old 04-29-2013, 06:38 PM   #25141
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 1,059
Originally Posted by JonXX View Post
It allows more air in, reverse of the choke.
Previous responses are correct, but in my experience the hot start button is only needed if you stall or cough out the engine, not when you shut it off on purpose. I've only needed to use it once on my 610, but I use it all the time on my 450.
Ah, makes sense. Thanks to all you guys who help us noobs along....
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 04-29-2013, 07:03 PM   #25142
xymotic
xymotic's Avatar
Oddometer: 8,367
Originally Posted by EricMN View Post
If your not leaking oil by your shifter the shaft bushing and seal are probably good. I have heard of people welding loose shifters to the shaft, but you are going to have an even harder time down the road when you NEED to get it off. To replace the shaft, you have to remove shifter and the clutch cover, the shaft will slide out the right side(make sure the shaft is clean or it will be hard to get through the bushing) You might have to remove the right foot peg, looks the shaft will hit it.
ok, cool! It just slides out the clutch side when you take off the circlip?
I do have an oil leak, but I "think" it's the crack in the stator cover where its been hitting. Either way I need to fix it.
anyone know of a decent aftermarket replacement for the shifter itself?
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 04-29-2013, 09:22 PM   #25143
Lav1200
Pig Pen
Lav1200's Avatar
Oddometer: 1,290
Originally Posted by xymotic View Post
Anybody else broken a top motor mount? (broke right above motor)
Yup - found mine broken at about 30,000 km
'11 Gas Gas EC250 | '06 KTM 950 Adv | '79 Laverda 1200
Lav1200 is offline   Reply With Quote
Old 04-29-2013, 10:41 PM   #25144
xymotic
xymotic's Avatar
Oddometer: 8,367
Did it develop a little gap or was it just a hairline crack?
Albert Einstein
6:10 to Yuma
Old 04-30-2013, 06:32 AM   #25145
EricMN
Oddometer: 18
There isn't a circlip on my 07, they should all be the same.
EricMN is offline   Reply With Quote
Old 04-30-2013, 06:53 PM   #25146
BarberPole
Short of the Clacker
BarberPole's Avatar
Oddometer: 30
I wish I could help with alternate shifters..............but I can't.
I epoxied a couple of quarter/50cent size pieces of sturdy neopreme along
the back edge of the stator cover where the shifter head travels and it has really protected the cases.
Even though I beveled down the shifter edge, my boots tend to push in on the shifter during panic down shifts and the head scrapes along those neopreme home made buffers.........or I'd have scrape cracks in my cover also........at 1500 miles.
Good luck
Finally free......to be a Servant to Thee
BarberPole is offline   Reply With Quote
Old 04-30-2013, 06:58 PM   #25147
BarberPole
BarberPole's Avatar
Oddometer: 30
Originally Posted by 1 lunger View Post
Those only control the compression stroke. Rebound dampers weren't put on the newer bikes. If you have rebound dampers they'll be on the bottom of the forks.
I might be mistaken but I think the Husky is somewhat reversed from many other bikes.
The "rebound" damper adjustments are on the top of the forks........08-09s
and the "compression" adjusters are on the bottom......on 06-07s.......along
with "rebound" adjusters up top .
Surely correct me if I'm wrong.
Old 05-01-2013, 12:30 AM   #25148
K7MDL
TE450, Jeep
Oddometer: 1,562
For a loose shifter lever fit over the splined shaft, the shaft splines are likely fine. The shifter metal is typically softer steel and has a lot of leverage applied to it, not to mention ground contact and probably was never truly tightened that well to start with.
I would look at some way to do an very thin insert, either a liquid metal or super thin material that will deform and fill the gap a bit. My traditional option is to ensure there is plenty of gap in the squeeze area, making it larger if needed (dremel wheel, hack saw, or file), and use a better clamp bolt, such as a 12.9 grade socket head and then get a good clamp force and fit again.
K7MDL is offline   Reply With Quote
Old 05-01-2013, 04:44 AM   #25149
StolenFant
Oddometer: 246
It was called a beer can fix when I was younger. The 1970's Honda Elsinore's and Suzuki TM's were notorious for stripping the shifter and kick starter threads. Beer can because back then Coke cans were steel, but beer cans wetter very thin malleable aluminum. A little filing and a through bolt/nut was often required to get sufficient clamping force.
Sent from my DROID RAZR using Tapatalk 2
StolenFant is offline   Reply With Quote
Old 05-01-2013, 08:32 AM   #25150
tlking6
tlking6's Avatar
Oddometer: 287
Haha,, yeah, brought back some memories for sure!
08 Husky 610 TE
01 KTM 453 MXC
tlking6 is offline   Reply With Quote
Old 05-02-2013, 04:16 AM   #25151
Taranis
Oddometer: 380
Be sure to clean the lever clamp threads with a tap use a high-strength bolt. When I got my bike at less than 1k miles, the bolt (don't know if it was the original) was low grade and the threads were rounded. The lever was slightly loose and couldn't be tightened. A nice 12.9 as mentioned above will allow greater torque without thread damage and eventual loosening. I used an ARP stainless flange-head bolt.
DIRT BIKES ARE FUN AND INTERESTING
Taranis screwed with this post 06-09-2013 at 03:05 PM
Taranis is offline   Reply With Quote
Old 05-02-2013, 11:30 AM   #25152
Cainer
supern00b
Cainer's Avatar
Oddometer: 205
Just got my 2007!
Just got my 2007 TE610 delivered. I purchased it with 2100 miles on the odo from a fellow inmate in Michigan and it took about a week to get it shipped here...but it's here in all its glory!! :)
I swear it looks like a new bike sitting there in my garage. I am already going through it with a fine tooth comb and looking for fun places to farkle (did my first mod the first morning I got it, a pigtail for the Battery Tender. :) I haven't rejetted yet for Colorado, though a JD kit came with the bike and I think I've figured out what I need to do to swap it out for high altitude (the kit was installed for Michigan air pressures, but I'm not sure if the leak jet was replaced at the time or how to tell once I get in there. if anyone has insights to that I'd love to hear them.).
Looks like I have about 1700 pages of this thread to catch up on. :) Is there a TE610 FAQ anywhere?
Cainer screwed with this post 05-02-2013 at 11:31 AM Reason: Changed 1000 pages to 1700 pages...you guys are prolific! :D
Cainer is offline   Reply With Quote
Old 05-02-2013, 02:50 PM   #25153
h2o_snow
Water, snow & dirt too.
h2o_snow's Avatar
Oddometer: 744
Tire Pressure and Front Rim Locks
Noob question.
I'm gonna spring for a new rear D606 and install a rim lock & then balance the tire. Good plan I think.
Have not really messed with changing pressure below 25psi for off road riding - (I'm about 50/50 road/dirt). What do you use to air up for the slab after dirt?
Thoughts on pressures - know its a personal preference/tire deal but how low do you guys go front/rear?
Also................I can make an argument in my mind for a rimlock on the front - wadya think?
Safety third.
06 TE 610; 98 DR 650 - Sold: a past pleasure
02 XT225 - Wifey's ride
So I'm packing my bags for the Misty Mountains
Over the hills where the spirits fly,
I really don't know.
h2o_snow is offline   Reply With Quote
Old 05-02-2013, 03:27 PM   #25154
Flashman1
Flashman1's Avatar
Oddometer: 5,361
Originally Posted by h2o_snow View Post
Noob question.
Safety third.
Well I use a Perelli MT43 on the rear - 20 to 25 lbs on the road and 8 to 10 lbs off road - amazing traction - much better then D606 at least here in S. AZ.
Front is a Perelli 21 - leave at 20 lbs on and off road - used to air it down but got too many flats - with pinches.
Flashman1 is offline   Reply With Quote
Old 05-02-2013, 03:49 PM   #25155
h2o_snow
h2o_snow's Avatar
Oddometer: 744
Flash,
How do you air up on the fly?
D606 rear has been a pretty good compromise for me and the local moto shop generally will match or beat the interweb. I prefer to give them my $.
Thanks.
Times are GMT -7.   It's 07:16 PM.
