Old 08-08-2012, 11:47 AM   #3391
beergut
Thumper
beergut's Avatar
Oddometer: 421
Of course! For anyone else...
http://www.ebcbrakes.com/ebc_brakes_...d_rotors.shtml
My KLR
DIY rear top rack
beergut is offline   Reply With Quote
Old 08-08-2012, 12:43 PM   #3392
stefer
stefer's Avatar
Oddometer: 119
Okay, say I do decide to go with the index idea where I put an index mark on the crankshaft and align the rotor while torquing it down....
How accurate do I have to get the rotor?
According to my calculations, a 1 degree angle at 1000 rpm results in 0.046 seconds of delay (or premature) from where it should be correctly aligned. Doesn't seem like very much, but is that enough to cause issues?
Rolla, MO Rider
Red 2006 KLR 650 - Odometer: Much too low
Profound quote:
Originally Posted by An Ancient Proverb
Anxiety weighs down the heart, but a kind word cheers it up.
stefer is offline   Reply With Quote
Old 08-08-2012, 09:13 PM   #3393
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,843
Unless you're looking to address some sort of discrete, performance-mod timing goal, I'd suggest doing your damndest to match the correct factory timing.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is online now   Reply With Quote
Old 08-08-2012, 09:22 PM   #3394
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,974
It does have to be rather exact, yes.
Best thing to do- discern where the woodruff key is, and mark this with a sharpy on the face of the crank,
JAFO is online now   Reply With Quote
Old 08-08-2012, 10:34 PM   #3395
stefer
stefer's Avatar
Oddometer: 119
Absolutely. Just concerned about human error.
Rolla, MO Rider
Profound quote:
Old 08-09-2012, 04:14 AM   #3396
Kentucky
Oddometer: 1,222
Originally Posted by fleshpiston View Post
Ya know I thought about it but I work too slow
I've made a little progress though ..........
A question for you guys running a LV X3..... I've read that you need to trim the fender but this much?
Hard to tell from the pics but looks like I need to remove over an inch from the right side. Is this correct?
You might think about pushing the Leo further onto the header pipe. Mine fit perfect after I did that with no trimming.
Barry
2013 Kymco Like 200i
2009 Piaggio BV500 Tourer
2009 Kawasaki KLR650
1973 Jawa 350 Californian two stroke twin
Kentucky is offline   Reply With Quote
Old 08-09-2012, 01:09 PM   #3397
Hetzel88
cycles is a mean toy
Oddometer: 170
I find it almost inconceivable that you can't get the woodruff key out. I'd love to hear what you did.
Hetzel88 is offline   Reply With Quote
Old 08-09-2012, 02:25 PM   #3398
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,256
I'm wanting to fill my stock bars with something to help insulate them so my heated grips actually heat my hands.
What should I use? Thanks
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 08-09-2012, 02:26 PM   #3399
fleshpiston
fleshpiston's Avatar
Oddometer: 592
Barry
Thanks, I'll try that. I need to get the airbox back in and see how far forward I can go.
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 08-09-2012, 03:18 PM   #3400
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
You can use expanding foam insulation and a long application tube. Another option would be to fill the bars with lead or steal shot, and cap that with foam. The shot will help dampen the vibes.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 08-09-2012, 03:43 PM   #3401
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,675
But makes them heavy..................
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 08-09-2012, 04:00 PM   #3402
newcastleadam
Artful Tagger
Oddometer: 3,455
It's already heavy; it's a KLR
Adam
Old 08-09-2012, 04:30 PM   #3403
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,675
sorry........'er
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
Old 08-09-2012, 05:06 PM   #3404
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,048
I feel the same way. A Dremel with a cutting wheel would precisely cut or even grind it away if necessary. Make sure you wear glasses when using those cutting wheels, they like to shatter but a guarantee you can get it out with them...
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 08-09-2012, 06:20 PM   #3405
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Times are GMT -7.   It's 03:32 PM.
