Old 08-28-2006, 01:47 PM   #46
freeflow OP
get in or go in
freeflow's Avatar
Oddometer: 16,200
Update:
just called again to see what is up...geez sorry to bother you service man...
"you are calling about the Vstar?..."...me: nope the Vstrom!...."Right the Vstar"...NOPE!....oh ohh the red one?
"We are waiting for authorization from Suzuki to tear the motor down"
umm...dood, last week you told me you took the rear cylinder out of it and were putting together an estimate to the warranty department..
"I did?"...I told you we did a leak test"
I will give him a few more days....
freeflow is offline   Reply With Quote
Old 08-28-2006, 08:53 PM   #47
RubberDown
RubberDown's Avatar
Oddometer: 2,306
Originally Posted by FREEFLOW
Update:
Sounds like a good dealer.
Well if it seems to be real, it's illusion - For every moment of truth, there's confusion in life - Love can be seen as the answer, but nobody bleeds for the dancer - RJD
RubberDown is offline   Reply With Quote
Old 08-29-2006, 05:25 PM   #48
Fat Toney
Up Yours PoopSicle
Fat Toney's Avatar
Oddometer: 7,456
Update:
His brain sounds clogged with bong resin..
Fat Toney is offline   Reply With Quote
Old 09-01-2006, 09:28 AM   #49
Fat Toney
Up Yours PoopSicle
Fat Toney's Avatar
Oddometer: 7,456
Originally Posted by jkam
That never affected me that way.
thats because your bike isn't blowing smoke
Old 09-01-2006, 01:36 PM   #50
soloyosh
Dad and husband
soloyosh's Avatar
Oddometer: 5,480
Probably put too much oil in it?
Translation: "We tore down the rear cylinder without authorization, so before we really get in trouble were gonna sit and wait a little bit.
2007 Aprilia RXV 5.5
soloyosh is offline   Reply With Quote
Old 09-06-2006, 08:17 AM   #51
Fat Toney
Up Yours PoopSicle
Fat Toney's Avatar
Oddometer: 7,456
Old 09-06-2006, 09:00 AM   #52
freeflow OP
get in or go in
freeflow's Avatar
Oddometer: 16,200
Originally Posted by Fat Toney
no doubt...just got a call today....bullshit
"loose exhaust valves" all the way around.....we are waiting for approval to order new parts and head and pistons......
I can feel it coming...this is bullshit....some please esplain it to me....loose exhaust valves (which were fine 5,000 miles ago and are known to be fine forever on these engines right?)....that'd cause smoking and oil burn of about 1/2 a qt in a few hundred miles?...right?
does this smell fishy to anyone else?....
Old 09-06-2006, 09:22 AM   #53
Fat Toney
Up Yours PoopSicle
Fat Toney's Avatar
Oddometer: 7,456
Fishy?...it smells shitty to me...reminds me that I need to check the valves on my KLR...
Old 09-06-2006, 09:52 AM   #54
mp183
Oddometer: 310
Can't see that happening on this type of engine.
It uses a shim/bucket type system to adjust the valves.
If it used a rocker arm type of adjustment, like on my KLR250, where you use a set screw it can happen.
On a shim/bucket there is no way you can get a radical change it such
a short amount of time unless they did something totaly wrong
at the factory. Like forgot to screw down the whole cam assembly.
I have almost 30,000 miles on mine and have yet still to check the valves.
Was going to do a check on Friday but something came up again.
2004 DL650
2002 GS500
2004 KLR250
mp183 is offline   Reply With Quote
Old 09-06-2006, 10:11 AM   #55
jdiaz
Oddometer: 32,308
Just yank the motor and put a 744 kit in.
jdiaz is offline   Reply With Quote
Old 09-06-2006, 10:24 AM   #56
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I can't see loose exhaust valves causing smoking besides the fact that they wouldn't have changed that quickly (and if they had, its much more likely they would have tightend up).
good luck
BikePilot is offline   Reply With Quote
Old 09-06-2006, 11:04 AM   #57
TroopFuel
Green Side Up
TroopFuel's Avatar
Oddometer: 673
It does sound very fishy. That would never happen at a KTM dealer
www.troopfuel.com
TroopFuel is offline   Reply With Quote
Old 09-06-2006, 12:31 PM   #58
mp183
Oddometer: 310
KTM has dealers?
2004 DL650
2002 GS500
2004 KLR250
Old 09-06-2006, 03:22 PM   #59
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,775
Don't know how loose exhaust valves would require new pistons and heads.
Think maybe he means the exhaust valve stem is loose in its guide. That would make more sense as far as the oil consumption goes. But still not for the head and piston replacement.
Old 09-06-2006, 03:32 PM   #60
TroopFuel
Green Side Up
TroopFuel's Avatar
Oddometer: 673
Originally Posted by mp183
KTM has dealers?
www.troopfuel.com
Times are GMT -7.   It's 11:31 PM.
