Old 06-06-2013, 04:54 AM   #25246
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 1,091
okay, I've read hundreds of pages...
Don't start the OMGs because I'm asking about oil...I've searched hundreds of pages in this thread and didn't find my answer, so....
Can you briefly describe an oil change procedure for a 2006 and what oil to run and how much oil it takes?
I appreciate all good information, since I'm learning about this bike and I'll even laugh at a few smart ass comments...
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is online now   Reply With Quote
Old 06-06-2013, 05:28 AM   #25247
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,705
Two drain plugs on the sump come out (one is a recessed hex.)
Remove left side bag filter & clean.
You can take out the right side bag filter if you have extra time, but it takes removing the case cover.
Remove filter cover, extract filter & replace.
Button it all back up and put in 10W60 or a similar weight class oil. I use Motorex. 2.1 quarts when replacing the filter.
Old 06-06-2013, 09:14 AM   #25248
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,156
I highly recommend it, side cover gasket is reusable.
Old 06-06-2013, 09:19 AM   #25249
K7MDL
TE450, Jeep
Oddometer: 1,565
And if you do pull off the right side clutch cover to check that "bag" filter (just 2 metal mesh tubes screens, one inside the other), be sure to watch for the proper alignment of the oil pump shaft notch putting the cover back on. The gasket is reusable. Do not over tighten those bolts, the o-rings and gaskets work well enough. The paper oil filter cover on the front right side has 3 bolts and has a spring between the cover and filter top. Don't forget to put it back in after it pops out and rolls away.
K7MDL is offline   Reply With Quote
Old 06-07-2013, 05:28 AM   #25250
flyrodder
Donny, please.
flyrodder's Avatar
Oddometer: 3,180
That probably didn't buff out.
"It's sorta like a combination of camping in your Grandma's back yard, and a Frat party. " --fifthcircle 2015 Filth Fest
flyrodder is offline   Reply With Quote
Old 06-07-2013, 05:59 AM   #25251
DutchGrandia
b00n
Oddometer: 14
Originally Posted by pete613 View Post
Hey everybody, I'm not sure if this has been mentioned before but on my 2009 TE610, when at a stoplight or coasting (at idle in gear) the bike will randomly shut off when the clutch is pulled in all the way. It does not feel that the bike is stalling out, it just shuts off as if I turned off the ignition.
Does anybody have any clue of what this could be?
Thanks, Pete
probably your starter wire has a poor connection
I have short circuit-ed the connection
DutchGrandia is offline   Reply With Quote
Old 06-07-2013, 07:05 AM   #25252
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,156
Right side is the single filter I posted a pic of, left side has the double screens...you nailed the rest of that stuff.
Old 06-07-2013, 07:53 PM   #25253
Baroquenride
Oddometer: 986
Marzocchi fork manual
Anyone have the fork manual in pdf that they could send me? Maybe a Sachs shock manual too? PM for my email addy.
2000 Honda VFR800, 2008 Husqvarna TE-610
Baroquenride screwed with this post 06-07-2013 at 08:02 PM
Baroquenride is offline   Reply With Quote
Old 06-08-2013, 02:58 PM   #25254
Ben600
Ben600's Avatar
Oddometer: 13
Here's my newly acquired Husky!
A '98 Te610, Left hand kick only, right drive...First registered in 2007, with only 600km on it. Excel rims with Talon hubs.
It's a lovely bit of kit, I am hoping to fit the enduro rims to it, but I am having trouble with spacers on the rear?
Anyway, here she is....
[IMG][/IMG]
Ben600 is offline   Reply With Quote
Old 06-08-2013, 10:53 PM   #25255
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,475
got huge amounts of footage of all our TE610 riders over the past three years so edited the best bits down to this. enjoy...
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 06-09-2013, 05:29 AM   #25256
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,478
Great job on the video! Says it all. Very versatile do all motorcycle. Hands down best dual sport these last 15 years.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 06-09-2013, 05:25 PM   #25257
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
For those of you running a Giant Loop Fandango or Diablo tankbag, where did you attach it to on the left-hand side? I had it running over the top of the exhaust heat shield and down to my DirtBagz bracket. Seemed to work well for about 500 miles, but today the strap running over the head shield melted. I'm not seeing another good location to attach it, unless I ran it all the way down to the left lootpeg, which seems weird...
huzar is offline   Reply With Quote
Old 06-10-2013, 05:37 AM   #25258
TrailPunter
Oddometer: 58
Giantloop
I used the passenger peg brackets to mount the bag. I also used one of their heat shields.
Mike
09' TE-610, 06' TE-250
TrailPunter is offline   Reply With Quote
Old 06-10-2013, 05:31 PM   #25259
g.mccormick
g.mccormick's Avatar
Oddometer: 190
Power or lack there of
I put new sprockets on and went +2 in the rear. Still this thing is a big slouch. '06 TE610.
Last night I triied and could not get it about 90mph in about 1mile run.
I haven't looked in the carb, but assume it to be stock jetting.
g.mccormick is offline   Reply With Quote
Old 06-11-2013, 04:42 AM   #25260
1 lunger
1 lunger's Avatar
Oddometer: 1,338
Sounds like something's just not right? These bike are a bit heavy, but slow they aren't. They will pull top speed about a fast as you can shift them.
1 lunger is offline   Reply With Quote
Times are GMT -7.   It's 05:49 AM.
