Old 05-14-2013, 02:07 PM   #2701
nejauks
nejauks's Avatar
Oddometer: 173
moped in good health
nejauks is offline   Reply With Quote
Old 05-15-2013, 07:54 PM   #2702
arcangel
Adventure Poser
Oddometer: 69
KLX650C starter switch
Does anyone happen to know if a non-latest model KLR650 start switch/RH control pod (I can verify the 08+ unit doesn't work ) , or any other kawi unit for that matter, will connect up with a 93 KLX650C by chance???
TIA
arcangel is offline   Reply With Quote
Old 05-15-2013, 08:12 PM   #2703
marine_mike
marine_mike's Avatar
Oddometer: 319
Hey guys, I just had a friend work on my fiance's 94 klx 650c and he pointed out a few things to me. First, her battery wont hold a charge after riding. It's brand new. He tested it and it's reading kind of low. I'm thinking the stator is on it's way out. Can some one post up a link to changing out the stator, and where can I get one...aside from a flea-bay used one. Second, there seems to be a clank on the right side of the engine every once in a while. Any idea what that could be? It has the manual cam chain tensioner.
marine_mike is offline   Reply With Quote
Old 05-15-2013, 08:21 PM   #2704
itsatdm
itsatdm's Avatar
Oddometer: 4,833
TIA
I think a pre 2007 KLR switch will work. Got a shop manual?, here is a wiring diagram for a 2006 KLR. http://www.buttonhome.org/photos/?g2...geViewsIndex=1.
The wiring colors are different but it looks like the R/Y off the starter relay is the same as W off the relay for a KLX
Old 05-17-2013, 07:59 PM   #2705
Knobster
Knobster's Avatar
Oddometer: 52
nice!!
94' KLX650-C, 09' Tiger 1050, 74' R90/6, 73' GT550 project
ABC # 5618
Knobster is offline   Reply With Quote
Old 05-18-2013, 05:51 AM   #2706
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,540
A few video's of our last rip guys last week, 5500 klms in 2 weeks.
Cheers Fogo...
Fogo72 is offline   Reply With Quote
Old 05-18-2013, 06:07 AM   #2707
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,540
Old 05-22-2013, 12:36 PM   #2708
nejauks
nejauks's Avatar
Oddometer: 173
Tensioner and bolt.
Cheap and angry.
Pulled my chain (not new) one click more than the spring does it. This is better.
http://klxclub.ru/showthread.php?t=4...ll=1#post25234
nejauks screwed with this post 05-22-2013 at 12:41 PM
Old 05-22-2013, 12:47 PM   #2709
HanShotFirst
Oddometer: 281
I have a 1994 KLX 650 California model thats currently not running. I may have it figured outwell see this weekend. If not, Ill be asking questions. But when she does run, thats a really fun bike. Much bigger cajones than the KLRs. Im 6-2 230lbs, so I like a big heavy bike to go with my big heavy frame. Love woods riding, and technical stuff. Im bound and determined to get her running very soon, I have trails calling my name.
HanShotFirst is offline   Reply With Quote
Old 05-23-2013, 06:28 AM   #2710
Bishke
Bishke's Avatar
Oddometer: 7
Hello guys,few question !
Does anybody can tell me, how much is Oil consumption on yours KLX 650 C model ?
And how you checking your oil level ?
Because on my KLX 650 C,oil level rise and fall under normal,although in engine is normal volume of oil !
Bishke is offline   Reply With Quote
Old 05-23-2013, 07:22 AM   #2711
Myway
Myway's Avatar
Oddometer: 3,102
none, less....
start engine, drive a while, warm it up, keep the klx straight up, let it idle for some minutes, stop, still straight up, watch oil lever 3/4 off glass done.
I do this after a ride, the idle time with petcock closed, (lower fuel level in carb, start next time better if bike is standing for a while on its side), stop, check oil level.
If you have oil under the filterbox reservoir that comes out the box after the filter, you can make a longer tube loop up from cilinderhead to the filterbox. The oil condense in the tube and float back to the cilinder head.
even some build oilcondensater between above the cilinderhead.
example in this forum
Myway screwed with this post 05-23-2013 at 07:38 AM
Myway is offline   Reply With Quote
Old 05-23-2013, 10:07 AM   #2712
Bishke
Bishke's Avatar
Oddometer: 7
ok,I understand this story for measuring oil level.
But,what about oil consumption ?
I heard that 250 ml / 1000 km is just fine
Old 05-24-2013, 04:41 AM   #2713
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,540
I just finshed rebuilding my KLX650c engine and took it on a 6000 klm trip into outback Australia, Heavily loaded on dirt roads,
Used 200ml in 6000 klms.
Myway is correct, sometimes the engine oil level Lies. Sometimes low sometimes high, oil get traped over in the magneto side of the engine, (LHS)
Cheers Fogo...
Old 05-24-2013, 04:43 AM   #2714
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,540
I am going to start my roller bearing cam cylinder head project soon.
Old 05-24-2013, 12:18 PM   #2715
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 689
Interesting idea, but how do you envision getting the bearings between the lobes?
uraberg is offline   Reply With Quote
Times are GMT -7.   It's 04:51 PM.
