Old 02-25-2007, 02:05 PM   #61
jmemmert
Oddometer: 33
Me Three!!! Mine is an Acerbis
jmemmert is offline   Reply With Quote
Old 02-25-2007, 02:19 PM   #62
TexBiker
TexBiker's Avatar
Oddometer: 815
Originally Posted by R_W
Still listening for anyone to say whether they have had blistering issues on the tanks, especially IMS
The tank I pictured earlier is one of the early plastic tanks that BMW put on R1100GS. It's notorious for bubbling paint and decals (the original paint was badly blistered and the decals were gone). However, I haven't had any issues with the bedliner after 3 months.
For prep, I just degreased the exterior and sanded the surface to promote good adhesion, then I sprayed three medium coats of rattle can bedliner and let it dry overnight.
Suppose you were an idiot...And suppose you were a member of Congress...But I repeat myself.
-Mark Twain
TexBiker is offline   Reply With Quote
Old 02-25-2007, 04:52 PM   #63
klr
scott
Oddometer: 166
I havent had any problems with gas blistering (been on a year now), but I dont know if the Line-X brand is the same stuff as the spray can. If you take all the plastic off yourself and sand the gas tank down (to remove the graphics), and take it to them, they will spray it for around $100. this stuff is tough as nails, too. Oh yea, you need to remove the petcock and gas cap.
klr is offline   Reply With Quote
Old 02-25-2007, 05:06 PM   #64
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
My weestrom panels and fenders were bedlined. It's hard to apply it nicely, so it looks rather ugly. It blends in into wee's general ugliness rather nicely.
666 is offline   Reply With Quote
Old 02-25-2007, 07:15 PM   #65
LaOutbackTrail
Certified Smartass
LaOutbackTrail's Avatar
Oddometer: 5,058
Why not just tape them up really well? I dont see the point to taking off... or am I missing something?
LaOutbackTrail is offline   Reply With Quote
Old 02-25-2007, 07:50 PM   #66
klr
scott
Oddometer: 166
the liner spray is very thick and hard, so while you could tape them up, it is easier to remove them (just two screws and two bolts), than to cut the tape off. You still have to cut the tape covering the holes
Old 02-26-2007, 10:09 AM   #67
cheekymonkey
born again jackass
cheekymonkey's Avatar
Oddometer: 148
Originally Posted by TexBiker
It's not a thumper, but it's bedliner:
Man does that ever look good !
"the dream of this is also make that the person can not make this trip can ride with me ..and use my eues for see and your theyre brain for understand"
ZOA
cheekymonkey is offline   Reply With Quote
Old 02-26-2007, 10:47 AM   #68
LaOutbackTrail
Certified Smartass
Oddometer: 5,058
But then you have two holes.. and what about the threads for the gas cap.... or are you talking about a differnt type of gas tank and bike?
Old 02-26-2007, 11:09 AM   #69
moto mike
who needs a front wheel ?
moto mike's Avatar
Oddometer: 363
NEWS FLASH
Yesterday i went to put gas in the tank one gallon at a time so i could mark off were the gas was on the tank and i can't see the gas level. When i had the tank sanded all the way down i was able to see the level but i guess you need more light or somthing. I'll still play with it and let you know if i figure it out.
Mike Moto
motorcycling is not a hobby, it's a passion
07 x challenge SOLD down to two bikes that sucks
07 1000 v-strom
06 honda crf250x
02 go-ped
It's all about motor bikes, always has been, always will be. (Long way down)
moto mike is offline   Reply With Quote
Old 02-26-2007, 12:24 PM   #70
dodgerdodger
Acountabilabuddy
dodgerdodger's Avatar
Oddometer: 1,564
Originally Posted by moto mike
P.S. I always look around garages when i look at photos so for those with the same sickness sorry for the mess but it's winter and this weekend i'll clean it up.
At least you put the bong away first ..........
[I][B]2000 XR650R
[COLOR=Blue]2001 WR426
2003 WR250F (Wifeys...)
2009 YZ250F
2012 1/2 sherco 3.0 Cabestany
dodgerdodger is online now   Reply With Quote
Old 02-26-2007, 12:47 PM   #71
Reformed DucFlogger
Inventor Of The Wheel Mk2
Reformed DucFlogger's Avatar
Oddometer: 1,445
Flash
My guess is that the opaqueness (word?) of the bedliner is an issue. I know they have such strips on the side of the Baja KTMs.
The position might also be an issue - on the Baja bikes they gave them on the sides from top to bottom just by the edge of the seats - it might allow more light in from the top.
Hey, hook up a bright blue led (suckers are BRIGHT) on the inside of the gas cap. hold down a button and a 3v AAA lights up the inside of the tank just enough to see the contrast. LEDs are low current, run cool and are sealed. A small hole in the gas cap, couple of leads around your breather hose to your battery & switch and Bob's your Aunt.
Damn near any solution is better than that POC gas level monitor that comes with the bike. Someone probably stole some parts off a random number generator to make the things.
"...who gives a rat fornication?"
Reformed DucFlogger is offline   Reply With Quote
Old 03-04-2007, 01:12 PM   #72
Reformed DucFlogger
Oddometer: 1,445
Gas Level
The obvious just hit me in the face re: best way to put gas view strips on 640A tank. Prepping my (640A) tank for paint and a gas view strip. Created one on each side (1/2" wide) of tank near seat. Strips were 'polished' with wet sanding up to 2000 grit. Just discovered this two-strip system enables light from one side of tank to highlight gas level on other. If I move my hand in front of the clutch-side strip, the shadow is clearly visible from the brake-side strip.The tank, unpainted, is just opaque enough it apparently needs some degree of highlight lighting to show the contrast between th empty and fuel-ladden sections.
Old 03-04-2007, 06:20 PM   #73
JStory
JStory's Avatar
Oddometer: 2,777
Does anyone know if there are any colors other than black available in rattlecans?
Jeff
"He who makes a beast of himself gets rid of the pain of being a man." Dr Samuel Johnson.
JStory is online now   Reply With Quote
Old 03-04-2007, 09:55 PM   #74
PlasticSun
Long Live The Supertanker
PlasticSun's Avatar
Oddometer: 331
Don't know about rattlecans but durabak is a spay on bedliner that comes either smooth or textured in mutiple colors.
durabakcompany.com
No affiliation just something I'm planning on using on my TT39 tanks.
PlasticSun is offline   Reply With Quote
Old 03-05-2007, 06:39 AM   #75
moto mike
moto mike's Avatar
Oddometer: 363
Dura back is what i used. I did not spray it on I rolled it or brushed it with pretty much the same results.
Mike Moto
07 1000 v-strom
06 honda crf250x
02 go-ped
Times are GMT -7.   It's 09:53 PM.
