Old 04-16-2007, 07:34 AM   #76
freeflow OP
get in or go in
freeflow's Avatar
Oddometer: 16,106
bump....
finished a short 150 mile ride yesterday....shelly rolled into garage and smoke pouring out exhaust....you know....blueish tint oil smelling exhaust....
..I don't have time to deal with this again...and a BIG WTF!!!!!...
I shot video of it.....basically...after a ride...come home to idle...and smoke comes out of exhaust.,...not normal....but then it clears out after a bit....but when revved to 4-5K...it has a smoky exhaust
this is still under warranty....and worth having them look at it again?...
BTW my 04 weestrom was fine and ridden way way harder than Shelly rides her's...
freeflow is offline   Reply With Quote
Old 04-16-2007, 08:20 AM   #77
ShortOnSkill
Oddometer: 1,124
I'd take it in ASAP. The problem will get worse and riding conditions will get better. A college friend had this happen with her Honda Civic. She didn't get it fixed and the motor died before reaching 60,000 miles.
If the shop isn't performing to standards, check with your local Better Business Bureau. I did this once with non-motorcycle stuff. Someone from middle management was on the phone within hours and my problem was immediately resolved.
You should have a bullet proof motor. It would seem that a proper fix will have you running for years.
K3 DL1000 - Sold after 55,000 very fun miles.
ShortOnSkill is offline   Reply With Quote
Old 04-16-2007, 08:40 AM   #78
element
Time to roll
element's Avatar
Oddometer: 357
Crank case breather
Check the crank venting.... that will do it. check the vent the hose etc
element is offline   Reply With Quote
Old 04-16-2007, 10:05 AM   #79
markjenn
Oddometer: 10,456
If a shop tears into an engine and replaces hard parts only to have an oil-burning symptom return unchanged, that indicates they never fixed the problem in the first place. I'd start to get really worried about the competence of the shop. Wow, it would be a shame to have had major engine work done when it was something simple like a crankcase breather problem.
- Mark
Old 04-16-2007, 10:48 AM   #80
glasswave
Oddometer: 936
Originally Posted by FREEFLOW
yeah it is all fixed up...and only ONE month +...
FYI
Wisconsin's lemon law
If the motor vehicle you buy or lease turns out to be a "lemon," the manufacturer has to replace it free or refund the price (minus a reasonable amount for mileage).
What is a "lemon"?
A new vehicle - no more than a year old and still under warranty - is a "lemon" if
  • It has a serious defect the dealer can't fix in four tries, or
  • It has one or many defects that prevent you from using it for 30 days or more (the 30 days need not be consecutive)
http://www.dot.wisconsin.gov/safety/...s/lemonlaw.htm
I'd look into demanding a new bike.
glasswave screwed with this post 04-16-2007 at 10:57 AM
glasswave is offline   Reply With Quote
Old 04-16-2007, 11:05 AM   #81
ShortOnSkill
Oddometer: 1,124
Originally Posted by glasswave
FYI
They must either fix it correctly or give you a new one. You should not have to suffer with repeated shop failures or be forced into fixing it yourself.
Old 04-16-2007, 12:53 PM   #82
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,764
but not a dime out of pocket ...they were good about it and were a bit surprised I noticed the problem and brought it in...
it was a 20% leak down something something...valve guide....
they did manage to eff up the head gasket when they put it back together...but that was replaced...and they were very apologetic..
the reason there isn;t many good mechanics on this engine is...they usually do NOT require any work !!
shelly is happy to have her wee back
the end
I don't doubt that your conclusion is close to right..... nobody would believe the SV motor NEEDS tearing down.... then, finding a mechanic anywhere that "has experience" in rebuilding that unit..... Are we kidding? it just doesn't happen.
I have only heard of one other huge problem like this that was probably a build issue, and as it so happened, it was a "wife bike" also [I'm feeling a little insecure of my masculinity even as I type it...] . hubby and wife riding shiny new weestroms, side by side under the ever blue sky, and seemingly out of nowhere the wifes weestrom emitted a horrible noise and just died.
The clutch had self-destructed in a big, bad way.
the dealer tried to blame the wife....... bless him.
the bike only had something like 900 miles on it.
so, sometimes those bipeds that work in the assembly plants have a hangover or something...
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 04-16-2007, 01:06 PM   #83
Mr. Ray
Chemically Enhanced
Mr. Ray's Avatar
Oddometer: 3,632
I care.
I hope this comes to a smooth resolution.
Good luck. Keep us posted.
It's about this big.
http://www.roadtofermentation.blogspot.com
Mr. Ray is offline   Reply With Quote
Old 04-16-2007, 01:45 PM   #84
Prairie Dog
Prairie Dog's Avatar
Oddometer: 748
FREEFLOW,
My friend I hear your pain.
Now, remember this . . . . .
You no longer have to mix the gas and oil together. Suzuki now has 4 stroke engines!
I promise you that if you stop mixing the two, the smoke will stop!
Prairie Dog
'08 KLE 650-A8F
'06 DL-1000 K6
'06 KLX 331 H6
'04 KLR 650 A18
'92 EX500 - one day a KLEX500?
'74 Honda CB350F - project bike
"You'll never see a motorcycle parked in front of a Psychiatrist's office!"
Prairie Dog is offline   Reply With Quote
Old 04-16-2007, 02:49 PM   #85
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,677
bump....
How many miles since the total tear down?
I'll bet they've got some work to do on the front cylinder now..
Boon Booni is online now   Reply With Quote
Old 04-16-2007, 03:17 PM   #86
snowscum
World Owner
snowscum's Avatar
Oddometer: 1,274
au contraire mon frer....wees go nort...KLRs go south
no dates set...clearing some time
BTW yes kudos to Suzuki.,,,this was an extended warranty (that the previous owner bought and I worked to get transferred..a real PITA....but I jumped thru their hoops cuz I felt they were jerking it around a year ago....I;d never buy an extended warranty)...factory warranty went out a month before this or so
Are you going to trade it since it is a lemon?
I purchased the extended warranty on my Uly hoping I would never have to use it. Sounds like it came in handy really. How much did you pay for that?
I want to leave this planet the way I entered it, being held upside down naked and spanked by a nurse.
snowscum is offline   Reply With Quote
Old 04-16-2007, 05:04 PM   #87
freeflow OP
get in or go in
freeflow's Avatar
Oddometer: 16,106
checked the logs......wifey not ride this much since end of october last year...500 miles or so....it'll go in....this bike not needed for a few weeks.....
checking breathers.....but they did a bleed down test last fall....and rear couldnlt hold...whatever....
oil is now 1/4 - 1/2 qt low...on low side of window.....9K miles on bike...bought used with 3 K...an 05 in late late 05...and transferred an extended warranty....
big 4 brand dealer shop.....but dumb as shit IMO.....and they always question the rider and user...but I shove a big BULLSHIT in their face....and LOUD...LOL....they admitted last one was incorrect valve guide placement at factory...new head and all...they will get it tomorro or wed....
kinda irrating though.....
Old 04-16-2007, 05:12 PM   #88
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,677
Yeah no doubt.. 500 miles sounds like they didn't fix the problem to begin with..
It would seem that all you can do is let them, or someone else, have at it again..
Old 04-16-2007, 06:19 PM   #89
freeflow OP
get in or go in
freeflow's Avatar
Oddometer: 16,106
no doubt.....I will..and have time ...and have other bikes....I never agree with extended warranty BS...and is was a PITA to transfer from the PO who was a major tweekr wrench IMO... whatever...they make new bikes every dam,n day...still love it and what it is
Old 04-19-2007, 11:50 AM   #90
freeflow OP
get in or go in
freeflow's Avatar
Oddometer: 16,106
update.....
leak down test all great...within 3%...the last time when they warrantied and replaced the head on rear cylinder...leak down on that one was 20%ish
but oil in the airbox again like last time....suzuki is stumped....
last oil change was by the dealer...and within the sight glass marks....but now at low end....
some other breather system tied to the airbox was full of oil too....
Times are GMT -7.   It's 12:47 PM.
