Old 02-02-2002, 02:39 AM   #1
Dutchman OP
Diskussionsleiter
Dutchman's Avatar
Oddometer: 814
Send a message via Skype™ to Dutchman
BMW red instrument lighting
For those with any post '93 R series BMW's, I've had lots of enquiries regarding my red instrument lighting, which is a lot less of a distraction at night than the original bright white lighting.
www.pbase.com/iamge/999258
The main instrument bulbs, two in each clock, can either be replaced by red BMW auto bulbs, from any current BMW car-the fitment is identical except they are red or you can simply paint a little nail varnish over the bulbs until the desired hue is achieved.
I've also done the same with the fog light switch bulb, so that glows red as well.
As far as the R.I.D. (Rider Information Display) is concerned I took a couple of hours yesterday to completely dismantle this instrument to see if I could illuminate that red as well.
Big problemo............
This is lit by four ORANGE LED's soldered directly onto the PCB which is at the heart of the R.I.D. These in turn provide uniform backlighting via a small perspex prism.
First of all I tried colouring the LED's, but this simply reduced the light too much to be effective.
I removed the colouring from the LED's and coloured the prism instead-no better.
As far as I can see there are only two ways to colour the R.I.D to match the other instruments:
Apply a thin clear red plastic foil/tape to the outside face of the instrument.
Obtain bright red LED's and solder them in place of the orange one's, a lot of work for the required result.
Alternatively you just say, what the fuck, and get on with your life........
Ride to Arrive...................
DUTCHMAN
Dutchblog
Dutchman is offline   Reply With Quote
Old 02-02-2002, 11:00 AM   #2
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Did the same on my DR650. it uses those 3w plug in bulbs. local auto parts store has amber, red and green. I like the red glow but the redline doesn't show up (duh red light on red marking) but I long ago memorized how the bike feels and sounds at redline.
dead
Chopperman is offline   Reply With Quote
Old 02-02-2002, 11:05 AM   #3
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Did the dame on my DR650. it uses those 3w plug in bulbs. local auto parts store has amber, red and green. I like the red glow but the redline doesn't show up (duh red light on red marking) but I long ago memorized how the bike feels and sounds at redline.
dead
Old 02-02-2002, 06:09 PM   #4
fish
fish's Avatar
Oddometer: 47,709
Re: BMW red instrument lighting
you mean http://www.pbase.com/image/999258 ?
fish is offline   Reply With Quote
Old 02-03-2002, 03:16 AM   #5
Dutchman OP
Diskussionsleiter
Dutchman's Avatar
Oddometer: 814
Re: Re: BMW red instrument lighting
..........................you're much too sharp for me Fischmeister......sorry about the typo.............:
DUTCHMAN
Dutchblog
Old 02-16-2002, 08:44 AM   #6
Beemer-Biker
Beemer-Biker's Avatar
Oddometer: 1
Question
Here is a stupid/novice/moron question, but since I do not know the answer, here goes.
How does one remove the bulbs in the speedo/tach to change them? I have had the dash of my R1150RT off, had the nuts off of the back of the speedo and tach, but couldn't see where to remove the bulbs to change them to red.
Help!
TIA
George
Beemer-Biker is offline   Reply With Quote
Old 02-16-2002, 09:35 AM   #7
Dutchman OP
Diskussionsleiter
Dutchman's Avatar
Oddometer: 814
Once you have removed the instruments from their mountings in the dash you will see two grey rubber bulb holders push fitted into the white back of each clock.
Pull firmly away from the clock back and each bulb holder contains one capless clear bulb which you then paint red!
DUTCHMAN
Dutchblog
Times are GMT -7.   It's 09:25 AM.
