Old 10-31-2013, 03:19 PM   #2896
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,562
Originally Posted by Dugw View Post
Sorry boys, yeah that was a while ago. and like most things I failed to follow up on the post.
so here are some more pics. The 4 legs were bolted into place before taking it into town to get someone to alloy weld it in place with out moving them.
All KLX sub frame will crack over time from either jumping the bike or humping a load, You must provide rubber mounts to where it attaches to the frame. I carry about 40 to 50 kg on both my bikes rear guards and they have never cracked also with subframe strengthening.
Drill an 8mm hole straight through the seat mounting hole and bolt the rubber mounts on the outside with the bolt going through from the inside after you bore some plastic outta the way, tight area, use allen head screws.
Seat mount bolt area.
Rear mount at rear blinker / indicator area.
Fogo72 is offline   Reply With Quote
Old 10-31-2013, 03:26 PM   #2897
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,562
KLX700 project coming along nicely
See thread here
http://www.advrider.com/forums/showt...php?p=22488478
Cheers Fogo...
Old 10-31-2013, 04:18 PM   #2898
itsatdm
itsatdm's Avatar
Oddometer: 5,001
Now I see where your best post go . Great project.
Old 10-31-2013, 07:36 PM   #2899
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,562
Don't forget about the TEAM KLX homepage,
http://advrider.com/forums/showthread.php?t=850765
Old 11-01-2013, 09:03 PM   #2900
Letze
Oddometer: 15
New KLX650C Owner
Hey guys, I'm a sportbike rider at heart, with two First Gen R6's and a little collection of CBR and R6 motors littering my garage. I've been craving a dualsport in the upper range for adventuring, just picked up this guy for a small sum.
Not a whole lot of info from the previous owner, he claimed he was going to pull the motor and put it in a Honda Odyssey (the gokart not the van) But never got around to it. Sold as a non runner. What a mess.. the whole bike was partially disassembled but he had all the important parts so I took the plunge.
She's undergoing restoration. lucky me the motor was sealed up and rotates smoothly with good compression. Only seems to have a hand full of electrical gremlins from a haphazard harness removal attempt.
One thing I'm curious about, is the front wheel rim has jukyard paint pen markings "KX500" and the forks are blue... I know my ignition doesn't mount to the triple clamps so I'm lead to believe that the bike was wrecked and repaired with a KX500 front end (43mm Forks). As I have no idea what modifications were done to make it work out, any one want to chime in on advantages/disadvantages of this swap?
Letze screwed with this post 11-01-2013 at 09:28 PM
Letze is offline   Reply With Quote
Old 11-01-2013, 10:51 PM   #2901
itsatdm
itsatdm's Avatar
Oddometer: 5,001
They are KYB forks used in 92-96 era KX 125/250/500 2 stroke dirt bikes. Have adjustment for compression and rebound. The stock forks don't.
They were used on much lighter bikes, so unless sprung for weight and revalved, they probably need work.
Old 11-02-2013, 03:34 AM   #2902
DaniGAS
DaniGAS's Avatar
Oddometer: 97
Originally Posted by Fogo72 View Post
Great fairing, FOGO. I would be interested in one of them if you mould and copy some!
I am on a klx650r rally build too, but have no idea about what to do with the fairing. I was looking on dual headlights like the buell's mod, but i'll wait for some other ideas
DaniGAS is offline   Reply With Quote
Old 11-02-2013, 04:05 AM   #2903
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,562
Yeah. the plan is to cut and shut and grind and bog until it fits over the KLX650R Acerbis tank and then make a mould of it.
Old 11-02-2013, 04:08 AM   #2904
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,562
Hey guys, who had the part number for the Kibblewhite 1mm oversize valves?
I want to put them in the 700 head.
Cheers fogo.
Old 11-02-2013, 10:15 AM   #2905
UtahGuido
UtahGuido's Avatar
Oddometer: 5,125
Just a quick note here regarding whether or not a KLX650 footpeg mount (right side) will work on a KLX250. It will - bolts right on. More info over on the KLX250s Long Term Review thread. But here's what it looks like:
Thanks fellas for your assistance in measurements and pictures!
As you get older get a slower dog.
UtahGuido is online now   Reply With Quote
Old 11-03-2013, 05:27 PM   #2906
Earthscape
Have ya got a helmut?
Earthscape's Avatar
Oddometer: 363
Excellent, glad it worked out like you hoped.
"You do your own thing in your own time, you should be proud."
2004 KTM 950 ADV : : : : : : : 1998 Triumph Tiger
1999 KTM 640 ADV : : : : : : : 1993 Kawasaki KLX650
2007 Kawasaki KLX350S : : : : 1996 Yamaha XT350
Earthscape is offline   Reply With Quote
Old 11-08-2013, 03:04 AM   #2907
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,562
KLX700 crank has gone together!
see over at the KLX700 project thread.
Cheers Fogo...
Old 11-10-2013, 05:49 PM   #2908
Letze
Oddometer: 15
Tomorrow is reassembly time, just have to let the paint on the frame cure just a little bit longer.
but I'll share some progress.
Going to visit my friends at the local dealership and get some replacement clutch/throttle cables, I've tried cleaning the ones I got with it but even after the oil cleared up on the throttle cables they still didn't actuate as smooth as I'd like and the clutch cable looked like some one let it rub on the exhaust.
Old 11-10-2013, 11:58 PM   #2909
Jura
Oddometer: 16
My almost finished work
https://www.youtube.com/watch?v=iiK4LU_WgAY
Jura is offline   Reply With Quote
Old 11-15-2013, 07:52 AM   #2910
Pete in PA
Getting dirty....Again.
Oddometer: 79
Is the muffler from a KLX650R (dirt version) a direct bolt on to a KLX650C (dual sport)??
If so I want one.
94 Kawasaki KLX650C 21k miles. Shinko 705's, snorkel removed, lid on, K&N filter, stock muffler bored out, 155 keihin main, 42 pilot, stk needle shimmed .045, 3 turns on screw, slide hole 1/8th in. runs like a beast.
06 Honda ST1300
Previous Hondas: 98 CBR1100XX, 97 XR650L, 85 V65 Sabre, 83 650 Nighthawk.
Pete in PA is offline   Reply With Quote
Times are GMT -7.   It's 06:05 PM.
