Adventure Rider
Welcome, lurker!   Even if you don't post, the system can help you find the good stuff faster if you register.
Go Back   ADVrider > Bikes > GSpot
Register Members Pics Search Today's Posts Mark Forums Read
Old 04-03-2003, 03:43 PM   #1
kevbo
Rubbery-Lip Flappin' PHI
kevbo's Avatar
Oddometer: 1,478
Changing an 1150 GS fork seal
Here is a quick procedure, doesn't even require removing front wheel. You do have to work inside the beak. I'm 6'5" and if I can get my big hands in there, anyone should be able to.
Sorry, no pictures, I did this in the dark, and it was windy, and didn't want delays adding to the grit.
Changing a 1150GS fork seal should be a 30 min. chore the first time, and maybe only 15 minutes the second time. Bout $30 in parts including a quart of BMW fork oil.
Step-0) put bike on center stand.
Step-1) Remove the cable clip which is around the top of the fork leg. That is not a normal zip-tie, don't cut it. It is reuasable, there is a small release tab. This is perhaps the most time consuming part of the job.
Step-2) Pry out the cap on the top of the triple-clamp. I used a pocket knife.
Step-3) Hold the fork leg with a 22mm open end wrench, and use a 14mm socket to remove the nut that was under the step-2 cap.
Step-4) Push the fork leg down, then bring it forward. Have a rag ready to put under bottome end which will be dripping oil. Then pull the leg upward and out. Be careful not to drop or scratch it.
Step-5) Pry the dust seal out of the slider. knife blade again to start it, small screwdriver to finish it.
Step-6) Remove the small wire clip which holds the seal in place. Small allen wrench makes good tool. DON'T drop it down the slider. Note that the seal is positioned so that the garter spring is visible.
Step-7)pry the old seal out. Screwdriver job. Use twisting motion rather than prying on edge of slider.
Step-8)
Either suck out, and replace the fork oil (470cc of BMW 7.5Wt.) or guess at how much came past the leaky seal, and squirt that much in there. Error on the skimping side.
Step-9)Install new seal, I used a 5/8" fender washer on a long bolt to push it home. Hand pressure was enough, no need to pound. Garter spring goes on top side.
Step-10) Put everything back togethor. Don't forget the snap ring.
Locktight on the top nut., torque to 45 Nm (~32 lb-ft) Yer done.
Sincerity is the most important thing. Once you learn to fake that, the rest is easy.
kevbo is offline   Reply With Quote
Old 04-03-2003, 04:25 PM   #2
RubberDown
RubberDown's Avatar
Oddometer: 2,286
sounds pretty painless. I don't remember ever seeing a service interval for replacing the fork oil...and there is no drain plug. Is that a "fill for life" kinda deal?
Eric
'01 R1150GS
RubberDown is offline   Reply With Quote
Old 04-03-2003, 04:59 PM   #3
kevbo
kevbo's Avatar
Oddometer: 1,478
There is a drain plug, AND it is supposed to be service free. Since the oil is not used for damping, it doesn't break down.
I looked like the slide bearings were some sort of plastic....nylon or maybe even teflon.
Old 03-12-2004, 01:28 PM   #4
Curmudgeon
Enjoying the ride
Curmudgeon's Avatar
Oddometer: 1,002
Oilhead fork oil is 10.0 Wt
Great advice, that matchs what the tech said at the local BMW dealer... Except!
Step-8)
The manual says:
Telescopic fork oil
– approved grades BMW telescopic fork oil
BMW Fork oil: 7.5 Wt
BMW Telescopic Fork oil: 10.0 Wt
Airhead fork oil is 7.5 Wt, but Oilhead Telescopic is 10.0 Wt.
Patrick
Live Long and Ride
Step-8)
Curmudgeon is offline   Reply With Quote
Old 04-08-2004, 01:22 PM   #5
johnjen
Mod-U-Later
johnjen's Avatar
Oddometer: 8,172
One additional note for all of you that have done this... No one mentioned bleeding off the air pressure from the re-assembled front forks... That will change the handling considerably... Just a thought..
JJ
Originally Posted by Javarilla
referring to my avatar…
That is the illustration of the atomic flux of the lubricant in the semi-hemispherical aebleskiver therodynamic transfer mechanism under thermostress.
johnjen is offline   Reply With Quote
Old 04-08-2004, 01:32 PM   #6
Nailhead
Ice ice, baby...
Nailhead's Avatar
Oddometer: 2,037
Question Fork oil??
What on Earth is fork oil doing in a suspension like the T-lever? I thought that neat little external shock/spring negated the need for fork oil, seals, and the mayhem they INEVITABLY cause? I thought I was exempt from this!
- Chris
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
"In America, we like everyone to know about the good work we're doing anonymously." - Jay Leno
"If stupidity got us into this mess, why can't it get us out?" - Will Rogers
Nailhead is offline   Reply With Quote
Old 04-08-2004, 01:52 PM   #7
johnjen
Mod-U-Later
johnjen's Avatar
Oddometer: 8,172
The oil is for lubrication, not for hydraulic dampening. Less stiction that way.
JJ
Old 09-30-2008, 07:07 PM   #8
DruiD
riding too fast
DruiD's Avatar
Oddometer: 414
I just did mine. What a breeze! I can't believe I probably spent more time wiping oil off my forks than I did changing the seals!
DruiD
When he rode the first three corners before putting the front wheel back down, I knew we were in trouble.
DruiD is offline   Reply With Quote
Old 10-01-2008, 01:13 AM   #9
Bill the Bong
Supern00ba
Oddometer: 206
JJ
I agree. I took out the little grub screw with the o-ring at the top of the stansion while sliding it into the lower leg. Lot of air rushing out while pushing the stansion in. Don't know if not doing that would lead to the seal blowing out though
Bill
Bill
I'm not nuts, I'm condiments; I have been promoted: Murdoch
Bill the Bong is offline   Reply With Quote
Old 10-01-2008, 05:00 PM   #10
johnjen
Mod-U-Later
johnjen's Avatar
Oddometer: 8,172
Bill
Bill
The BMW manual calls for releasing the air with the tubes fully extended (ie on the center stand).
JJ
Old 03-19-2009, 07:34 AM   #11
matkal
Assault Commuter
matkal's Avatar
Oddometer: 968
Just did mine, very easy job. Thanks for the tutorial!
I just left the old fluid(PO used ATF) in there,
only one of my seals where leaking so I dumped a capfull in the non
leaking side and measured with a (clean) paint stirrer and a closepin,
and added to the other side to match. It's easy to see down there as the inside of the tube is white.
I used an automotive drum brake adjusting tool(kind of an S shaped prybar)
and a piece of hard rubber to protect the slider, to pry out the seal.
It took me about an hour.
'00 R1150GS, Yella
Helmet laws suck. They interfere with natural selection.
ATGATT 35:12-14
"And Atgatt courted Motgatt, and took her for a wife.
And lo, he compromised with Atgmott, and verily she conceived,
and did bear a son, Notgatt. And Notgatt roamed naked,
and did bequeath his skin to the roads. And he was a wild ass and an outcast,
and was hated through all the land. And his forehead was branded, and he did be
come a sign and a warning to all the people."
matkal is offline   Reply With Quote
Old 03-19-2009, 07:54 AM   #12
Mr Head
Pfying Pfig Pfilot
Mr Head's Avatar
Oddometer: 2,707
Send a message via Yahoo to Mr Head
- Chris
Without that oil in there the bike would wheelie way too easily.
...Dick
"Loctite is for people who don't own a cheater bar"
5 Years
Save $5 with Smugmug coupon:
F8vWgljcr2IPk
Mr Head is offline   Reply With Quote
Old 03-19-2009, 08:33 AM   #13
matkal
Assault Commuter
matkal's Avatar
Oddometer: 968
And then you'd be replacing the fork seals more often.
'00 R1150GS, Yella
ATGATT 35:12-14
Old 03-19-2009, 09:04 AM   #14
Mr Head
Pfying Pfig Pfilot
Mr Head's Avatar
Oddometer: 2,707
Hahaha, But, I know a "card trick" which usually works rather than just replacing the seal.
The other trick is to land the wheelie right. BMW is not replacing broken frames like on the gixxer one millions.
...Dick
5 Years
F8vWgljcr2IPk
Old 03-21-2009, 07:14 PM   #15
JTM65
JTM65's Avatar
Oddometer: 392
Grub Screw?
Can anyone tell me where to bleed the air out of the fork? That might explain why the front end on my 00 feels like the shock is a solid bar bolted in there. PO might have replaced a seal and not let the pressure out.
JT
00 R1150GS
SE USA (The Dark Corner)
Please don't try to project your delusions on to me, I'm much more comfortable with mine.
JTM65 is offline   Reply With Quote
vB code is On
Times are GMT -7.   It's 11:13 AM.
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ADVrider 2007
