Old 08-21-2011, 05:03 PM   #1921
scorp88
Wanabe outlaw
scorp88's Avatar
Oddometer: 90
Wicked
Hmmm... somehow the whole wicker thing got right past me
scorp88 is offline   Reply With Quote
Old 08-22-2011, 04:24 AM   #1922
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,540
Hey Cuddly, went and met an old KLX650"R" fan today that invited me to come and have a ride on his bike. He was interested in my electric start conversion and I was interested in his engine mods. My bike is about 48 - 50 hp and he said his bike runs on the dyno at 65 hp at the rear wheel.
He gave me lots of info, he owns a Kawasaki dealership a few hours away. His bike just sits in his shed now with a sheet over it.
Cheers Fogo...
Fogo72 is offline   Reply With Quote
Old 08-22-2011, 08:09 AM   #1923
Myway
Myway's Avatar
Oddometer: 3,101
what do you want? reliability in the outback or high..........bike
more hp more change of left crankshaft problems and rod connecting problems they tell.
but de late US R models has original 58-60 hp.
Myway screwed with this post 08-22-2011 at 08:52 AM
Myway is offline   Reply With Quote
Old 08-22-2011, 09:03 PM   #1924
muddriller
Oddometer: 97
Is the wossner piston necessary?
Hi Fogo: You wrote about your bigbore with a Wossner piston. What are the advantages to this piston as opposed to the Vulcan 1500cc piston used by others? Has anyone bored and sleeved an R cylinder to accept a big bore?
Todde
Every sailor knows, that the sea, is a friend made enemy. And every shipwrecked soul, knows what it is, to live without intimacy.
muddriller is offline   Reply With Quote
Old 08-23-2011, 06:06 AM   #1925
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,540
Todde
I have never used or seen a vulcan piston so I can't comment, but a few months ago my bike blew a head gasket and slowly dumped its coolant out the exhaust, I didn't know at the time, I was chasing down a friend in front of me and held my bike flat at 170 kph for about 10 klms and the engine started to get tight and lose power I backed off to 80 and let her cool down then came to a stop to investigate. No rivers or creeks anywhere so I rode it home about a distance of 40 klms. When I took the top end apart to investigate there was not one score or scratch up the liner or on the thrust side of the ceramic shirt of the piston, bloody brilliant, there, proven quality right there. Standard piston and rings are crap, any predetonation snaps out the ring land of the 1st and 2nd position while constantly slobering into the air box unable to control the oil on the cylinder wall and hold back the combustion pressures. For a career I am a mechanic that specialises in high HP electroniclly controlled diesel engines over 2400 horsepower, so after 20 years I have managed to learn what the ass end of an engine looks like.
As for the rebore of the "R" whats the problem, Lock it to a boring bench, send the boring bar down through it to the correct size to be an interferance fit and press a "C" model liner straight in. LA sleeve in the USA were selling them for about $75. Done, easy.
Your call buddy, its your bike, put what ever you want in it. Your best tool is
Cheers Fogo...
Old 08-23-2011, 09:36 AM   #1926
itsatdm
itsatdm's Avatar
Oddometer: 4,833
The inmate to talk to about the Vulcan piston is Mark 53, either here or on the KLX site on Yahoo. He posted a lot of info on the Yahoo site. All I remember is the piston is of standard design vs short skirts for the Wossner. There seemed to be an initial concern about placement of the piston pin may increase side thrust and some question of the valve cut outs for clearance. I seem to remember he measured the head to determine clearance issues and potential CR.
It seemed to have worked well for him, as he has thousands of miles on it and is an advocate.
Old 08-23-2011, 10:43 AM   #1927
Myway
Myway's Avatar
Oddometer: 3,101
There also people using a xr600 hotrod and a wösner 102mm
because the xr rod is stronger.
Old 08-23-2011, 11:24 AM   #1928
MasterMarine
Oddometer: 1,556
Where is this info from? I have been on the Yahoo list for a long time and never read about that. Is there some other source of info?
I am probably going to rebuild my KLX sometime soon and am looking for as much info as possible about it.
MasterMarine is offline   Reply With Quote
Old 08-23-2011, 01:54 PM   #1929
Myway
Myway's Avatar
Oddometer: 3,101
[QUOTE=MasterMarine;16693728] Is there some other source of info?
QUOTE]
In Germany
Old 08-23-2011, 03:21 PM   #1930
Myway
Myway's Avatar
Oddometer: 3,101
http://topend.exblog.jp/tags/%EF%BC%...C%EF%BC%B8650/
read for yourself
Old 08-23-2011, 09:45 PM   #1931
MasterMarine
Oddometer: 1,556
I think I will have better luck with the forum in German! At least I know a little of that...
I can just scope out the pictures in the other one.
Thanks! Any more info in English?
Old 08-24-2011, 12:46 AM   #1932
Myway
Myway's Avatar
Oddometer: 3,101
you are lucky there is
Old 08-24-2011, 07:37 AM   #1933
3girlsdad
aka FiddyK
3girlsdad's Avatar
Oddometer: 364
1995 KLX650C Part Out
hey fellas, i've decided to completely part out my 95 klx650c. It's in the flea market. http://www.advrider.com/forums/forumdisplay.php?f=53. or you can go to my site with the pis here http://www.klx650.com/1995-klx650c-part-out/.
Thanks,
Paul
3girlsdad screwed with this post 08-24-2011 at 08:13 AM
3girlsdad is offline   Reply With Quote
Old 08-24-2011, 02:35 PM   #1934
dtdynamics
Oddometer: 44
Has anyone had issues with the starter clutch on these bikes? seems as though mine is on the way out. it seem to be iffy at engaging when starting and also sometimes seems to engage while the engine is running causing a horrible racket from the left side of the engine (atleast i hope its only the starter )
dtdynamics is offline   Reply With Quote
Old 08-24-2011, 08:24 PM   #1935
Mcgillacuddy
Up to no good
Mcgillacuddy's Avatar
Oddometer: 44
I just got back from a 981 mile round trip on my KLX. I am now going to go out, shoot that seat and bury it in my neighbor's yard.
"That nightrain is a mean wine".
Mcgillacuddy is offline   Reply With Quote
Times are GMT -7.   It's 05:27 AM.
