Old 08-05-2006, 07:40 AM   #1
buffallodan OP
buffallodan's Avatar
Oddometer: 1,709
The "Husky 610 Jetting Thread"
This thread will be our place to post jetting results and questions to aid each other in dialing in the FCR. Post away
Dan
p.s. please include any modifications and your location please including altitude.
buffallodan is offline   Reply With Quote
Old 08-05-2006, 07:47 AM   #2
buffallodan OP
Oddometer: 1,709
I tried in vain to copy these post but gave up after 15 minutes of futility. Please click on link for relevant posts.
http://www.advrider.com/forums/showp...72&postcount=2
http://www.advrider.com/forums/showp...6&postcount=14
External Link
Jetting your 2006 TE 510 (LONG)
buffallodan screwed with this post 08-06-2006 at 08:46 AM
Old 10-22-2006, 11:40 AM   #3
Countdown
Oddometer: 5,328
What do you have?
If you re-jetted your 610, please share what you have along with your muffler and your riding elevation as they make a difference.
Jerry Counts
Countdown is offline   Reply With Quote
Old 10-22-2006, 11:41 AM   #4
Countdown
Oddometer: 5,328
SCfrank wrote
TE-610 with stock exhaust.
Bought JD jetting kit.
Changed Pilot to 42
Main is 172 (which is the stock size) - Kit says use 180 ?
Changed Needle to red with clip in 4th slot.
Ended up with 180 main. Red needle from JD Jetting kit 4th slot.
Pilot to 42.
This is pretty common. My elev. is 1000 ft.
I may try Jim's advice next, but it seems lean to me.
I'm at a 42 pilot, 170 main and a red JD needle from a KTM kit in I think the 4th from top clip slot, 1.5 out on the fuel screw and just under 1 sec. of AP squirt if that helps. (Thanks Jim !)
I don't know about the 170 main - sounds pretty lean to me.
I am at 180 main.
Jerry Counts
Old 10-22-2006, 11:42 AM   #5
Countdown
Oddometer: 5,328
OffRoute wrote
I've been riding my new TE610 between 6-8000 feet. All stock. I haven't noticed any stutter or flat spots. I just get a fair amount of popping on decelleration. Not sure what's normal with even a well tuned thumper like this. If my plug color looks good is there any real reason to chase down different jetting etc?
Jerry Counts
Old 10-22-2006, 11:48 AM   #6
Countdown
Oddometer: 5,328
Firebolter wrote
I think there has been a crap load of info about Jetting. Based on my reading and my personal jetting (I have a Sm610), I came up with the following.
180 Main
45 Pilot
Fuel Screw 3 turns out (minimizes decel popping and idles good)
JD Red needle at #6 position for the clip
Leo Slip on
Iridium Plug
Runs like a champ. Pulls hard and clean from Idle to redline.
I am in the sea level to 3K regime with 70-90 degree temps 60% humidity.
Jerry Counts
Old 10-22-2006, 11:49 AM   #7
Countdown
Oddometer: 5,328
Huskysm610 wrote
I posted a bunch of jetting info on speedzilla (dukepilot) and SMJunkie (huskysm610) for the SM610. Here are my current settings with LV full exhaust, some additional holes in my airbox cover and backfire screen removed:
185 Main
JD Red Needle at 5th position
45 pilot
Fuel screw about 1.5 turns out
Boyesen pump plate
Power Now Plus
This is at sea level.
Jerry Counts
Old 10-22-2006, 04:12 PM   #8
Countdown
Oddometer: 5,328
TE6 from thumpertalk wrote
IMO the 06 610's jetting is less of an issue than the standard muffler which is very bad for upper mid and top end power ie it kills it. I have a Barrett pipe on mine which transformed my bike from bad to excellent power-wise, but I imagine any decent muffler would deliver good results
I also changed things re jetting as I have drilled 5 X 30mm holes in the airfilter cover. I went to a #174 main from #172, stock needle on the 3rd groove from the top, and a #42 pilot down from a #50. As it is I think the bike runs a little lean on the transition from pilot to needle (bearing in mind the pilot is always affecting jetting to some degree right through the throttle range). I have noticed a massive improvement in both acceleration and steady throttle fuel economy, the hunting and lurching in low-load high-speed situations (such as downhill on freeways) has disppeared to the point where it is rare and no drama. Altitude is not really much of an issue with us South Australians as we call a 2000ft hill a mountain.
Hope this helps.
Jerry Counts
Old 03-16-2007, 04:33 PM   #9
CMWoody
CMWoody's Avatar
Oddometer: 5,248
Saw this in the sign in thread
Originally Posted by Ted West
I can't answer your question but I did get this info from another member and he said they were jetting specs from Malcolm Smith's shop for the 610:
OBDVP Needle - 5BE-14916-dp-00
60 leak Jet - 4jt-1494-f-11-00
42 Pilot jet - 019-008
Needle Screw - 5JG-14521-00-00
removed the A/P adjuster cap
Fuel Screw 1.5 out
I'm terribly rookie when it comes to jetting so I can't back any of this up nor have I done it to my bike. I just thought I'd pass it along.
My current settings. Not perfect but getting there.
Gutted pipe
185 main
45 slow
adjustable leak jet at 1 3/4 turns out
mix screw at about 2 turns out
OBDMM needle @ 5th clip
Getting it close to ideal. Still have a few more tweeks to do.
CMWoody screwed with this post 03-16-2007 at 09:11 PM
CMWoody is offline   Reply With Quote
Old 03-18-2007, 10:36 AM   #10
CMWoody
CMWoody's Avatar
Oddometer: 5,248
Gutted pipe
185 main
45 slow
Did a couple hours worth tinkering on the settings last night and came to the realization I was way too rich on the low end... Handy having a wideband O2 sensor shoved up the tailpipe
I'm going to drop to a 42 pilot next and I also have a LeoVinci slip on coming that'll change it a slight bit... Currently running the hacked and gutted stocker.
180 main
45 slow
screw at 1.25
OBDMM needle at 3rd clip
Getting a good 12-13 AFRs on the top end revving under no load...just trying to get her close for now. Still rich low down but not by too much. Lowering the needle smoothed out the transition and it really feels much better.
Old 04-03-2007, 10:40 PM   #11
valiant
I wanna go fast
valiant's Avatar
Oddometer: 10
2006 Te610e
I have just had my '06 TE610 dyno tuned and re-jetted to suit a Barrett slip-on exhaust. The maximum hosepower was only 48.5 which is seemingly short of the 53 stock HP stated by the manufacturer.
I would be interested to see dyno results posted by others.
valiant is offline   Reply With Quote
Old 04-16-2007, 03:52 PM   #12
buffallodan OP
Oddometer: 1,709
I would really appreciate you guys with a 610 to post your results here...I have ordered the LV slip on and need get a base to start from. I am at 500' but will be doing the TAT this summer and wonder what the jetting will need to be to allow for 12,000' of altitude? I am guessing I will need to set it for 5000' since that will be the average lower elevation for the western section of the TAT? TIA for any advice or specs you may have...
Dan
Old 04-16-2007, 05:32 PM   #13
spagthorpe
spagthorpe's Avatar
Oddometer: 14,662
I actually went with a smaller main than a lot of posts I've read on TT and on other sites. I had the JD kit, and although a lot of people use the red needle, I was better off with the blue. Also unplugged the TPS and used a Quickshot.
Best thread I've seen for this is on the Speedzilla site:
http://www.speedzilla.com/forums/gen...mpression.html
It's primarily about the SM, but as far as engine performance goes, same info.
spagthorpe is offline   Reply With Quote
Old 07-04-2007, 08:32 AM   #14
Magus
Never grew up...
Magus's Avatar
Oddometer: 96
Spark Plug reading
Just pulled my plug and will replace it with an iridium and thought I would throw it out to the group for comments as I do not have any experience reading spark plugs. I have been having continuing stuttering problems with the 610 even after installing the JD kit (LV exhaust installed) . Current symptoms are pronounced stuttering on acceleration in 1st through 3rd especially at higher RPMs in those gears and difficulty with stuttering at a constant throttle in the 4800 - 5200 rpm range. I can hard accelerate through a lot of the stuttering (sometimes) and roll-on in the higher gears from let's say 50mph to 75mph is smooth and powerful.
Main #180
Pilot #42
JD Red Needle 5th pos. from top
Stealth Racing AP Cover
Not sure where fuel screw is at
Sea Level - high humidity
I know there has been a lot of jetting discussion and there are a million variables, but I thought I would just add to the mix.
'13 Honda CBR500
'09 Aprilia RS 125
'06 Ducati Sport Classic
Magus screwed with this post 07-04-2007 at 04:25 PM
Magus is offline   Reply With Quote
Old 07-04-2007, 12:00 PM   #15
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,556
Looks rich to me. I'd start leaning it out until it runs better, then check the plug again.
Times are GMT -7.   It's 01:29 AM.
