Old 05-24-2013, 11:26 AM   #2716
Jura
Oddometer: 16
Finally end of the modifications from dual sport to supermoto
We still need to replace the headlight, decals, and few things.
Jura screwed with this post 05-24-2013 at 11:40 AM
Jura is offline   Reply With Quote
Old 05-24-2013, 12:07 PM   #2717
nejauks
nejauks's Avatar
Oddometer: 173
Filled to the front fork the engine oil 5W40. This is good and cheaper.
In the rear shock is filled Dexron 3. It is cheap and good. Next time I will fill 5W40 there.
nejauks is offline   Reply With Quote
Old 05-24-2013, 12:20 PM   #2718
nejauks
nejauks's Avatar
Oddometer: 173
Reconfigured rear shock "pyramid" (the assembly of plates) for my weight with a backpack (about 110 kg)) for compression ( absorber squeeze phase ). Made a "pyramid" is more simple in shape (almost cone than, at the beginning.) Meaning - to make a "pyramid" harder to load. The result is better for me.
http://www.shimrestackor.com/index.htm
nejauks screwed with this post 05-24-2013 at 12:35 PM
Old 05-26-2013, 03:59 AM   #2719
Bishke
Bishke's Avatar
Oddometer: 7
Here picture of two KLX :)
And picture of me and my KLX 650 C
Bishke is offline   Reply With Quote
Old 05-26-2013, 05:03 AM   #2720
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
Originally Posted by uraberg View Post
Interesting idea, but how do you envision getting the bearings between the lobes?
You dont, you put the bearings on the end of the cams. One on each end and mill out a channel to take out the original cam tunnel. Blocks of alloy will have to be welded in to the head at each end to except the roller bearings. two steel adapters will need to be machined and pressed into the cams from both ends to take the bearings.
No its not been done before, but dont forget who I am. I did fit a "C" model crank into an "R" model engine before and made it electric start.
Cheers Fogo.
ps, dont worry I will keep you in the loop.
Fogo72 is offline   Reply With Quote
Old 05-26-2013, 05:08 AM   #2721
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
Twins ayyy.
Well heres my two.
Check mate.
Old 05-26-2013, 05:38 AM   #2722
Ben600
Ben600's Avatar
Oddometer: 13
Hi all!
I'm new to this enduro bike lark, an I'm hopefully going to pick up a 1997 klx650 on Tuesday!
I've a couple of questions if you'd help...
Firstly, the cam chain adjuster mod (doohickey?). How can I tell its been done to the bike?
Secondly, what other known issues are there to look out for? The bike I'm looking at looks to be mint, but any pointers would be brilliant.
Lastly, I've seen a lot with a more 'mx' style back end ( pointy rather than curved). What rear panels if any will fit onto these bikes?
I look forwards to becoming a KLX owner and getting some mud under its tyres :)
Cheers
Ben
Ben600 is offline   Reply With Quote
Old 05-26-2013, 06:55 AM   #2723
arcangel
Adventure Poser
Oddometer: 69
Ben-
Totally different engine than our KLR brevvren--no 'doo to do!
Only real problem with these bikes I've seen is that people here will convince you to spend lots of $$$ farkling them.
arcangel is offline   Reply With Quote
Old 05-26-2013, 07:06 AM   #2724
Newfiebullet
Newfiebullet's Avatar
Oddometer: 193
Originally Posted by arcangel View Post
Ben-
Well, that answers, in part, the question I was going to ask.
Forgive me for not having read through the entire thread, but it's a little lengthy. But I'm curious just what the differences between a KLR and a KLX are. If there's no doo-hickey, I assume that means there's no counter-balancer on the KLX. Of course the fairings are different. What else distinguishes a KLX from a KLR?
Newfiebullet is offline   Reply With Quote
Old 05-26-2013, 08:32 AM   #2725
itsatdm
itsatdm's Avatar
Oddometer: 4,920
It has a gear driven balancer. The KLR and KLX are different bikes. It would be easier to tell you what is the same, which is not much.
Different engines, frame, suspension, brakes, etc,etc,etc. You don't say wether you have the dirt R version or dual sport C version. There are differences there too, but that would require an extra etc.
Old 05-26-2013, 09:54 AM   #2726
Ben600
Ben600's Avatar
Oddometer: 13
It is a C that I am looking at. almost perfect condition with a 'performance' exhaust. That's a relief there's no doohickey thingy to worry about though :)
Old 05-26-2013, 10:21 AM   #2727
itsatdm
itsatdm's Avatar
Oddometer: 4,920
You might find this interesting: http://advrider.com/forums/showthread.php?t=889914
Old 05-26-2013, 12:12 PM   #2728
Ben600
Ben600's Avatar
Oddometer: 13
cheers mate! that's my dad's thread lol didn't realise he'd opened one for me :)
Old 05-27-2013, 05:48 AM   #2729
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 691
Cheers Fogo.
I am usually not a naysayer to this sort of work (mine is a "C" framed "R", and I made an SV cammed DL once), but are you sure there is room in the head ?
Have you thought about split bearings?
uraberg is offline   Reply With Quote
Old 05-28-2013, 05:57 AM   #2730
HanShotFirst
Oddometer: 399
KLX Sputtering, backfiring
Melp me my bro-tha’s.
1994 KLX650C, been sitting for several years. Rebuilt the carb and generally cleaned the whole thing up. Got it to start and run, actually rode it for about 5 minutes; fast. But I had to put her up because I’m waiting on a replacement O ring for the float bowl, and she’s leaking gas bad.
Anyhow, it takes a little cranking and then she fires. When cold, she sputters, occasionally backfires, and doesn’t really want to idle. As she warms up, she smooths out, eventually idling on her own.
For the cold and idle part, I assume it’s an air fuel mixture thing and I just need to adjust the pilot screw and find the “sweet spot”; am I correct? But what about the backfiring, is that carb related also?
HanShotFirst is offline   Reply With Quote
Times are GMT -7.   It's 02:16 PM.
