Old 07-16-2013, 09:48 PM   #25396
uska
uska's Avatar
Oddometer: 169
Originally Posted by TIGERRIDER007 View Post
Thanks, I'll take a look at riser options and different handlebar dimensions, I need to bring these stock bars up a bit, for standing...
I do have a new (used for one ride) motosportz riser set. I believe they're 1 1/8" rise and all the cables were fine with those. Had to take them off since i bought a scotts damper for which i had to buy different clamps. I could throw in the 08` bar clamps as well if you would like. Pm if interested.
uska screwed with this post 07-17-2013 at 08:28 AM
uska is offline   Reply With Quote
Old 07-17-2013, 06:07 AM   #25397
Taranis
Oddometer: 379
Originally Posted by g.mccormick View Post
Where did you get the Renthal from?
Rocky Mountain.
DIRT BIKES ARE FUN AND INTERESTING
Taranis is offline   Reply With Quote
Old 07-17-2013, 06:09 AM   #25398
Taranis
Oddometer: 379
My side panel is melting all over the muffler. When riding and squeezing with my knees, it pushes the panel right against the hot muffler. Do the aftermarket mufflers (without cat) stay cool enough to keep the from happening? Anyone have a heat shield option?
There's originally a little rubber bumper that's supposed to prevent this from happening. It doesn't work.
The forward carbon fiber hanger on the LV holds the plastic away from the metal can, so no more melty.
Old 07-17-2013, 08:26 AM   #25399
flyrodder
Donny, please.
flyrodder's Avatar
Oddometer: 3,156
Did a little trail riding yesterday. It's been about 10yrs since I've done any offroad riding. The TE goes pretty well, I was wishing for a motocrosser though.
Yeah, but go down the highway for 60 miles or so on an MXer.
"It's sorta like a combination of camping in your Grandma's back yard, and a Frat party. " --fifthcircle 2015 Filth Fest
flyrodder is offline   Reply With Quote
Old 07-17-2013, 08:57 AM   #25400
1 lunger
1 lunger's Avatar
Oddometer: 1,301
Just ordered some ASV shorty levers for the 610. $220 for the set from ASV direct. Is that a good price? Or should I have shopped around?
1 lunger is offline   Reply With Quote
Old 07-17-2013, 10:55 AM   #25401
1 lunger
1 lunger's Avatar
Oddometer: 1,301
What's the thought on running a non O-ring chain on the 610 since I'm only ever riding off road? I wash and oil my oring every ride and would take care of a non oring the same way.
Old 07-17-2013, 12:02 PM   #25402
uska
uska's Avatar
Oddometer: 169
Which bike levers did you get? Because I don't think they list huskys. Did you get the clutch perch too?
What's the advantage of running a non o ring chain?
Old 07-17-2013, 06:08 PM   #25403
1 lunger
1 lunger's Avatar
Oddometer: 1,301
Called ASV direct and got the lever and perch ( pro 3 ) clutch and just the brake lever. I'll post up part #s and review when I get them. As far as the O-ring non O-ring, I feel like the O-ring gets trashed and traps grit.
Old 07-17-2013, 07:47 PM   #25404
uska
uska's Avatar
Oddometer: 169
Did you get the shorties? I was thinking of cutting mine but I will end up with the asv ones since I will soon know the part #`s.
You asked if you think you overpaid.. I think most companies charge more if you buy it from them directly. For example JD tuner from JD is $220 / motoxotica $200. Scotts damper from scotts, over $640 / the whole kit from brp was ~$550, ppegz $169/$130 from amazon. Pretty huge savings just by looking around.
Have you ever considered a left hand rear brake? Rekluse sells one for the te511 but I'm not sure if the rear MC`s are the same on the bikes
Old 07-17-2013, 07:53 PM   #25405
uska
uska's Avatar
Oddometer: 169
Is anyone having problems ordering husky parts from their local BMW/husky dealer? Its been two months since I can't order from BMW/husky of countryside, IL. I know KTM tried to push BMW to sell husky/ktm`s, maybe that's causing it?
Old 07-18-2013, 04:41 AM   #25406
1 lunger
1 lunger's Avatar
Oddometer: 1,301
Yes, the shorty ones. I was looking at doing the LHR brake with auto clutch, but where I ride, I can stay in 2nd gear 80% and never shift and I've heard mixed things on the autos w/ the big bores, so for now I'm keeping the clutch. However, the ASV lever will fit the hydro conversion w/ small mod, so it will work if I do change over.
Old 07-18-2013, 05:40 AM   #25407
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 1,051
oil filter
1Lunger, I'm getting ready to change the oil in my 06' and was curious about oil filters...is there a number of choices as far as aftermarket or other oem models that will work for the husky?
I have a yam, honda, kawa, ktm dealer pretty close to me....I was going to get a filter and some Spectra 20w50 to do the oil change.
Anyone else have info? Thanks, I appreciate it.
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 07-18-2013, 06:00 AM   #25408
1 lunger
1 lunger's Avatar
Oddometer: 1,301
10w60 is what the 09 calls for. I like the Motul full syn. For filers I like the Hi Flo and I think the pre 08 bikes use the158 model. Be sure to check the bag filters. The clutch side is not really necessary, but not a bad idea. The stator side is every other time.
Old 07-18-2013, 09:25 AM   #25409
TIGERRIDER007
Oddometer: 1,051
Thanks good people, last question (yea right!)....
How much oil will this 06' beast take? 2.1 Quarts?
Thanks again, oh, and got a hi-flo..
Scott
Old 07-18-2013, 09:34 AM   #25410
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,024
1.6-1.8 Quarts, engine has to be super dry to get 1.8 in it.
I found the right side screen to be the most important one to check, it can break and is the last line of defense for the oil pump.
larryboy is online now   Reply With Quote
Times are GMT -7.   It's 11:04 AM.
