Old 09-12-2012, 07:10 AM   #2521
Lesharoturbo
Nerdly Adventurer
Lesharoturbo's Avatar
Oddometer: 1,172
Originally Posted by johnnycombat View Post
So ive got a 96 klx 650 and me needs a new clutch cable.....every shop in the area, Huntington Beach, CA, says its special order only and i get that due to nature of the bike........ Will any other cable from any other model work or am i stuck to special ordering one only??
HELP!!
I ordered mine, the local store could not even spell KLX650.
The good news is it was stock and only took 2 days to get tome.
Individuality is best expressed individually; you are conforming in your non-conformity.
Lesharoturbo is offline   Reply With Quote
Old 09-14-2012, 06:32 AM   #2522
DaniGAS
DaniGAS's Avatar
Oddometer: 87
Originally Posted by bobbed06 View Post
This is gonna be a good looking Kawi.......
I hope so!
This weekend I'll try to fit the C airbox into the R frame. There is a tutorial on the yahoo groups
Any suggestions??
Will the R swingarm hit the C airbox so I'll need to use the C swingarm?
DaniGAS is offline   Reply With Quote
Old 09-22-2012, 07:15 PM   #2523
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,546
Everyone on holidays or what?
Fogo72 is offline   Reply With Quote
Old 09-22-2012, 09:18 PM   #2524
muddriller
Oddometer: 99
holiday?
Nope.' Just got my pumper carb fitted and it fired up today! I need to get the throttle cables sorted yet, but she runs. Too nice to spend all my time fixing shit, I put 700miles on my Connie yesterday and the day before. Maybe I'll learn to post pictures and show you how my project is coming along.
Todd
Every sailor knows, that the sea, is a friend made enemy. And every shipwrecked soul, knows what it is, to live without intimacy.
muddriller is offline   Reply With Quote
Old 09-23-2012, 01:44 AM   #2525
Myway
Myway's Avatar
Oddometer: 3,103
No watching australia safari rallye, live
http://www.australasiansafari.com.au/Webcam/webcam.html
Good day,................
Myway is offline   Reply With Quote
Old 09-23-2012, 03:53 PM   #2526
Landmissile
Oddometer: 26
Pretty much my first post here. I do a lot of lurking. Not sure why I haven't found this thread with previous interweb searches.
Anyway... Thought I would share my attempt at a KLX650R Rally bike. I love this bike, for the record. Just installed the BD double LaPaz lights and billet innovations bracketry. Zumo GPS and Trailtech computer. Also just ordered the big Acerbis tank to replace the IMS model.
Running a 19 inch front and 17 inch rear wheel with Shinko 705's. The street rear has a C model hub and standard lacing. My dirt wheels are the the factory set in the same size with Woody's super lace running IRC Vulcanduro's for now.
Rear fender and fork guards are grafted from a KX. Currently sorting how to fab a ProMoto Billet rack to it. Wolfman tank bag, saddlebags and a GiantLoop tank bag thing.
Maybe one day I'll have pics loaded somewhere so I can share them.
Landmissile is offline   Reply With Quote
Old 09-25-2012, 08:58 AM   #2527
Pete in PA
Getting dirty....Again.
Oddometer: 69
So my clutch is starting to slip on my 94 KLX650C Just under 20k miles. I regeared it back to stock which causes me to use the clutch more in tight, narly, uphill areas. A few questions.
E bay even has used clutches, should I even consider that?
OEM or aftermarket?
If aftermarket which one?
Any to avoid?
Get everything (friction, steel and springs) or take apart check/measure than order?
Thanks for the help.
94 Kawasaki KLX650C 21k miles. Shinko 705's, snorkel removed, lid on, K&N filter, stock muffler bored out, 155 keihin main, 42 pilot, stk needle shimmed .045, 3 turns on screw, slide hole 1/8th in. runs like a beast.
06 Honda ST1300
Previous Hondas: 98 CBR1100XX, 97 XR650L, 85 V65 Sabre, 83 650 Nighthawk.
Pete in PA is offline   Reply With Quote
Old 09-25-2012, 01:59 PM   #2528
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 691
Originally Posted by Landmissile View Post
... Also just ordered the big Acerbis tank to replace the IMS model...
You wouldn't be looking to ditch the IMS tank would you?
uraberg is offline   Reply With Quote
Old 09-25-2012, 03:46 PM   #2529
Petrolburner
Noise Maker
Petrolburner's Avatar
Oddometer: 564
OEM or aftermarket?
Any to avoid?
Take it apart and see what you need. Probably only need the fiber plates. Soak then in oil before installation.
2007 Honda XR650R, 2005 Gas Gas EC 250, 2004 Sherco 2.9, 2002 aprilia ETV 1000 Caponord, 1993 Kawasaki KLX 650
Petrolburner is offline   Reply With Quote
Old 09-26-2012, 06:52 AM   #2530
DaniGAS
DaniGAS's Avatar
Oddometer: 87
klx650r frame, klx650c motor
ALmost done...
Old 09-28-2012, 07:32 AM   #2531
Pete in PA
Oddometer: 69
Thanks, what about brand? I've been doing a lot of surfing and can't decide.
06 Honda ST1300
Old 09-28-2012, 08:19 AM   #2532
Lesharoturbo
Nerdly Adventurer
Oddometer: 1,172
Have you removed the clutch and tried to de-glaze the fiber pads first? You may just need to sand a little with fine paper on both the fiber and metal plates to remove any glazing and be back in business.
Old 09-28-2012, 08:43 AM   #2533
Pete in PA
Oddometer: 69
Nope, didn't pull apart yet. Trying to decide if I'll wait till the end of ridng season (not long) and do over the winter. It's not slipping yet just weaker. When trying to bump start the engine clutch slips tire doesn't lock.
Any chance I can save the right side engine gasket or will I need a new one?
Still want to know OEM, Barnett, EBC, DP, or what. Cork, kevlar, carbon fibre etc. Lots of choices out there.
06 Honda ST1300
Old 09-29-2012, 09:24 AM   #2534
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,546
Originally Posted by DaniGAS View Post
ALmost done...
So whats new about that!
Are you gunna run the "R" model CDI with your "C" engine.
Are you gunna run the original "R: model wiring harness?
Cheers Fogo...
I can see this ending up in tears.......
Old 09-29-2012, 09:35 AM   #2535
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,546
Don't waste your time trying to fix your clutch. I just put in a new complete EBC clutch kit that come with the fibre plates, steel plates and heavy duty springsfor $70 off Ebay. Your gasket will tear as well and needs to be replaced as the gasket covers alot of important oil galleries.
One way to tell if you bike clutch slips a little is if you can get the front wheel off the ground easy in 2nd gear, my bike was very hard to wheely where my sons KLX was easy, now with the new clutch it comes straight up 1st and second just with the crack of the throttle.
Hey MYWAY, Starting to get ready for the Longest day ride again this year, remember 1500 klms of dirt in 15 hours across NSW Australia. Hope for no rain this year.
Cheers Fogo...
Times are GMT -7.   It's 09:58 AM.
