Old 01-10-2013, 05:47 PM   #3946
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,394
Thanks. Damn, the bike has 1100 miles on it , really shouldn't be needing that repair yet.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 01-10-2013, 06:33 PM   #3947
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,289
Petcock Mod
You can also just remove the diaphragm block with gaskets and spring and the back cover and make a little aluminum plate and gasket and convert it to manual yourself.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is offline   Reply With Quote
Old 01-10-2013, 09:38 PM   #3948
Myfuture_yourdebt
Oddometer: 372
It could be your gas tank cap's vent. Ride with the cap open and see if the problem does away. I'm not sure on a fix for that if it is causing the issue.
And instead of the petcock diaphragm leaking the vacuum line to it could be leaking or have a bad seal over the petcock...and just like a diaphragm leak, it could prevent the valve from fully opening.
Or some junk in the carb, of course. Also make sure your carb vent isn't restricted and while your at it that the fuel tank vent (under the seat) is also not restricted.
As most of us know, there's a list of issues that can potentially cause surging. The most common causes involve something that is leaking or pinched.
Myfuture_yourdebt is offline   Reply With Quote
Old 01-10-2013, 11:34 PM   #3949
jules083
jules083's Avatar
Oddometer: 3,588
For anyone with an aftermarket exhaust-
Do they really do much? I have a big gun full exhaust the previous owner installed. He gave me the old exhaust, but the clamp that holds the muffler to the header is missing. I'm getting sick of hearing the big gun, but if its actually helping I'll leave it on.
I just figured I'd ask before I bought a clamp then went through the changing process. I hate to give up HP, but this thing is getting annoying.
All typos and misspellings blamed on my phone.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 01-11-2013, 12:00 AM   #3950
schaffer40
I look lived in.....
schaffer40's Avatar
Oddometer: 402
@jules083
I think the only real gain on a stock KLR is the weight savings.
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson
Punk Rock Changed My Life- The Minutemen
schaffer40 is offline   Reply With Quote
Old 01-11-2013, 04:15 AM   #3951
Grinnin
Forever N00b
Oddometer: 2,631
The aftermarket exhaust might increase the HP if the PO re-jetted carefully. But I've bought enough bikes that were badly jetted that I'm starting to think that people don't think that much. If the PO did re-jet, you'll have to do it again to really test the stock muffler.
My KLR came with an obnoxious-loud aluminum muffler and a drilled and gutted stock muffler. I got an unmolested muffler from E-bay and the bike was easier to ride and far quieter. The bike came with stock jets so it didn't run very well with the aluminum exhaust.
Motorcycles are magical.
Grinnin is offline   Reply With Quote
Old 01-11-2013, 05:01 AM   #3952
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,503
I think someone was selling those already made up as a kit at one time. Probably a good thing to have along on a trip, or a drop in ready manual petcock like Eagle Mike sells for like 25 bucks. I think it's a Yammy TW200 petcock.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 01-11-2013, 06:36 AM   #3953
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,734
Make sure that the vacuum line at the carb is properly blocked off/sealed if this mod is done. I did this mod about 40K ago as well as the removal of the 'other' vacuum asisted polution stuff - then just the looped the hose between the 2 vacuum takeoff points on the carb.
Tsotsie is offline   Reply With Quote
Old 01-11-2013, 07:11 AM   #3954
astrolump
astrolump's Avatar
Oddometer: 699
i have gone back and forth between alumnium and stock pipes on both of my klrs a number of times. an aftermarket can like the big gun or lexx will give a slight increase in power if you re jet. it is defiantly noticeable to me in the mid-range. but im sure it is very slight maybe 1-2 hp? i choose the louder pipes because i like the fact that they tend to chase off the deer on the back trails i ride. and they do defiantly help with alerting Miami drivers.
i always run some type of quiet core and spark arrestor combo to take the edge off the roar and be forest service legal.
you can get a quiet core and spark arrestor for that big gun you have, then pack it with steel wool and it becomes a good pipe that weighs less than half the boat anchor the klr comes with. every bit of weight you remove makes a difference in performance....and the performance im talking about is the performance of my lower back when i pick the pig back up in the mud
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is offline   Reply With Quote
Old 01-11-2013, 07:49 AM   #3955
jules083
jules083's Avatar
Oddometer: 3,588
It's the one with a spark arrestor, not sure if its a quiet core or not. After talking to the last kid (owner 2) I highly doubt it. Typical kid you would expect to see on a gsx-r or something.
I'll look around for a quiet core, see what I can find. It's not too bad as long as you're off the highway. Backroads its fine, just that constant drone is what kills me. I've even thought about trying to make the tip turn down somehow, maybe to divert some sound.
And I do need to do some jetting. I went according to dynojet's instructions and I think its too lean. Getting 38 mpg on the last tank, that can't be right.
Old 01-11-2013, 09:16 AM   #3956
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,289
38 mpg sounds like its too rich,not lean,unless you are riding it hard.
2001 GAS GAS 321
IBA # 23,716
Old 01-11-2013, 05:19 PM   #3957
jules083
jules083's Avatar
Oddometer: 3,588
I don't know what I was thinking when I typed that. Meant too lean.
Old 01-11-2013, 07:37 PM   #3958
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 4,977
I think the muffler change and subsequent rejetting helped mid range and slightly higher. I feel the jetting did as much as the exhaust. My mpg sucks but I spend much of my 35 mile commute at 5500 RPMS and higher. But 30 mpg on a motorcycle beats 13 mpg in a Durango.
1988 KLR 650 Bare frame,swing arm & title For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by WaterWheel View Post
From what I've heard, riding a DR feels just like riding a KLR except your head doesn't sway left and right constantly scanning the ditches for aluminum cans.
Chicken Helmet is online now   Reply With Quote
Old 01-11-2013, 07:40 PM   #3959
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,289
You just did it again !
2001 GAS GAS 321
IBA # 23,716
Old 01-11-2013, 07:44 PM   #3960
jules083
jules083's Avatar
Oddometer: 3,588
ghead: ghead: ghead:
Edit- just noticed the banned thingie. From my phone it was a picture of a guy beating his head on a brick wall.
jules083 screwed with this post 01-20-2013 at 06:53 AM
Times are GMT -7.   It's 06:13 AM.
