Old 06-02-2011, 03:19 PM   #1591
Myway
Myway's Avatar
Oddometer: 3,154
Originally Posted by Fogo72 View Post
Hey MYWAY, new Mod for this, KLX650R. Screw in a fitting into the bottom of the air filter box with a small hose off it that goes down to your chain. New chain oiler,
NOWAY, that's makes it sticky, for dust and dirt.
I use no oil on the chain, only real teflon, that dry's.
Chain keeps clean now.
Myway is online now   Reply With Quote
Old 06-03-2011, 10:45 AM   #1592
rodsram
rodsram's Avatar
Oddometer: 350
Thanks chaps.
'07 R 1200 GS.
'96 KLX 650 R.
Keep It Real!
rodsram is offline   Reply With Quote
Old 06-03-2011, 09:39 PM   #1593
Petrolburner
Noise Maker
Petrolburner's Avatar
Oddometer: 599
so here is a pic of when i first got the idea of trying my 125 fender on the KLX
Here's another pic of the black one
2007 Honda XR650R, 2005 Gas Gas EC 250, 2004 Sherco 2.9, 2002 aprilia ETV 1000 Caponord, 1993 Kawasaki KLX 650
Petrolburner is offline   Reply With Quote
Old 06-03-2011, 09:44 PM   #1594
Petrolburner
Noise Maker
Oddometer: 599
New tires today!
Got 3200 miles out of my rear Michelin T63, front is still good for at least another 3k.
Trying out a Kenda Trakmaster II, I'll let you know on the miles I get out of it.
I ride about 50/50 or 60/40 Street/Dirt
Threw on a set of EBC Red carbon graphite brake pads front and rear too.
Petrolburner screwed with this post 06-03-2011 at 10:05 PM
Old 06-03-2011, 10:00 PM   #1595
Petrolburner
Noise Maker
Oddometer: 599
Broke my chain guide, so bought this one off eBay for $20, not too impressed with the quality, but it is a full box instead of just one single sided piece like the factory C piece. Not quite sure if I'd recommend it yet. It wasn't the right width, I had to make a spacer by cutting up what was left of my stock guide. Also, just FYI, I rode hundreds of miles offroad with a broken chain guide, with the chain set at the proper tension, and I never had any issues with the chain falling off.
http://cgi.ebay.com/ebaymotors/ws/eB...T#ht_500wt_956
Old 06-04-2011, 06:47 AM   #1596
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
Luggage racks for "R" model
Hi guys, I started making 2 rear luggage racks for both my "R" model bikes today. I used 20mm x 5mm alloy flat bar for around the edge and security alloy mesh for the infill and got them welded in. I have to start making the legs for them now but I thought I better straighten my rear sub frame first.
Cheers Fogo.
Heres a few pics.
Fogo72 is offline   Reply With Quote
Old 06-04-2011, 07:36 AM   #1597
Petrolburner
Noise Maker
Oddometer: 599
Looks good, plans for attaching it to the frame?
Old 06-04-2011, 09:54 AM   #1598
Myway
Myway's Avatar
Oddometer: 3,154
@fogo, also think about a another seat connection, for easy oilfilter change, so your luggagerack can still be attached to the sidepanelbolts.
Something like this.
Old 06-04-2011, 07:42 PM   #1599
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
[QUOTE]
Something like this.[/QUOTE
That a sweet mod Myway.
I have rubber mounts that I use to mount my rear fuel tank so I will just pick up them. I have drilled out the thread in the seat mounting nuts and drilled right through the inner rear gaurd from the inside with a 1/2" drill. I put a 8mm allen hex bolt from the inside and push it through the seat mount and seat lug and side cover so it hangs out the outside about 1/2". Then I have rubber mounts ( see pics ) that I screw on the secure the seat and side panel. On the end of the rubber mount there is another thread to mount what you like. I use this system to mount my rear 12 litre alloy fuel tank and my clothes bag goes on top. I did a 5000 klm trip and it gave me good movement and saved my subframe from cracking. Myway nice seat mod but when I am all packed up my saddle bags sit over my seat so everything has to come off anyway
Cheers Fogo....
Old 06-04-2011, 08:18 PM   #1600
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
How to make a windscreen for an "R" model.
Guys I made two new windscreens for my 2 "R" models today, I'll show you how I did it.
Order a sheet of 2mm Lexan, 300mm x 300mm
Mark two lines down the sides 45mm from the edge.
Put the lexan in a vice between two bits of angle iron and heat the marked line with a heat gun and bend to 45 deg's.
Mark out shape and sand back edges smooth with file and sand paper and mount to headlight shroud, remove protective film.
Stand back and check out your work.
Holy shit Batman am I seeing double?
Cheers Fogo...
Old 06-05-2011, 02:06 AM   #1601
Myway
Myway's Avatar
Oddometer: 3,154
Are these white radiator screen original?
Old 06-05-2011, 03:19 AM   #1602
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
Myway
Myway, yes the radiator gaurds are original with the 2001 model in Australia.
Cheers Fogo...
Old 06-05-2011, 11:43 PM   #1603
dunno_where
130km open roads!
dunno_where's Avatar
Oddometer: 304
Great photo! Your KLX650's still have show room shine about them. Love the screens. I've made the same for my DRZ400E. They work a treat too.
"You do not need a therapist if you own a motorcycle, any kind of motorcycle!" - Dan Aykroyd
2014 Kawasaki Ninja 1000 ABS Sport-Tourer
dunno_where is offline   Reply With Quote
Old 06-15-2011, 10:01 PM   #1604
Petrolburner
Noise Maker
Oddometer: 599
Got my street tires mounted up, pretty fun. Long road trip to Boise this weekend.
Old 06-16-2011, 01:37 AM   #1605
Myway
Myway's Avatar
Oddometer: 3,154
Times are GMT -7.   It's 01:47 PM.
