08-14-2006, 04:33 PM
#1 |
"What exit?"
Oddometer: 320
KTM 640 Adventure "windshield" removal
I'm hauling a new-to-me 2003 640 Adventure in my Dodge van. Can someone suggest what tools I need to remove the plastic windshield?
The van's openning is 49" high. The mirror's will have to be removed too. Thnx. Magile |
08-14-2006, 05:38 PM
#2 |
KTM ADV640 Windscreen Removal
On my 2005 and my 2006 you need an 8mm socket for the two left and two right bolts in the sides of the main fairing, then the three screws around the top of the instrument panel must come off (don't lose the washers). CAREFULLY seperate the black top of the instrument panel from the lower fairing. There are rubber plugs that hold the pieces together, and the whole setyp is a bit delicate. The lower fiberglass fairing comes off forward, again CAREFULLY. The black top instrument panel stays on the bike.
Good luck. Jeff Rogers Rogersboyz@aol.com |
08-14-2006, 06:28 PM
#3 | |
Still alive...
Oddometer: 10,718
![]() But to remove your fairing, all you do is remove all six 6mm bolts with a 8mm socket... then pull up the lower "ears" of the black inner instrument panel, which lifts the locking tabs out of the 4 rubber grommets in the fairing. At this point, there is nothing holding the fairing in place... you don't have to unbolt the instrument panel. Pull (flex) the two fairing rear sections outward a bit to clear the mounting bracket... and pull the fairing straight off toward you. Takes about 3 minutes tops... or less time than it took to write this. And nothing about a KTM 640A fairing is either "delicate"... or fiberglass. That's it, C |
08-14-2006, 07:12 PM
#4 | |
SBS's #1 fan in January
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,261
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
08-14-2006, 09:29 PM
#5 |
90S on the bench
Mine's got the old 2 piece fairing. Sounds like the only difference is that the old ones have cap nuts holding the instrument pannel in place instead of press lugs.
If it's an old one, undo the 6 bolts and 3 nuts on the instrument pannel and pull the fairing up and towards you (standing at the front of the bike). Unplug the instrument panel quick connects and the indicators and you're done. |
08-14-2006, 11:27 PM
#6 | |
"What exit?"
Oddometer: 320
I just started combing thru the LC4 index...whew! There's tons of info there. There are a few things I'll do before hitting the road & trail - replace the chain & sprockets if they're are original, inspect the valves, and do a fresh oil change, any other recommndations? Gracias, |
08-15-2006, 12:13 AM
#7 |
90S on the bench
Get it serviced by a reputable shop, unless you're a confidant home mechanic of course.
08-15-2006, 09:24 AM
#8 | |
Still alive...
Oddometer: 10,718
C |
08-15-2006, 11:47 AM
#9 | |
Molon Labe
Oddometer: 6,287
Chris '03 KTM Adventure 640 '43 BSA M20WD |
08-15-2006, 12:06 PM
#10 | |
Still alive...
Oddometer: 10,718
08-15-2006, 03:38 PM
#11 |
wannabe
Oddometer: 1,472
hey creep your gonna make the lad rip off his turn signal wiring. at least inform him about the bullet plugs.
08-15-2006, 06:17 PM
#12 | |
Still alive...
Oddometer: 10,718
I replaced my stockers with waterproof, QD Deutsch connectors when I switched over to the LED turn siggies. Sorry Magile... I haven't had to dick around with the stock connectors in so long I forgot about them. They are not tough to disconnect... but they are a tiny bit fiddly to work with one hand. ... so shoot me.
08-15-2006, 08:06 PM
#13 | |
"What exit?"
Oddometer: 320
I didn't have to remove the fairing to fit it in the van. We cinched down the forks, tipped it sideways & let the air out of the front tire. It fit fine. It looks great in the garage already! - Magile |
08-15-2006, 10:01 PM
#14 |
90S on the bench
So show us already!
08-16-2006, 04:17 AM
#15 |
"What exit?"
Oddometer: 320
Ta-Dah !
Here it is, '03 w/ 11,900 miles -
