04-23-2007, 06:15 AM
#751 |
Hooplehead
Oddometer: 820
XFool, very nice piccies, looks like fun.
04-23-2007, 08:00 AM
#752 | |
Follow me
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE Robert rwamf homepage |
04-23-2007, 09:39 AM
#753 |
Paint it black.
Oddometer: 12,870
Well, I got an answer from Pro Moto Billet. I'd asked for dimensions on their end caps so I could adapt one. They don't want to talk about dimensions. Looks like I'll have to find a shop that stocks a few and see what's close in size. It wouldn't be that hard to massage an aluminum pipe to fit a different end cap.
Yeah, it does have a cat in it, but that isn't marked either. That makes ME feel better, at least I won't be starting fires. I just don't want to have to argue with the man...and as loud as this thing is it's bound to happen. |
04-23-2007, 11:42 AM
#754 |
Hooplehead
Oddometer: 820
Get a hold of an 07 pipe from someone selling one. Those have the little sheild built on to them.
04-23-2007, 11:51 AM
#755 | |
Oddometer: 1,702
Dan |
04-23-2007, 11:52 AM
#756 | |
Oddometer: 1,702
I really like the idea of making the pipe more quiet... Dan buffallodan screwed with this post 04-23-2007 at 12:05 PM |
04-23-2007, 12:24 PM
#757 |
Balding Gloriously
Oddometer: 566
Starting when wet
I reply to Ted about starting after getting wet. Sorry Ted, I'm still learning to navigate this site, missed your question. The first time I mangaged to get the bike up within seconds, not enough time for much water to soak in. Simply pushed it up an embankment as far as I could to get the front wheel up and triggered the starter a few times and she started right up!. The second time we were in the water longer and did the same thing but it would'nt start. Took the filter off and sprayed some WD-40 into the screen at the back of the filter while cranking the starter and Brrrraup! Squeezed out the filter and kept goin. WD-40 mini can never leave home without it.
04-23-2007, 01:14 PM
#758 | |
Dirty Old Mudder
Oddometer: 3,932
Tilt your bike up (wheelie) to make sure exhaust is free off water, remove sparkplug & use short burst's of magic button (preferably kickstarter if there is one), if no water comes out, then its safe to restart the engine. If you do have water in the engine, keep turning it over untill no more shoots out the sparkplug hole & check you oil, chances are good it'll need numerous fill ups & drains to get all the H2O out
We spend our lives chipping away at our ignorance :wisdom by Dakez Friendship is like peeing your pants, everyone can see it, but only you can feel the true warmth.: wisdom by ?? Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet 06 Husky TE510 |
04-23-2007, 01:24 PM
#759 | |
n00b-ish
Oddometer: 485
-Ted PS I just read that and I sound old. I got to snap out of it and get out there and get dirty!!
-Ted West '06 Husqvarna TE250 '82 Husqvarna 430WR '81 Husqvarna 250XC |
04-23-2007, 01:25 PM
#760 | |
n00b-ish
Oddometer: 485
04-24-2007, 01:50 AM
#761 |
Paint it black.
Oddometer: 12,870
Well, my 5.0 black tank showed up a day early. Figures I'm in the middle of another project.
I stopped by cycle gear and rifled thru their promoto billet spark arrestors until I found one that measured close to my rough measurements. I figured at 3.5" x 5" would get me close to the stock end cap. It did. I tried drilling out the rivets and popping the stock end cap off the pipe, I gave up since it looked like I'd booger up the pipe if I tried any harder. So I broke out the cut off wheel and sliced the end cap off. ![]() Darn close. ![]() That's going to look pretty good and take some heat off the turn signal. ![]() I need to cut off the stepped part for a better fit. ![]() I need some longer rivets and the use of the power tools to clearance the inside of the pipe for the screen cone...I'll give the fam a break and save the noise for later. The end cap fits so well that I feel much better about cutting up a brand new $130 billet part.
04-24-2007, 05:29 AM
#762 |
Oddometer: 1,430
That'a awesome...now let's get that tank on!
04-24-2007, 06:08 AM
#763 | |
Oddometer: 377
Bars
I was happy with the stock bars but bent them. For a replacement I wanted the highest bars I could find. The Pastrana’s are only slightly higher than stock and have a funky elbows out bend. Warning: The hoodlum elbows out bend will affect your road riding manners physically and mentally. |
04-24-2007, 07:11 AM
#764 |
Oddometer: 823
Larryboy, let us know how that sounds when you're done. It looks like it will be great
Wendell
Wendell You will never find a more wretched hive of scum and villainy....we must be cautious. |
04-24-2007, 07:18 AM
#765 | |
Oddometer: 1,702
Dan |
