Old 02-20-2009, 03:12 PM   #9646
mrkartoom
Lurker Extraordinaire
mrkartoom's Avatar
Oddometer: 828
Wonder how much light those LEDs put out. They make it sound good.
"white high brightness LED’s ensures exceptional visibility at night, and is produced by two groups of 10 LED’s, with two 20W spotlights placed in the center for optimal visibility."
It's pretty mean/alien looking. Looks like it came off a Cagiva Raptor.
"gotta have more cowbell" C. Walken
"I
spent 90% of my money on woman and drink. The rest I wasted." G. Best
'08 Husqvarna TE610, '11 Gas Gas EC300, '03 Beta Rev3 250
Husky TE/SM-610 Thread Index
mrkartoom is offline   Reply With Quote
Old 02-20-2009, 03:16 PM   #9647
kalebian
kip
kalebian's Avatar
Oddometer: 34
i can just see the little kid on the streat that sees that coming at him. "momy that scary monster tryed to get me!!!"
"what luck for rulers. that men do not think" Adolf Hitler
kalebian is offline   Reply With Quote
Old 02-20-2009, 03:19 PM   #9648
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,135
I thought it looked like a giant ant. (the black one)
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 02-20-2009, 03:24 PM   #9649
kalebian
kip
kalebian's Avatar
Oddometer: 34
aftermarket air cleaner
what is the best aftermarket air cleaner for the 610?
Old 02-20-2009, 03:29 PM   #9650
mrkartoom
mrkartoom's Avatar
Oddometer: 828
If you mean filter you can't go wrong with a Twinair. I'd have to look but I'm pretty sure that's what came on my '08.
"I
Old 02-20-2009, 03:36 PM   #9651
spanker
bada bing, capiche?
spanker's Avatar
Oddometer: 825
RustyRocket et al:
Originally Posted by Rusty Rocket
This makes me suspect that it has more to do with FI than the fuel. I had an Oldsmobile that had the block temp sensor go bad. This was the sensor that told the "brain" whether the engine need a "choke/enrichening". I don't know wether or not the FI Husqs have something like this built in or not but if it does, this could be the problem. Maybe it's putting in too much fuel, or maybe it's not putting in enough. The manufacturer probably assumed everyone was gonna leave the bikes in the barn till the temps went above 50.
I'm not sure of the level of sophistication RR. FI Husky's have a "choke." I always thought it was odd for an FI bike to have such a thing. I'm not even sure what it really does because I haven't looked to see if it actually operates the butterfly. But, one can assume that Mikuni recognized that a choke would "help" cold starting and actually put one in there. It suggests that the ECM is not very sophisticated and a manual device was the best (cheapest) thing to do. I have used mine on occasion, when it sits for a long time but take it off almost immediately. All I know is that I have gotten over 70 calculated mpg with a fully loaded bike in Geek's back yard this past TAT trip. I luv FI!
2010 BMW R1200RT, a sweet scooter for my daily 100 mile commute.
'08 Husqvarna TE-610, sold
waiting till I retire to get a new adv bike. meanwhile........
spanker is offline   Reply With Quote
Old 02-20-2009, 03:53 PM   #9652
kalebian
kip
kalebian's Avatar
Oddometer: 34
would you happen to know the part # or the webpage...
Old 02-20-2009, 03:55 PM   #9653
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,294
There are some videos on youtube showing them.
They don't put out sh*t for light.
Though the white LEDs might make you more noticeable to oncoming traffic.
here's a random one:
Old 02-20-2009, 04:32 PM   #9654
mrkartoom
mrkartoom's Avatar
Oddometer: 828
It's just a "fast idle" lever. It doesn't change the mixture or anything, since the FI take cares of that. Adds a few 100 RPM to the idle. I always use mine when the engine is cold, regardless of ambient temp.
"I
Old 02-20-2009, 05:23 PM   #9655
Beemer Pat
Oddometer: 2,722
Originally Posted by Geek
Good point! I forgot BeemerPat is running that setup too.
And Olas Atlas is running the cyclops.
Jeez... if I wanna be different... maybe I should mold my own
..... now that sounds like a good idea. I still have the side bracket's for my set up if ya need them. In my Motorcycle Consumer News they have a product review of a light relay kit that gives you more out put from your headlight. You will take a hit on the life of the bulb (Sylvania runing more than 12 V from 7500 to 1400 hours) but it could be worth it. The kit runs the bulbs at 13.68 V. It hooks right in with out having to cut anything. I might try this on the setup I have and lst ya know how it works. The name if the company that makes it is Eastern Beaver.... H4 Headlight Relay Kits.
Just a little update on my '08...... the battery is done. One year and kept inside in the winter. It will not hold a charge for long in the cold even riding it everyday. I've had to put it on the charger to keep it so it will start the bike. Picked up a Deka (gel) today and will put it in tomarrow. Two year warranty so we shall see how this one holds up.
Beemer Pat is offline   Reply With Quote
Old 02-20-2009, 05:24 PM   #9656
Beemer Pat
Oddometer: 2,722
Beemer Pat screwed with this post 02-20-2009 at 05:44 PM
Old 02-20-2009, 05:26 PM   #9657
lagcam
lagcam's Avatar
Oddometer: 731
Finally got around to doing something about my subframe. With a few pieces of .062 galvanized sheet (all I could find laying around) I bent up some L shaped brackets. Painted all the parts trying to ward off rust and oxidation, but we'll see how it holds up.
It seems much stiffer now with the whole thing sandwiched between the main subframe and the Dirtbagz brackets. Hmmm, looks like I could do a little cleaning under there...
I'm hoping this isn't too much load for the tail. There's a lot of weight in that bag full of camping gear. I refuse to give up my heavy air mattress!
Hmmm, looks like I could de-clutter the shop a little too...
lagcam is offline   Reply With Quote
Old 02-20-2009, 06:19 PM   #9658
mrkartoom
mrkartoom's Avatar
Oddometer: 828
I'm still on the original and haven't looked for a spare yet, but I'm guessing it may be hard to find other than at a Husky dealer. I looked on the Twinair site and didn't see one, but that doesn't mean they don't make it. Maybe someone else has purchased an aftermarket one.
"I
Old 02-20-2009, 06:40 PM   #9659
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,294
Hey Gents,
I'm going to put speed bleeders on the 610... anyone off the top of their head know which diameter the Husky uses?
7mm? 8mm? 10mm?
Old 02-20-2009, 06:45 PM   #9660
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,294
I bought a spare.. its a twin air.
We pulled the air filter out of a brand new 2008 610 on the show room floor to match it up (since the dealer couldn't figure out the part number).
The "from the factory" 610 had a twin air in it.. same as mine.
Times are GMT -7.   It's 10:02 AM.
