Old 09-27-2006, 01:07 PM   #46
texsurfer
Oddometer: 239
furthering this... To me, i don't care if the rear wheel is aligned with the front. I care about the rear sprocket being aligned with the front sprocket. otherwise your chain/sprockets will bind and prematurely wear out. I see it on a lot of idiots bikes that get ahold of a toolset with no instruction from anyone on what to do. and they wonder why the rear sprocket looks like shark teeth and the chain makes a loud horrible sound when riding. ymmv ;)
texsurfer is offline   Reply With Quote
Old 09-27-2006, 11:03 PM   #47
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Originally Posted by rjf
$102 !!!!
Psst: That tool sells for about 30 bucks.
Arch
Arch is offline   Reply With Quote
Old 09-27-2006, 11:06 PM   #48
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Originally Posted by creeper
Elegantly simple, Creep.
Arch
Old 09-28-2006, 04:13 AM   #49
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,231
THANK YOU!
All the esoteric straightedge parallel to the front wheel stuff aside, this will work just fine for me.
Now - how do you get the point on the welding rod? Do you have a metal compatible pencil sharpener? Just kidding.
Thanks,again.
Dave
dunno.....
Old 09-28-2006, 05:15 AM   #50
techieguy
Lost in the woods
techieguy's Avatar
Oddometer: 354
If you need to worry if your swing arm pivots are square and in line with the rest of your frame, you have too much time on your hands. If they are not in line and square, then who cares about adjusting the chain correctly 'cause you got other problems!!!!
Thanks Creep, I've made one of these alignment tools for myself and one for a friend. He was amazed at my inginuity. Na, I gave you full credit!
Techieguy
Reality does not always develop in a way we expect it to.
techieguy is offline   Reply With Quote
Old 09-28-2006, 03:34 PM   #51
MrH
Oddometer: 463
I've always checked the wheel alignment on my bikes with two straight 6' planks bungied either side of the back wheel, and then measuring the gap between the planks and the front wheel. This is very sensitive because of the distances involved - 1mm at the axle is probably equivalent to 5 or 6 mm at the front wheel.
In the UK there's a requirement for the wheels of a bike to be in line for the MOT test, I guess for reasons of safety, ie steering as well as tyre, wheel bearing and transmission wear.
MrH is offline   Reply With Quote
Old 09-29-2006, 01:25 AM   #52
cat
cat's Avatar
Oddometer: 1,323
Originally Posted by meat popsicle
Well, I have the engine, tranny, drivetrain in one section, and suspension, wheels, and brakes in another. This is a cross-dresser, no, crossover tool right? I stuck it in the drivetrain section because my addled brain thought chain, but you are right, it is also a rear wheel issue.
Perhaps a Tool section would be a nice workaround? That might be a nice congregation point for all things TOOL, such as tool kits, and tool storage, and... yeah, good idea'r!
cat screwed with this post 09-29-2006 at 01:29 AM Reason: edited picture
cat is offline   Reply With Quote
Old 11-27-2006, 10:27 PM   #53
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,239
as promised elsewhere
an administrative draft "seal of approval":
If I may borrow the phrase: simple yet elegant?
Now if approved, I need someone to help me remove the white outside of the black ring. I have tried to remove it but have failed to end up with a jpeg that doesn't have any background...
meat popsicle is offline   Reply With Quote
Old 12-28-2006, 05:11 AM   #54
gruesom2som
gruesom2som's Avatar
Oddometer: 14
I felt a bit uncomfortable that zip-tie might slide while I fiddle with it, I found a simple way to secure it in place. I had my "Creeper's Chain Alignment Tool" with a metric 6 rod.. Threads gouges grooves on the zip-tie and you're comfortably +/- 0.5 mm's on the spot..
Well.. Of course it would take ages to roll it for a couple inches if you are so dumb to zip it at the end of the rod..
..or maybe after a chain replacement!
gruesom2som is offline   Reply With Quote
Old 12-28-2006, 09:32 AM   #55
alpiv
Sr. nOOb
alpiv's Avatar
Oddometer: 2,173
Creeper -- You make my days so much easier..
alpiv is offline   Reply With Quote
Old 12-28-2006, 09:42 PM   #56
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Better that than your nights.
So... how's tricks?
creeper is offline   Reply With Quote
Old 10-01-2012, 04:21 AM   #57
turbodieseli4i6
turbodieseli4i6's Avatar
Oddometer: 463
Tagged for future reference!
turbodieseli4i6 is offline   Reply With Quote
Old 10-01-2012, 05:12 AM   #58
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
And yet another ancient Creeperism comes back from the dead. You gotta love it...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 10-01-2012, 06:22 AM   #59
ihatefalling
Let it roll
ihatefalling's Avatar
Oddometer: 3,387
Pretty cool . . . . . . .thanks !
We gunna debitchulate you boy . . . .
ihatefalling is offline   Reply With Quote
Times are GMT -7.   It's 09:46 PM.
