Old 05-23-2011, 06:24 AM   #1561
rodsram
rodsram's Avatar
Oddometer: 349
Street Legal
Hi Elfdowney;
I have a 650 R , and used some baja designs products but most of the electrical components came from Procycle.us.:
Battery Bag $19.95
Battery 3.7 A Hrs 12v $49.45
Wire harness - ASM-HARNESS, Dual Sport $179.95 (it came with the switches)
Signal mounts front $8.95
Flasher Unit 49.95
Turn Signal Pack of 4 $29.90
Baja Deigns:
Mirror
Billet mirror mount
Horn
Flasher mount sleeve
Hope this helps you out.
Rod
'07 R 1200 GS.
'96 KLX 650 R.
Keep It Real!
rodsram is offline   Reply With Quote
Old 05-23-2011, 06:35 AM   #1562
elfdowney
Oddometer: 4
Re: Baja Designs
Mr Rodsram... THANX!!! That's EXACTLY what I was needing!
elfdowney is offline   Reply With Quote
Old 05-23-2011, 08:28 AM   #1563
Petrolburner
Noise Maker
Petrolburner's Avatar
Oddometer: 560
Decent price on the tanks...
2007 Honda XR650R, 2005 Gas Gas EC 250, 2004 Sherco 2.9, 2002 aprilia ETV 1000 Caponord, 1993 Kawasaki KLX 650
Petrolburner is offline   Reply With Quote
Old 05-23-2011, 08:46 AM   #1564
Myway
Myway's Avatar
Oddometer: 3,099
Rerun Tank
AU dollar, i believe
OZ what's that?
Myway is offline   Reply With Quote
Old 05-23-2011, 09:46 AM   #1565
Hayden#69
Oddometer: 254
Myway.
OZ is slang for Austraila.
Hayden.
Hayden#69 is offline   Reply With Quote
Old 05-24-2011, 08:59 AM   #1566
Pete in PA
Getting dirty....Again.
Oddometer: 69
Just found this stuff: http://www.b3cfuelsolutions.com/ Ethanol shield. put in 1 ounce at fill up and no more draining your carb to start when it's sat for a week or more. Improroved power and gas mileage also. I've got it in every engine I own now, 2-stroke or 4.
If you can find the big bottles (16 ounce) it's less than $1 an ounce. Home Depot has the small bottles which are good to keep for each dose. I get the big bottles at my local mower, weedeater, leafblower etc. store.
The stuff is awesome.
94 Kawasaki KLX650C 21k miles. Shinko 705's, snorkel removed, lid on, K&N filter, stock muffler bored out, 155 keihin main, 42 pilot, stk needle shimmed .045, 3 turns on screw, slide hole 1/8th in. runs like a beast.
06 Honda ST1300
Previous Hondas: 98 CBR1100XX, 97 XR650L, 85 V65 Sabre, 83 650 Nighthawk.
Pete in PA is offline   Reply With Quote
Old 05-25-2011, 08:54 AM   #1567
F.I.B.
F.I.B.'s Avatar
Oddometer: 69
E-start conversion
A question to those who have converted a 650R to electric start.
Is it worth it?
I have a KLX 650C ( 93 US)motor as a parts donor, but from what I have read there were some other problems to resolve.
Mark
"I figure if one of us is going to be pissed it may as well be her"
F.I.B. is offline   Reply With Quote
Old 05-25-2011, 11:00 AM   #1568
Petrolburner
Noise Maker
Oddometer: 560
Street tire sizes?
Doing a long pavement trip later this summer with my brother (Triumph 800XC) and Dad ('86 Honda Goldwing) on pavement only. Looking for a set of pavement tires, not dual sport 50/50 or 90/10 BS. Probably going to get some cheap Shinkos. Question is what size rear tire can I fit on the stock 17 inch rim? Might do a track day in the future. I know at some point going too wide for the rim changes the profile, so probably no wider than a 150. Also wheelspin isn't an issue so I guess it doesn't need to be that wide. Just looking for more options in sizing. I'm going with a 90 90 21 up front so the speedo isn't any farther off than it already is from the factory I'm also looking to get a little better cruising RPM at speed so was thinking a 130 90 17 instead of the 130 80 17. Thoughts?
Old 05-25-2011, 02:25 PM   #1569
Underboning
Underboning's Avatar
Oddometer: 720
Free KLX-650C shock
Does anyone have any interest in a KLX-650C shock? We replaced the stocker with a shortened Progressive and I have been carrying the stocker around in case we ever un-motarded it. But since we sold the bike a few months ago I no longer have any need for it. Had about 9K miles on it when removed from the bike. Free to a good (or bad) home if you pay the shipping or you can pick it up in PDX.
Underboning is offline   Reply With Quote
Old 05-25-2011, 03:22 PM   #1570
richarddacat
helmet full of Blues
richarddacat's Avatar
Oddometer: 3,317
I've added a 16T CS (43T rear) sprocket and it's a perfect match, IMO for road use. I also have mounted a 140/80/17 Shinko's 705's. As far as the front I'm using a 110/80/19. Tires feel great, no complaints, we'll see about the mileage.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is online now   Reply With Quote
Old 05-25-2011, 03:57 PM   #1571
itsatdm
itsatdm's Avatar
Oddometer: 4,825
I think the 130/90 is the recommended tire. I have run D606 and Pirelli's in that size without a problem. I don't know what is available in a more street orientated tire in that size. If you find a tire you like, you can upsize the front sprocket to a 16 for highway travel. I have one, same as the KLR but to fit it, you need to mill down the middle bolt boss under the sprocket cover. A drill and large bit will do it. You can buy a sprocket nut for the KLR that does away with the lock washer and is reusable so changing sprockets is a 15 min job.
Old 05-25-2011, 04:36 PM   #1572
richarddacat
Oddometer: 3,317
I've been told a 140/80 is the largest size that will fit on KLR's and KLX's.
Mid-TN Tag Riders
richarddacat screwed with this post 05-27-2011 at 07:31 PM
Old 05-25-2011, 11:44 PM   #1573
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,226
650c owners
Klx650c owners your swingarm, it looks a lot like my klr650c swingarm.The slider adjusters etc look very similar.Could some one measure up from the rear of the arm to the pivot centre and the distance between the swingarm sides at the the rear wheel.Also the width of bottom shock mount at the knuckle.I'm interested in the drz shock conversion and klx wheel inalterability's with the klr.
here's a klr650c
WILL_S is offline   Reply With Quote
Old 05-26-2011, 02:54 AM   #1574
Myway
Myway's Avatar
Oddometer: 3,099
here's a klr650c
Before we all MEASURE.
there a lot of ifs when you have..........
I don not see why a klx swingarm should do better the job.
Why not find a aftermarket shock from another bike for the KLR
how long eye to eye is your shock.
what is the shock stroke.
and what is your inside measurent of the lower fork from your shock.
there more +/- 430 mm shocks to get and also +/- 460 mm shocks
But is there a place for the sidepot off the shock
The frame is more narrow than that place on a klx.
Myway screwed with this post 05-26-2011 at 03:07 AM
Old 05-26-2011, 10:18 AM   #1575
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,226
Thanks for the reply.405mm but 430 fits. A WP shock off a lc4 fits and there is room for the sidepot.Drz stuff is a lot more commom and cheaper.
Times are GMT -7.   It's 05:54 PM.
