Old 08-13-2007, 04:39 PM   #241
endurotour
endurotour's Avatar
Oddometer: 285
Originally Posted by Motogeek
They have all the specifications (they make a round rotor) but I would like to find out if there is enough interest to make it worth their while
Please let me know.
If they are ok $ wise, and able to be shipped to AUS I am up for one,
cheers Al
endurotour is offline   Reply With Quote
Old 08-13-2007, 07:37 PM   #242
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,650
I have been speaking with Industrias Galfer about making a rear wave rotor for my '93 KLX650c and am wondering if there is anyone else who is interested.
They have all the specifications (they make a round rotor) but I would like to find out if there is enough interest to make it worth their while.
Please let me know.
How about a wave FRONT rotor? A nice Biggun... 340 mm like Buell's! and anodized caliper bracket to match
All for less than 300 bucks (I just bought a new clutch)
BENRON is offline   Reply With Quote
Old 08-14-2007, 08:03 AM   #243
Motogeek
Magically Delicious
Motogeek's Avatar
Oddometer: 7
There is a 320mm with what looks like the correct bolt pattern. I need to figure out which bracket to mount with it but will post once I have the details.
Motogeek is offline   Reply With Quote
Old 08-14-2007, 10:22 AM   #244
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,650
That'd be sweet...
Old 09-11-2007, 07:21 AM   #245
xKLR_John
xKLR_John's Avatar
Oddometer: 885
How many miles should I be getting before I hit reserve?
This is on a 1993 KLX650C.
I finally got mine running. I'm working on it's first tank of gas in years on the road. It sputtered at 80 miles and I switched to reserve. Seems to be running fine now but that seemed early to hit reserve. Previous owner did gear it way down for offroad so I'm sure that's not helping range on the highway.
xKLR_John is offline   Reply With Quote
Old 09-11-2007, 06:35 PM   #246
Duck1
Lost
Duck1's Avatar
Oddometer: 57
Depending on the type of riding I'm doing, I've hit reserve between 110-130 miles. Typically, I refuel at 100 as I'm not a big fan of hitting the reserve.
Duck1 is offline   Reply With Quote
Old 09-13-2007, 02:59 PM   #247
JRiott
Oddometer: 137
http://denver.craigslist.org/mcy/421573236.html
Every once in a while I see one for sale here. I almost bought one because they're dirt cheap.
04' KTM 300 EXC Plated
01' Honda BRP Dual Sport Barely Legal
03' XR100
03' XR70
01' XR50
93' CBR900RR
JRiott is offline   Reply With Quote
Old 09-13-2007, 08:00 PM   #248
Duck1
Lost
Duck1's Avatar
Oddometer: 57
I know where you can find one for a good price in Kansas City as well
Old 09-17-2007, 06:13 AM   #249
xKLR_John
xKLR_John's Avatar
Oddometer: 885
Ok. Something's not quite right with mine. That sputter at 80 miles really was me hitting reserve. I'm getting a little under 30 mpg. 3.2 gallons to fill up at 90 miles.
Anyone know the factory sprockets for a 1993 KLX650c? I've got 14tooth front and 49 tooth rear.
Final clue, it runs ok but doesn't pull smoothly under wide open throttle when hot. All in all, it seems weaker than my KLR but I've heard the KLX should have a good bit more power. Engine is way smoother and shifts smoother than my KLR, just need to do a bit of fine tuning on the jetting, maybe.
Heck, I'll reply to my own post. I won't get overly excited until I see what I get with tank #2. Tank #1 had mix of ancient gas + fuel additives + fresh gas. Since I ran it almost dry, results may vary with full tank of fresh gas.
Well I'll answer another of my own questions. Web research shows stock gearing is 15-43. So I'm turning 22% higher RPM than stock. So if stock gas mileage is ~50mpg, I should be getting ~40mpg. So I don't have as much of a discrpency to explain as I thought.
xKLR_John screwed with this post 09-17-2007 at 09:48 AM
Old 09-18-2007, 04:30 PM   #250
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,650
No wonder why my KLX seems so dang heavy... I put it on the scale today with a full tank (5 gallons) ... 397 pounds
Old 09-19-2007, 06:15 AM   #251
xKLR_John
xKLR_John's Avatar
Oddometer: 885
You have a bunch of aftermarket parts added on? Or (more likely) does Kawasaki lie?
Old 09-19-2007, 06:43 PM   #252
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,650
An acerbis 5 gallon tank... And new 606's
The 5 gallons of gas accounts for 35 pounds... which would make the dry weight ~362 pounds which is 25 pounds over Kawasaki's "dry weight" of 337 Hard to believe I have 25 pounds of oil in it...
Liar Liar pants on fire
Old 09-20-2007, 06:27 AM   #253
xKLR_John
xKLR_John's Avatar
Oddometer: 885
Just to keep the thread alive and for anyone who's curious.
Tankful of gas number 2 yielded 29mpg.
So my KLX650 is thirsty. I may investigate adding an auxillary tank at some point.
Anyone considering switching to 14-49 gearing can use this as a datapoint.
Old 09-22-2007, 07:32 PM   #254
Royal Tiger
Pz VI B, Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,385
I got over 100 without hitting reserve. I just filled it to the brim the other day and reset the trip, so I'll see how I do this tank. With the mods, I figured less range, not more. It's the 6 miles at 85mph on the Interstate that are killing my milage. That's a whole lot of revs. My ZR is getting close to 50mpg ridden hard.
2013 Yamaha XT250 * 2005 BMW R1200ST
Long list of former rides.
Royal Tiger is offline   Reply With Quote
Old 09-23-2007, 12:34 AM   #255
endurotour
endurotour's Avatar
Oddometer: 285
I am running 17 Motard front and rear, 15 / 43 gearing, 12 litre original tank and cover a touch over 200kms before its dry.. or needing a push, generally around 220kms maybe out by 12-18kms on the speedo/odm runs about 3% on the high side.. 1993 C model.
On a side note, I have just had a rebuild, swapped out the swing arm, ('a') version, panniers, rails, gos etc etc.. hope to get the photos up soon..
Monday I see about a 24lt tank fitting on.. looking a little more tricky, will see how it goes..
Times are GMT -7.   It's 08:13 PM.
