Old 08-21-2006, 01:32 PM   #1
DarkRider OP
Shorter of breath...
DarkRider's Avatar
Oddometer: 594
Fantasy tire repair kit
Does anyone have any suggestions on one tire repair kit for distance riding (20% offroad). I've been lucky so far but that'll change I'm sure. Running Tourances currently.
_______________________
"This is your life, and it's ending one minute at a time." ~Chuck Palahniuk, Fight Club
DarkRider is offline   Reply With Quote
Old 08-21-2006, 01:40 PM   #2
racer
racer's Avatar
Oddometer: 1,405
Tubes or tubeless?
Socialism works good until you run out of other people's money to spend.
racer is offline   Reply With Quote
Old 08-21-2006, 01:50 PM   #3
eap
El Adventurero Solitario
eap's Avatar
Oddometer: 3,047
For tubeless I carry the Stop N Go kit and Sparrow Air Compressor - I've used them several times. I also have the BMW plug kit with 3 cartridges that come with my bike - I used it once and it worked fine also.... I think Rider Warehouse carries both these items, but they're not hard to find.
eap '01 R1150GS,
Chesapeake Bay Watershed, Surf Your Watershed
Save the Bewbies
"Over the Mountains Of the Moon, Down the Valley of the Shadow, Ride, boldly ride," -From 'Eldorado', Edgar Allen Poe (1849) http://www.eapoe.org/works/poems/eldrdoa.htm
eap is offline   Reply With Quote
Old 08-21-2006, 01:53 PM   #4
DarkRider OP
DarkRider's Avatar
Oddometer: 594
May be confused but I think the Tourances on 1150's are tubeless. If I'm wrong, it won't be the first time (today).
Old 08-21-2006, 02:51 PM   #5
DarkRider OP
DarkRider's Avatar
Oddometer: 594
Thumb Thanks for the feedback
I appreciate the feedback...decided to go w. the Stop N Go...already have the Sparrow heading my way.
Thanks again
Old 08-21-2006, 06:24 PM   #6
Crush
Oddometer: 985
Get a Safety Seal kit. Dirt simple to use and won't leak.
Crush is offline   Reply With Quote
Old 08-22-2006, 06:21 AM   #7
PETDOC
Oddometer: 1,165
If you do search you'll find threads where Stop N Go plugs are cut in half after about 50 miles when used on bikes with steel belted tires. For this reason I carry both Stop n Go kit and the OEM plugs.
PETDOC is offline   Reply With Quote
Old 08-22-2006, 07:10 AM   #8
BikePilot
BikePilot's Avatar
Oddometer: 10,901
For tubless tires I carry regular cage tire plugs and a source of air (co2, bicycle pump, electric pump or whatever is handy). For tube tires I care a spare tube
BikePilot is offline   Reply With Quote
Times are GMT -7.   It's 07:32 AM.
