Old 06-11-2013, 08:59 AM   #25261
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 2,980
Originally Posted by g.mccormick View Post
I put new sprockets on and went +2 in the rear. Still this thing is a big slouch. '06 TE610.
Last night I triied and could not get it about 90mph in about 1mile run.
I haven't looked in the carb, but assume it to be stock jetting.
Originally Posted by 1 lunger View Post
Sounds like something's just not right? These bike are a bit heavy, but slow they aren't. They will pull top speed about a fast as you can shift them.
What he said.
I actually liked it's ability to accelerate better with stock gearing than with lower dirt gearing.
bobnoxious67 is offline   Reply With Quote
Old 06-11-2013, 09:20 AM   #25262
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,192
That's about right for a 47 tooth rear. 102 mph with a full load of camping gear and a 45 tooth rear, it helps to really wring it out in 5th:
Edit: Stock jetting, Uptite slip-on.
Old 06-11-2013, 02:00 PM   #25263
Dr Klaun
Dr Klaun's Avatar
Oddometer: 439
Originally Posted by huzar View Post
For those of you running a Giant Loop Fandango or Diablo tankbag, where did you attach it to on the left-hand side? I had it running over the top of the exhaust heat shield and down to my DirtBagz bracket. Seemed to work well for about 500 miles, but today the strap running over the head shield melted. I'm not seeing another good location to attach it, unless I ran it all the way down to the left lootpeg, which seems weird...
I also ran mine down to the left passenger peg bracket over the OEM exhaust pipe cover. I used some stick on heat wrap tape (2" wide) around the strap. It has held up well (1500 miles), but with the grit trapped between the two surfaces, the heat shield looks like it's been power sanded.
Since I just got done mounting up the Safari tank, I need to come up with a new mounting option for the rear straps to the bag (I never liked going over the exhaust anyways...). I'm going to run a piece of 1" webbing (strap) under the rear of the tank with the female 1/2 of a fastex buckle sewn on each site. Then I'll thread the male end through the GL straps, so I can take the base piece on / off much quicker. Their design is a bit over engineered with the strap routing...
- Matt
96 R1100RSL (red)
08 TE610
Dr Klaun is offline   Reply With Quote
Old 06-11-2013, 02:38 PM   #25264
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
I also have the Safari tank, so post a pic of your solution
huzar is offline   Reply With Quote
Old 06-11-2013, 08:10 PM   #25265
Dr Klaun
Dr Klaun's Avatar
Oddometer: 439
Will do. I'll be sewing the strap / buckles up tonight.
On a side question, I've yet to ride with the GL tank back on the Safari. It doesn't seem like it sits all that well... Have you had issues with the fuel cap breather hose since it gets bend underneath? teh GL buck and roll tank bag may be a better solution, but I really like to have a map case.
- Matt
96 R1100RSL (red)
08 TE610
Old 06-11-2013, 08:16 PM   #25266
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
I had it such that the bag does not overlap the fill cap at all. That does mean that the bag rides further back than is optimal. Like you, I'm beginning to think the Buckin' Roll might be a better solution...
Old 06-11-2013, 08:37 PM   #25267
Dr Klaun
Dr Klaun's Avatar
Oddometer: 439
I don't think I'd want it that far back - it already seems a bit in the way with the front of the bag over the cap. I'm just concerned that the movement will pull out the breather hose. Maybe I'll add a zip tie to it.
In any case, I'll have a pretty good report on it after this weekend. Will be heading to the OR Beemer Rally in John Day on Thursday morning for 4 days of riding. Should be a good test for the tank and new TT X2 HID headlight.
- Matt
96 R1100RSL (red)
08 TE610
Old 06-11-2013, 09:52 PM   #25268
Dr Klaun
Dr Klaun's Avatar
Oddometer: 439
Here's the final deal - looks like it'll work OK.
First: Here's the previous solution, with heat wrap tape on the straps:
This shows the wear on the heat shield. Not a big deal...
The new strap: 1" webbing with buckles:
Feed it behind / under the tank:
Then tighten things up!
Mount the bag:
Left side close up:
Right side:
Here's the fuel vent hose:
New X2 HID with home made shield.
That's about it. Will post some feedback when I get back!
- Matt
96 R1100RSL (red)
08 TE610
Old 06-11-2013, 10:03 PM   #25269
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
Looks good, Matt. I'll give that a go
Old 06-14-2013, 05:12 AM   #25270
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,439
Pm me your email address
I can send you Picts of my mounting solution. I don't use a photo hosting site to put the Picts up here
ebrew is offline   Reply With Quote
Old 06-14-2013, 02:56 PM   #25271
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
So ebrew sent me the pics, and it's a pretty neat solution, so I thought I'd post up the pictures he sent me:
I used the passenger peg bracket ( u shaped part) then got the shackles at Home Depot. They work great
image-1 by Marcin Porwit, on Flickr
image by Marcin Porwit, on Flickr
image-3 by Marcin Porwit, on Flickr
image-4 by Marcin Porwit, on Flickr
image-2 by Marcin Porwit, on Flickr
huzar screwed with this post 06-14-2013 at 03:01 PM
Old 06-15-2013, 05:42 PM   #25272
xymotic
xymotic's Avatar
Oddometer: 8,368
Cam gear locktite?
Do I need locktite on the cam gear to camshaft bolts? Red? Or are they just powered on there? From memory it's like 90 ft # right?
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 06-16-2013, 08:49 AM   #25273
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,192
Yes, red. I just give them a good tap with the impact gun and red Loctite.
Whassup? Going someplace cool?
Old 06-16-2013, 12:17 PM   #25274
xymotic
xymotic's Avatar
Oddometer: 8,368
Nope, just finally trying to give the bike some much-needed luv. I **HOPE** to make at least one good ride this summer but I dunno.
You got anythng in the works?
Albert Einstein
6:10 to Yuma
Old 06-16-2013, 03:31 PM   #25275
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,192
No, nothing that interesting...Goldwing trip next week, DV in the fall on the GS...keeping my ear to the ground for a zero mile 2007 610.
Dying for a 2013 Beta 520, too cheap to pull the trigger.
Times are GMT -7.   It's 03:12 AM.
